Stefal Posted August 29, 2025 Posted August 29, 2025 (edited) Hello ! I'm trying to build my custom Armbian image for a Raspberry Pi. When I build it with these settings, I get a rolling release, which I don't want. compile.sh BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes DISABLE_IPV6=true INCLUDE_HOME_DIR=yes KERNEL_CONFIGURE=no NETWORKING_STACK=network-manager RELEASE=trixie EXPERT=yes BOARD=rpi4b But when I boot with the official armbian minimal image (Armbian_25.8.1_Rpi4b_trixie_current_6.12.41_minimal.img) It's not on the rolling release. Do I miss a setting ? edit: I've tried with building the image on the main and the v25.08 branch. Edited August 29, 2025 by Stefal 0 Quote
SteeMan Posted August 29, 2025 Posted August 29, 2025 Stable images can only be built by Armbian. All user built images are essentially rolling releases. But once booted into an image, you can use armbian-config to switch to the stable apt repositories, which means you won't get bug fixes or security updates to the kernel, but instead you get a stable kernel build released once every three months. 0 Quote
Stefal Posted August 29, 2025 Author Posted August 29, 2025 14 minutes ago, SteeMan said: All user built images are essentially rolling releases Ho ! That's a new thing isn't it ? And IMHO, a strange choice. Is there a way to disable that rolling release during the image building process? 0 Quote
robertoj Posted August 29, 2025 Posted August 29, 2025 (edited) 56 minutes ago, SteeMan said: Stable images can only be built by Armbian. All user built images are essentially rolling releases. But once booted into an image, you can use armbian-config to switch to the stable apt repositories, which means you won't get bug fixes or security updates to the kernel, but instead you get a stable kernel build released once every three months. With the armbian build system, you can build either Bookworm or Trixie You will always get the latest Bookworm or the latest Trixie packages in a freshly built armbian OS. This is what's meant by "always rolling release"... not to be understood as "always sid or Trixie". Independently, the armbian build system will let you choose a stable Linux version, or the latest available from Armbian (edge). Edited August 29, 2025 by robertoj 0 Quote
laibsch Posted August 29, 2025 Posted August 29, 2025 Armbian kernel and BSP Debian/Ubuntu userland 0 Quote
Stefal Posted September 8, 2025 Author Posted September 8, 2025 On 8/29/2025 at 6:43 PM, SteeMan said: But once booted into an image, you can use armbian-config to switch to the stable apt repositories Regardless of which version I boot ("official" or home built with current) , the apt repositories are the same. And after I apt update && apt upgrade the "current" release, the "rolling" message disappears from the MOTD. On 8/29/2025 at 7:38 PM, robertoj said: This is what's meant by "always rolling release"... not to be understood as "always sid or Trixie". I understand that I should not care of these MOTD messages, the meaning is not what I thought it was. 0 Quote
robertoj Posted September 8, 2025 Posted September 8, 2025 9 hours ago, Stefal said: I understand that I should not care of these MOTD messages, the meaning is not what I thought it was. Building a rolling release is more than just showing that in the MOTD. If you do "sudo apt upgrade" in an OS image you just built, you probably will have zero or one packages to upgrade. If you start with an image built a long time ago, or with packages defined a long time ago, then "sudo apt upgrade" would take a long time. 0 Quote
