Kluas Posted August 16, 2025 Posted August 16, 2025 I just want to inform you, that tonight's system update showed this error: Hardware: Hardkernel Odroid C4 System: Armbian 25.5.2 bookworm (Debian Bookworm) --> As the issue is still present, I think I'd should going to inform you. Log: apt-get upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-bsp-cli-odroidc4-current armbian-firmware armbian-plymouth-theme base-files linux-dtb-current-meson64 linux-headers-current-meson64 linux-image-current-meson64 linux-u-boot-odroidc4-current 8 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 163 MB of archives. After this operation, 20.1 MB of additional disk space will be used. Get:1 http://apt.armbian.com bookworm/bookworm-utils arm64 base-files arm64 25.8.1-12.4+deb12u11-bookworm [53.1 kB] Err:1 http://apt.armbian.com bookworm/bookworm-utils arm64 base-files arm64 25.8.1-12.4+deb12u11-bookworm File has unexpected size (53132 != 53108). Mirror sync in progress? [IP: 198.140.141.60 80] Hashes of expected file: - SHA512:26d209e8ad9cd32687fbbda4b6cc6eaf4bb56489ad6859c5c10814d5a9a07a2a91da5dd7f02d4d4bf8d6c26d28d26dd2cf8ecc0d165445a5b80c3283f2a9c646 - SHA256:1616e5ec3540e36c9b2e566171f34d3dd720d65545c0229b9ca6f5ea417ae9e0 - SHA1:b68df5126ffa003446e4666d8c5ada4ccd70be52 [weak] - MD5Sum:69494de792a101fb2545f1446dea8ef9 [weak] - Filesize:53108 [weak] Get:2 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-bsp-cli-odroidc4-current arm64 25.8.1 [435 kB] Err:2 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-bsp-cli-odroidc4-current arm64 25.8.1 File has unexpected size (435268 != 435180). Mirror sync in progress? [IP: 198.140.141.60 80] Hashes of expected file: - SHA512:7e978f3ef834a0a01e52728dd72062f573fb7f973b3dedbdf36a6efd58972c5fab93c526a3945a9b6e0ff28a81bc4ade80029cf8ddb149f5d1a4ffaf8a6c2ab1 - SHA256:dc3f93c3de4bd694314451f1e7b257ff582d8ec728f206c557146666aefdc258 - SHA1:7354b3476c9b0972d60dab62fc5352246791d2e1 [weak] - MD5Sum:a8e1f40bf17e6e2b6d7765ef03fb77e2 [weak] - Filesize:435180 [weak] Get:3 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-firmware all 25.8.1 [95.9 MB] Ign:3 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-firmware all 25.8.1 Err:3 http://apt.armbian.com bookworm/main arm64 armbian-firmware all 25.8.1 File has unexpected size (95947948 != 95947672). Mirror sync in progress? [IP: 198.140.141.60 80] Get:4 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-plymouth-theme all 25.8.1 [112 kB] Ign:4 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-plymouth-theme all 25.8.1 Err:4 http://apt.armbian.com bookworm/main arm64 armbian-plymouth-theme all 25.8.1 File has unexpected size (112064 != 112032). Mirror sync in progress? [IP: 198.140.141.60 80] 0 Quote
Werner Posted August 16, 2025 Posted August 16, 2025 Yeah something is wrong. I had a similar issue for noble base-files package on a different mirror. 0 Quote
Solution laibsch Posted August 16, 2025 Solution Posted August 16, 2025 Thank you for the heads-up, @Kluas. 57 minutes ago, Kluas said: Get:2 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-bsp-cli-odroidc4-current arm64 25.8.1 [435 kB] Err:2 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-bsp-cli-odroidc4-current arm64 25.8.1 File has unexpected size (435268 != 435180). Mirror sync in progress? [IP: 198.140.141.60 80] Hashes of expected file: - SHA512:7e978f3ef834a0a01e52728dd72062f573fb7f973b3dedbdf36a6efd58972c5fab93c526a3945a9b6e0ff28a81bc4ade80029cf8ddb149f5d1a4ffaf8a6c2ab1 - SHA256:dc3f93c3de4bd694314451f1e7b257ff582d8ec728f206c557146666aefdc258 - SHA1:7354b3476c9b0972d60dab62fc5352246791d2e1 [weak] - MD5Sum:a8e1f40bf17e6e2b6d7765ef03fb77e2 [weak] - Filesize:435180 [weak] Your Packages file is uptodate. It is indeed a mirror issue. Just wait or use a different mirror. $ wget -qO- https://xogium.performanceservers.nl/apt/dists/bookworm/main/binary-arm64/Packages.bz2|bzgrep 25.8.1 -8|grep ^Package.*armbian-bsp-cli-odroidc4-current -A18 | grep -e ^SHA512 -e ^Size Size: 435180 SHA512: 7e978f3ef834a0a01e52728dd72062f573fb7f973b3dedbdf36a6efd58972c5fab93c526a3945a9b6e0ff28a81bc4ade80029cf8ddb149f5d1a4ffaf8a6c2ab1 $ wget -qO- https://xogium.performanceservers.nl/apt/pool/main/a/armbian-bsp-cli-odroidhc4-current/armbian-bsp-cli-odroidhc4-current_25.8.1_arm64__1-PCee86-Va97e-He458-B1e5d-Rf36a.deb | sha512sum c0a4948328da1996a6d4df7adf33ff36dcd9f4bb377c4727d2a8f244e8809668754abb1fbee741fdfb2a0573690ebd858afdbb350f0fec4f6519b65b1b9cb385 - $ wget -qO- https://xogium.performanceservers.nl/apt/pool/main/a/armbian-bsp-cli-odroidhc4-current/armbian-bsp-cli-odroidhc4-current_25.8.1_arm64__1-PCee86-Va97e-He458-B1e5d-Rf36a.deb | wc -c 434960 0 Quote
