bobby3605 Posted September 10, 2025 Posted September 10, 2025 As other people have noted, there are issues trying to connect the CB1 to wifi after the first boot. I believe I've narrowed down the cause, but I'm not sure about the right way to fix it permanently. The issue I was experiencing is as follows: 1. Flash latest armbian minimal to sd card 2. Plug into CB1 and turn it on 3. Go through first boot setup and connect to wifi normally 4. Reboot CB1 5. CB1 no longer connects to wifi, wpa_cli says 'CTRL_EVENT_SCAN_FAILED' A temporary solution I found is to mask systemd-networkd, then manually unmask systemd-networkd and start it after booting. This suggests that the problem is that systemd-networkd tries to talk to the RTL8189 before it's ready, and that puts the chip into a bad state. The wireless connection works on the first boot, because the CB1 doesn't try to configure the chip until after it has booted up. If I only mask netplan-wpa-wlan0 (instead of masking networkd) and try to manually bring it up, then I get an empty scan result, rather than CTRL_EVENT_SCAN_FAILED. Is there a way to make systemd-networkd wait until after the driver has loaded before trying to configure the chip? The easiest temporary solution is probably to just add a delay before systemd-networkd starts. 0 Quote
bobby3605 Posted September 10, 2025 Author Posted September 10, 2025 For anyone interested in solving this temporarily, doing the following steps worked for me: sudo systemctl edit systemd-networkd ### Editing /etc/systemd/system/systemd-networkd.service.d/override.conf ### Anything between here and the comment below will become the new contents of the file [Service] ExecStartPre=/bin/sleep 5 ### Lines below this comment will be discarded sudo systemctl daemon-reexec sudo reboot 0 Quote
bundle Posted October 2, 2025 Posted October 2, 2025 Having the same issue however your solution doesn't seem to work for me for whatever reason. 0 Quote
anttix Posted October 3, 2025 Posted October 3, 2025 Experiencing the same issue, wifi fails to activate for about 4 out of 5 boots or so. 0 Quote
JohnTheCoolingFan Posted October 4, 2025 Posted October 4, 2025 No idea what causes this, will need to check on my device 0 Quote
Eatocee Posted October 4, 2025 Posted October 4, 2025 Hello, I was experiencing the same problem, and both of these workarounds did not work for me. However! Even though I am quite inexperienced when it comes to these kinds of problems, I managed to get it working reliably again with the help of my favourite LLM-slop-machine. Made the file: /etc/wpa_supplicant/wpa_supplicant-wlan0.conf ctrl_interface=/run/wpa_supplicant update_config=1 network={ ssid="YourSSID" psk="YourPassword" key_mgmt=WPA-PSK } ran these commands: sudo systemctl enable wpa_supplicant@wlan0.service sudo systemctl restart wpa_supplicant@wlan0.service sudo systemctl restart systemd-networkd then this one: sudo wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant-wlan0.conf -D nl80211 -d got this error from that: nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) then these commands: sudo systemctl stop wpa_supplicant@wlan0.service sudo systemctl stop wpa_supplicant.service sudo pkill -9 wpa_supplicant || true sudo rm -f /run/wpa_supplicant/* then started the service again and watching logs: sudo systemctl start wpa_supplicant@wlan0.service sudo journalctl -u wpa_supplicant@wlan0 -f From there i saw "wlan0: Associated with" and "wlan0: WPA: Key negotiation completed" however when running ip addr show wlan0 It only showed me 2 lines and no IP. Checked that I was connected to the correct access point with: iw dev wlan0 link I installed dhcpcd5 to assign an IP. sudo apt install dhcpcd5 assigning IP and checking if it was assigned: sudo dhcpcd wlan0 ip addr show wlan0 Then also after restarting everything worked well for me. From the wpa error, it looks like there were 2 instances? I am not sure. I would love to hear someone elses opinion on this, since I am not 100% sure what exactly I did, but it worked. I hope this helps someone! 0 Quote
