Hello everybody,
I tried building an in-kernel module for USB Dongle
Bus 001 Device 003: ID 2357:0120 TP-Link Archer T2U PLUS [RTL8821AU]
on my OrangePi Plus.
Armbian supplied module from aircrack-ng/rtl8812au has become aging and raises exception errors on modprobe -r.
It was deactivated :
root@orangepiplus:/etc/modprobe.d# vi blacklist-88XXau.conf
#blacklist 88XXau
I made a fresh install of Armbian minimal image, then switched to :
root@orangepiplus:~# uname -a
Linux orangepiplus 6.15.4-edge-sunxi #1 SMP Fri Jun 27 10:13:43 UTC 2025 armv7l GNU/Linux
root@orangepiplus:/usr/src# cat /proc/version
Linux version 6.15.4-edge-sunxi (build@armbian) (arm-linux-gnueabihf-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP Fri Jun 27 10:13:43 UTC 2025
root@orangepiplus:/usr/src# zcat /proc/config.gz | grep CC_VERSION
CONFIG_CC_VERSION_TEXT="arm-linux-gnueabihf-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0"
CONFIG_GCC_VERSION=130300
root@orangepiplus:/usr/src# zcat /proc/config.gz | grep STACKPROTECTOR
CONFIG_CC_HAVE_STACKPROTECTOR_TLS=y
CONFIG_STACKPROTECTOR_PER_TASK=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
Headers were downloaded with armbian-config :
root@orangepiplus:/mnt/sda2/src/linux-6.15.4#
drwxr-xr-x 25 root root     4096 Aug 21 21:40 linux-headers-6.15.4-edge-sunxi
Then performed usual build process:
root@orangepiplus:/usr/src# sudo git clone --depth 1 --branch linux-6.15.y https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git
root@orangepiplus:/usr/src# sudo ln -s /usr/src/linux /lib/modules/$(uname -r)/build
root@orangepiplus:/usr/src# ls -al /lib/modules/$(uname -r)/build
lrwxrwxrwx 1 root root 14 Aug 21 22:45 /lib/modules/6.15.4-edge-sunxi/build -> /usr/src/linux
cp /boot/config-$(uname -r) /usr/src/linux/.config
sudo make olddefconfig
sudo make menuconfig
Module activated in the following tree :
│ Symbol: RTW88 [=m]        │
  │ Type  : tristate        │
  │ Defined at drivers/net/wireless/realtek/rtw88/Kconfig:2                                                             │
  │   Prompt: Realtek 802.11ac wireless chips support        │
  │   Depends on: NETDEVICES [=y] && WLAN [=y] && WLAN_VENDOR_REALTEK [=y] && MAC80211 [=m]                             │
  │   Location:        │
  │     -> Device Drivers        │
  │       -> Network device support (NETDEVICES [=y])        │
  │         -> Wireless LAN (WLAN [=y])        │
  │           -> Realtek devices (WLAN_VENDOR_REALTEK [=y])                                                             │
  │ (1)         -> Realtek 802.11ac wireless chips support (RTW88 [=m])
root@orangepiplus:/usr/src/linux# grep -E 'CONFIG_RTW88_CORE|CONFIG_RTLWIFI|CONFIG_RTW88_8821AU' .config
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_USB=m
# CONFIG_RTLWIFI_DEBUG is not set
CONFIG_RTW88_CORE=m
CONFIG_RTW88_8821AU=m
cp /usr/src/linux-headers-6.15.4-edge-sunxi/Module.symvers /usr/src/linux/
Then compiled with:
root@orangepiplus:/usr/src/linux# sudo make -j$(nproc) ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- M=drivers/net/wireless/realtek/rtw88
make[1]: Entering directory '/usr/src/linux/drivers/net/wireless/realtek/rtw88'
  MODPOST Module.symvers
  CC [M]  rtw88_core.mod.o
  CC [M]  .module-common.o
  CC [M]  rtw88_8822b.mod.o
  CC [M]  rtw88_8822bs.mod.o
  CC [M]  rtw88_8822bu.mod.o
  CC [M]  rtw88_8822c.mod.o
  CC [M]  rtw88_8822cs.mod.o
  LD [M]  rtw88_core.ko
