mitu Posted Sunday at 05:47 AM Posted Sunday at 05:47 AM I have an Orange Pi 5 board, installed with the 25.8 Debian Bookworm + Cinnamon desktop system. I have switched (using armbian-config) to the edge kernel in order to test the HDMI audio support in the new Linux kernel, but I'm not getting any audio out. The ALSA HDMI card seems to be present (see below), but there's no sound using speaker-test or aplay. Quote $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: hdmi0 [hdmi0], device 0: fddf0000.i2s-i2s-hifi i2s-hifi-0 [fddf0000.i2s-i2s-hifi i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: rockchipes8388 [rockchip,es8388], device 0: fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0] Subdevices: 1/1 Subdevice #0: subdevice #0 I have enabled the hdmirx overlay through armbian-config also, but the result is the same. Is there anything extra that should be configured in order to get audio output ? Output from armbianmonitor - https://paste.armbian.com/gegorimako 0 Quote
IBV Posted Sunday at 09:25 AM Posted Sunday at 09:25 AM Hi, always check with "amixer" (alsa mixer) if your outputs are not muted. 0 Quote
mitu Posted Sunday at 11:57 AM Author Posted Sunday at 11:57 AM amixer doesn't show any controls on the first card (and so does alsamixer) - amixer -c 0 shows nothing, while amixer -c 1 has a lot of output, but I think it's just showing the controls for the rockchipes8388 audio card (the analog output, not the HDMI). 0 Quote
Dantes Posted Sunday at 12:14 PM Posted Sunday at 12:14 PM On what kernel version are you ? HDMI Audio was introduced in the Linux Kernel in 6.15-rc1 0 Quote
mitu Posted Sunday at 12:24 PM Author Posted Sunday at 12:24 PM The kernel version reported by armbianmonitor (see my first post) is 6.16.4-edge-rockchip64. 0 Quote
IBV Posted Sunday at 12:40 PM Posted Sunday at 12:40 PM What does "aplay -L" show ? How do you test the HDMI sound ? 0 Quote
mitu Posted Sunday at 12:45 PM Author Posted Sunday at 12:45 PM (edited) 4 minutes ago, IBV said: What does "aplay -L" show ? Here's the output, shows PCMs for both the HDMI and analog audio outputs: Quote null Discard all samples (playback) or generate zero samples (capture) lavrate Rate Converter Plugin Using Libav/FFmpeg Library samplerate Rate Converter Plugin Using Samplerate Library speexrate Rate Converter Plugin Using Speex Resampler jack JACK Audio Connection Kit oss Open Sound System pipewire PipeWire Sound Server pulse PulseAudio Sound Server speex Plugin using Speex DSP (resample, agc, denoise, echo, dereverb) upmix Plugin for channel upmix (4,6,8) vdownmix Plugin for channel downmix (stereo) with a simple spacialization default Default ALSA Output (currently PipeWire Media Server) hw:CARD=hdmi0,DEV=0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Direct hardware device without any conversions plughw:CARD=hdmi0,DEV=0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Hardware device with all software conversions sysdefault:CARD=hdmi0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Default Audio Device dmix:CARD=hdmi0,DEV=0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Direct sample mixing device usbstream:CARD=hdmi0 hdmi0 USB Stream Output hw:CARD=rockchipes8388,DEV=0 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Direct hardware device without any conversions plughw:CARD=rockchipes8388,DEV=0 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Hardware device with all software conversions sysdefault:CARD=rockchipes8388 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Default Audio Device dmix:CARD=rockchipes8388,DEV=0 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Direct sample mixing device usbstream:CARD=rockchipes8388 rockchip,es8388 USB Stream Output > How do you test the HDMI sound ? speaker-test or aplay (with a .wav file). Edited Sunday at 12:45 PM by mitu 0 Quote
IBV Posted Sunday at 12:50 PM Posted Sunday at 12:50 PM 1 minute ago, mitu said: speaker-test or aplay (with a .wav file). Sorry I mean Which kind of output device: TV, Monitor with build in speakers? If you try "aplay -D plughw:0,0 your_audio_file.wav", still no sound? 0 Quote
mitu Posted Sunday at 12:56 PM Author Posted Sunday at 12:56 PM 4 minutes ago, IBV said: 9 minutes ago, mitu said: Sorry I mean Which kind of output device: TV, Monitor with build in speakers? I have a HDMI monitor with speakers included. 4 minutes ago, IBV said: If you try "aplay -D plughw:0,0 your_audio_file.wav", still no sound? Yes. 0 Quote
IBV Posted Sunday at 01:02 PM Posted Sunday at 01:02 PM aplay -D plughw:0,0 -f S16_LE -r 48000 -c 2 your_audio_file.wav ? this will force a more common audio format (in case the monitor supports specific audio formats. If not working, no idea, hw detection looks ok. 0 Quote
mitu Posted Sunday at 01:07 PM Author Posted Sunday at 01:07 PM 4 minutes ago, IBV said: aplay -D plughw:0,0 -f S16_LE -r 48000 -c 2 your_audio_file.wav ? It doesn't seem to make a difference: Quote aplay -D plughw:0,0 -f S16_LE -r 48000 -c 2 Alesis-Fusion-Nylon-String-Guitar-C4.wav Playing WAVE 'Alesis-Fusion-Nylon-String-Guitar-C4.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo 0 Quote
IBV Posted 14 hours ago Posted 14 hours ago Do you get sound (HDMI) through your monitor speakers with the official vendor image? 0 Quote
mitu Posted 6 hours ago Author Posted 6 hours ago 8 hours ago, IBV said: Do you get sound (HDMI) through your monitor speakers with the official vendor image? I haven't tried the vendor image, but I have another SBC (RasPi4) that can succesfully output audio through the monitor speakers, so the monitor is ok. I could re-test the HDMI cable I guess, but since the video signal is ok I don't expect the audio to have issues. 0 Quote
IBV Posted 1 hour ago Posted 1 hour ago I suggest to confirm first that it works with the vendor image, just in case. If you boot the vendor image you could also gather some info, like aplay -L, etc. 0 Quote
