Missing Battery Infos
Go to solution Solved by martinayotte,
hi,
i' using kernel 4.11.5-sunxi #3, before i used kernel 3.4.113-sunxi7i.
i had a script running to collect infos, but now none of the files are there anymore, why?
cat /sys/class/power_supply/ac/present
cat /sys/class/power_supply/ac/voltage_now
cat /sys/class/power_supply/ac/current_now
cat /sys/class/power_supply/battery/status
cat /sys/class/power_supply/battery/voltage_now
cat /sys/class/power_supply/battery/current_now
cat /sys/class/power_supply/usb/present
cat /sys/class/power_supply/usb/voltage_now
cat /sys/class/power_supply/usb/current_now
cat /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034/temp1_input
regards
  • Solution
From what I understood, Mainline has different folder hierarchy.
Check those :
/sys/power/axp_pmu/ac
/sys/power/axp_pmu/battery
/sys/power/axp_pmu/vbus