  LD [M]  rtw88_8822b.ko
  LD [M]  rtw88_8822bs.ko
  LD [M]  rtw88_8822bu.ko
  LD [M]  rtw88_8822c.ko
  LD [M]  rtw88_8822cs.ko
  LD [M]  rtw88_8822cu.ko
  LD [M]  rtw88_8723x.ko
  LD [M]  rtw88_8723d.ko
  LD [M]  rtw88_8723ds.ko
  LD [M]  rtw88_8723du.ko
  LD [M]  rtw88_8821c.ko
  LD [M]  rtw88_8821cs.ko
  LD [M]  rtw88_8821cu.ko
  LD [M]  rtw88_88xxa.ko
  LD [M]  rtw88_8821a.ko
  LD [M]  rtw88_8821au.ko
  LD [M]  rtw88_sdio.ko
  LD [M]  rtw88_usb.ko
make[1]: Leaving directory '/usr/src/linux/drivers/net/wireless/realtek/rtw88'
root@orangepiplus:/usr/src/linux# modinfo /usr/src/linux/drivers/net/wireless/realtek/rtw88/rtw88_8821au.ko
filename:       /usr/src/linux/drivers/net/wireless/realtek/rtw88/rtw88_8821au.ko
license:        Dual BSD/GPL
description:    Realtek 802.11ac wireless 8821au/8811au driver
author:         Bitterblue Smith <rtl8821cerfe2@gmail.com>
alias:          usb:v0BDAp0811d*dc*dsc*dp*icFFiscFFipFFin*
depends:        rtw88_usb,rtw88_8821a
vermagic:       6.15.11 SMP mod_unload ARMv7 thumb2 p2v8
sudo make modules_install ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-
doesn't work. Needs fixing.
So I just copied modules to system location :
root@orangepiplus:/usr/src/linux# sudo cp /usr/src/linux/drivers/net/wireless/realtek/rtw88/*.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/realtek/rtw88/
root@orangepiplus:/usr/src/linux# sudo depmod -a
But loading failed as follows :
root@orangepiplus:/usr/src/linux# sudo modprobe rtw88_8821au
modprobe: ERROR: could not insert 'rtw88_8821au': Exec format error
Aug 22 16:31:52 orangepiplus kernel: module rtw88_88xxa: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time
It appears to be a structural issue, as I also tried building out-of-kernel module from lwfinger/rtw88
I also tried building on Nanopi-r5s.
Each time  Exec format error was observed despite the module was successfully built.
Different analysis point to GCC version mismatch between kernel and build host, ABI incompatibility and subtle build failures, thus causing non-alignment with the kernel buid. Several other build flags were tried to align with the kernel, but in vain.
The root cause was not found. I am running out of options now.
Could community or development team point to correct approach building an in-kernel module on a running system in native environment ?
PS : complementary information :
when armbian headers were downloaded with armbian-config, the following build output was observed :
/usr/lib/gcc/arm-linux-gnueabihf/12/cc1 -quiet -I ./scripts/include -I ./scripts/dtc/libfdt -imultilib . -imultiarch
 arm-linux-gnueabihf -D _LARGEFILE_SOURCE -D _FILE_OFFSET_BITS=64 -D NO_YAML -MMD scripts/dtc/.dtc.o.d scripts/dtc/dtc.c
 -quiet -dumpdir scripts/dtc/ -dumpbase dtc.c -dumpbase-ext .c -mfloat-abi=hard -mtls-dialect=gnu -mthumb
 -mlibarch=armv7-a+fp -march=armv7-a+fp -O2 -Wall -Wmissing-prototypes -Wstrict-prototypes -std=gnu11 -fomit-frame-pointer
 -o /tmp/ccY6Z3QK.s
It may give some clues on the flags used.
Edited by y52
If you build the module in question on the target machine, why do you use stuff like "ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-"? Doesn't make sense when building natively.
I do agree, that it doesn't. But it looks like Armbian kernel is built with
Taken unalignment problem the same flag was used with which the kernel and headers were built. It doesn't help either.
