fxkl47BF Posted August 28, 2025 Posted August 28, 2025 i've been using armbian for a whole hour now i figure i've mastered this thing :) i loaded Armbian_25.5.1_Odroidxu4_bookworm_current_6.6.88_minimal.img on a sd and fired up an old xu4 according to the instruction the first thing to do is run armbian-config but it hangs because i don't have an interweb connection is there a way around that 0 Quote
Werner Posted August 28, 2025 Posted August 28, 2025 53 minutes ago, fxkl47BF said: according to the instruction the first thing to do is run armbian-config Um...no? Where did you get that info? Using armbian-config is totally optional. Everything this tool does can also be done manually. 1 Quote
Werner Posted August 28, 2025 Posted August 28, 2025 I guess that is a bit misleading. As mentioned using armbian-config is optional to do certain tasks in a more comfortable way than manually/traditionally. 0 Quote
fxkl47BF Posted August 28, 2025 Author Posted August 28, 2025 it appears to be a useful application is there a way to use it without a network 0 Quote