Edited by y52
What a PR is ? Could you be more specific about your suggestion ?
In fact, could this module be included into the next 6.15 EDGE build ?
I don't know if this module is indeed functional (I want to test it). As it is concurrent with Armbian supplied 88XXau for the same hardware,  one of them needs to be disabled in /etc/modprobe.d/ either:
# cat blacklist-88XXau.conf
blacklist 88XXau
or
# cat blacklist-RTW88_8821AU.conf
blacklist rtw88_8821au
Edited by y52
PR in this context is a "pull request" on github, you are telling us to pull some updates from your github code base
Could your team make such a "pull request" ?
Could you also drop the github link at the same time ?
I shall try making it myself.
In the meantime and in order digging further I've switched to gcc-13 to build module with the same version as the kernel :
root@orangepiplus:/mnt/sda2/src/linux-6.15.4# gcc --version
gcc (Debian 13.4.0-1) 13.4.0
Then I've downloaded headers with armbian-config to : /usr/src/linux-headers-6.15.4-edge-sunxi
and proceeded with rebuild Using Official Headers
cd /mnt/sda2/src/linux-6.15.4
make clean
cp /usr/src/linux-headers-6.15.4-edge-sunxi/.config .config
sed -i 's/^EXTRAVERSION =.*/EXTRAVERSION = -edge-sunxi/' Makefile
make olddefconfig 787 make menuconfig 788 grep -E 'CONFIG_RTW88_CORE|CONFIG_RTLWIFI|CONFIG_RTW88_8821AU' .config
make modules_prepare
cp /usr/src/linux-headers-6.15.4-edge-sunxi/Module.symvers .
make M=drivers/net/wireless/realtek/rtw88 modules -j$(nproc)
sudo cp /boot/System.map-$(uname -r) /mnt/sda2/src/linux-6.15.4/System.map root@orangepiplus:/mnt/sda2/src/linux-6.15.4# sudo make M=drivers/net/wireless/realtek/rtw88 modules_install make[1]: Entering directory '/mnt/sda2/src/linux-6.15.4/drivers/net/wireless/realtek/rtw88' INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_core.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8822b.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8822bs.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8822bu.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8822c.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8822cs.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8822cu.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8723x.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8723d.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8723ds.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8723du.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8821c.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8821cs.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8821cu.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_88xxa.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8821a.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_8821au.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_sdio.ko INSTALL /lib/modules/6.15.4-edge-sunxi/updates/rtw88_usb.ko DEPMOD /lib/modules/6.15.4-edge-sunxi make[1]: Leaving directory '/mnt/sda2/src/linux-6.15.4/drivers/net/wireless/realtek/rtw88'
sudo depmod -a
But the resulting module failed loading again :
root@orangepiplus:/mnt/sda2/src/linux-6.15.4# sudo modprobe rtw88_8821au modprobe: ERROR: could not insert 'rtw88_8821au': Exec format error Aug 24 12:08:53 orangepiplus kernel: module rtw88_core: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time
It proves a structural mismatch again.
Armbian built the 6.15.4-edge-sunxi kernel using Ubuntu's GCC 13 likely with plugins.
GCC plugins randomize or instrument the layout of kernel structures — including struct module.
It means, that you cannot reproduce the exact struct module layout unless you use the exact same GCC plugin configuration — which is not available to end users!
Could it be fixed and what is the right approach to adding missing in-kernel modules from kernel sources or headers ?
It has been tried several times with similar results :
On stable 6.12.35
The lwfinger/rtl8821au driver causes kernel exceptions (oops/panics)
It doesn't survive simple lsmod.
On kernel 6.15.4 :
It fails inserting : root@orangepiplus:~# sudo cp /var/lib/dkms/rtw88/0.6/build/*.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/realtek/rtw88/ root@orangepiplus:~# ls -al /lib/modules/$(uname -r)/kernel/drivers/net/wireless/realtek/rtw88 total 23744 drwxr-xr-x 2 root root 4096 Aug 24 15:13 . drwxr-xr-x 6 root root 4096 Aug 21 21:02 .. -rw-r--r-- 1 root root 961676 Aug 24 15:13 rtw_8703b.ko -rw-r--r-- 1 root root 415924 Aug 24 15:13 rtw_8723cs.ko -rw-r--r-- 1 root root 991580 Aug 24 15:13 rtw_8723d.ko -rw-r--r-- 1 root root 416088 Aug 24 15:13 rtw_8723ds.ko -rw-r--r-- 1 root root 419968 Aug 24 15:13 rtw_8723du.ko -rw-r--r-- 1 root root 492256 Aug 24 15:13 rtw_8723x.ko -rw-r--r-- 1 root root 929420 Aug 24 15:13 rtw_8812a.ko -rw-r--r-- 1 root root 424112 Aug 24 15:13 rtw_8812au.ko -rw-r--r-- 1 root root 1271964 Aug 24 15:13 rtw_8814a.ko -rw-r--r-- 1 root root 420676 Aug 24 15:13 rtw_8814au.ko -rw-r--r-- 1 root root 900128 Aug 24 15:13 rtw_8821a.ko -rw-r--r-- 1 root root 422752 Aug 24 15:13 rtw_8821au.ko -rw-r--r-- 1 root root 1025348 Aug 24 15:13 rtw_8821c.ko -rw-r--r-- 1 root root 415504 Aug 24 15:13 rtw_8821cs.ko -rw-r--r-- 1 root root 421624 Aug 24 15:13 rtw_8821cu.ko -rw-r--r-- 1 root root 1217480 Aug 24 15:13 rtw_8822b.ko -rw-r--r-- 1 root root 415504 Aug 24 15:13 rtw_8822bs.ko -rw-r--r-- 1 root root 425156 Aug 24 15:13 rtw_8822bu.ko -rw-r--r-- 1 root root 1734256 Aug 24 15:13 rtw_8822c.ko -rw-r--r-- 1 root root 415504 Aug 24 15:13 rtw_8822cs.ko -rw-r--r-- 1 root root 420196 Aug 24 15:13 rtw_8822cu.ko -rw-r--r-- 1 root root 666896 Aug 24 15:13 rtw_88xxa.ko -rw-r--r-- 1 root root 7900876 Aug 24 15:13 rtw_core.ko -rw-r--r-- 1 root root 575660 Aug 24 15:13 rtw_sdio.ko -rw-r--r-- 1 root root 560804 Aug 24 15:13 rtw_usb.ko root@orangepiplus:~# sudo depmod -a $(uname -r) root@orangepiplus:~# sudo modprobe rtw_8821au modprobe: ERROR: could not insert 'rtw_8821au': Exec format error Aug 24 15:14:25 orangepiplus kernel: module rtw_core: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time
It is already loaded :
root@orangepiplus:~# lsmod
Module                  Size  Used by
cfg80211              618496  2 mac80211,8189es
Just one more time again :
root@orangepiplus:/mnt/sda2/src/rtw88# sudo modprobe cfg80211
root@orangepiplus:/mnt/sda2/src/rtw88# sudo modprobe rtw_8821au
root@orangepiplus:/mnt/sda2/src/rtw88# sudo modprobe rtw_core
modprobe: ERROR: could not insert 'rtw_core': Exec format error
Edited by y52
I've now exhausted all practical options.
I guess that the 6.15.4-edge-sunxi kernel was built with GCC plugins and BTF settings that cannot be reproduced with out-of-tree module builds.
Even using the cross-compiler (arm-linux-gnueabihf-gcc-13) did not help — because the issue is not the compiler binary, but the entire build environment:
CONFIG_DEBUG_INFO_BTF_MODULES=y
GCC_PLUGIN_RANDSTRUCT or STRUCTLEAK
ftrivial-auto-var-init=zero
TLS guard offset (-mstack-protector-guard-offset=1464)
Kernel symbol versioning
These change the binary layout of struct module, making any externally built module incompatible.
The question now, how could a missing module be added to a running system !
It is almost improbable, that development path is completely blocked and requires tedious efforts for adding a simple already existing module.
In the meantime, while the right approach is being looked for, could somebody point to a "pull request" procedure?
Edited by y52