anttix Posted October 4, 2025 Posted October 4, 2025 (edited) Couple of data points that may be helpful. Platform: BTT PI v1.2 D/C 2023.11.8 with the U2C CAN board Distro: Armbian 25.8.1 Bookworm Kernel: 6.12.43-current-sunxi64 Overlays: spidev0_0 1. Adding a sleep 5 hack did not work for me, however what does *seem* to work is inserting the following line to /etc/netplan/30-wifis-dhcp.yaml activation-mode: manual WiFi was still activated (which may be another bug) for at least 3 cold boots in a row (didn't have time to test more thoroughly). Here's a pastebin link from right after one such boot - https://paste.armbian.com/umijapukiy 2. The error from wpa_supplicant is CTRL-EVENT-SCAN-FAILED ret=-1 retry=1 .Same error code (-1) is also reported when attempting a manual scan pi@jubilee:~$ sudo iw wlan1 scan command failed: Operation not permitted (-1) 3. Broken state of the WiFi driver seems to be correlated with mmc errors in dmesg [ 11.490708] sunxi-mmc 4021000.mmc: data error, sending stop command [ 11.490745] sunxi-mmc 4021000.mmc: send stop command failed [ 11.490856] sunxi-mmc 4021000.mmc: data error, sending stop command [ 11.490880] sunxi-mmc 4021000.mmc: send stop command failed [ 11.491071] sunxi-mmc 4021000.mmc: data error, sending stop command [ 11.491098] sunxi-mmc 4021000.mmc: send stop command failed [ 11.491224] sunxi-mmc 4021000.mmc: data error, sending stop command [ 11.491248] sunxi-mmc 4021000.mmc: send stop command failed These are not present if wifi was activated successfully. Here's a pastebin link from right after such boot - https://paste.armbian.com/xovixuniti EDIT: Ran armbianmonitor -c overnight and the SD card seems fine The results from testing /dev/mmcblk0p2 (ext4): Data OK: 111.37 GB (233561400 sectors) Data LOST: 0.00 Byte (0 sectors) Average writing speed: 18.41 MB/s Average reading speed: 22.74 MB/s ... Health summary: OK 3. Reloading the kernel driver (8189fs) when it is already in a broken state is very slow and provokes a slew of mmc errors $ sudo /sbin/rmmod 8189fs pi@jubilee:~$ time sudo /sbin/modprobe 8189fs real 2m15.835s user 0m0.008s sys 0m0.048s $ dmesg .... [ 673.262192] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.262286] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.262379] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.262471] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.262563] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.262656] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.262716] ====>_BlockWrite 101 i:0 [ 673.262742] ====>_WriteFW 230 [ 673.263001] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.263088] sunxi-mmc 4021000.mmc: data error, sending stop command [ 673.263141] ====>_BlockWrite 101 i:0 [ 673.263162] ====>_WriteFW 230 Again the same problem is not present if WiFi was activated successfully after boot: Shutting down the interface and reloading the driver works just fine. Please let me know if there's anything else I can collect that can help to track this down. Given this is a fresh install and has no personal data in it yet, I can share my SD card image if that would be helpful. Edited October 5, 2025 by anttix 0 Quote
anttix Posted October 5, 2025 Posted October 5, 2025 (edited) Small update. The hack below seems to work as well. $ sudo systemctl edit armbian-hardware-optimize.service Add the following content between comments [Unit] Before=basic.target systemd-networkd.service netplan-wpa-wlan1.service Please note that armbian-hardware-optimize was picked at random to force anything that touches wlan1 to wait until slightly later in the boot process. No tests were done to determine at what exact point in the boot process wlan is "safe" to interact with. Edited October 5, 2025 by anttix 0 Quote
JohnTheCoolingFan Posted October 8, 2025 Posted October 8, 2025 I am unable to reproduce this on BigTreeTech Pi (v1.2). Set wifi up using netplan via NetworkManager. Wifi connects after a reboot, same if I poweroff the device, disconnect power and then connect back up. 0 Quote
anttix Posted October 8, 2025 Posted October 8, 2025 (edited) @JohnTheCoolingFan what image are you using? I can reproduce the issue consistently with Armbian_25.8.1_Bigtreetech-cb1_bookworm_current_6.12.35_minimal.img . This is the Minimal / IOT image one can grab from https://www.armbian.com/bigtreetech-cb1/ . Interestingly enough, the Minimal / IOT image does not use NetworkManager, it's configured with systemd-networkd backend (or "renderer" as they call it) for netplan. Perhaps this is the key difference: I saw a comment on a topic below stating that MainsailOS has added CB1 Trixie image which is forced to NetworkManager and it's claimed to be stable. Edited October 8, 2025 by anttix 0 Quote
JohnTheCoolingFan Posted October 9, 2025 Posted October 9, 2025 Yep, looks like it's about the netplan renderer. I've tried the actual image instead of the one I built locally and even just a reboot is able to reproduce the issue. The main difference is that on the image I built networking was via NetworkManager by default, while the image on the website uses systemd-networkd. 1 Quote
anttix Posted October 9, 2025 Posted October 9, 2025 @JohnTheCoolingFan I tested a Debian Trixie image from the website ( Armbian_25.8.1_Bigtreetech-cb1_trixie_current_6.12.35_minimal.img.xz ) and it seems to be stable even with the default configuration that uses systemd-networkd. 0 Quote
anttix Posted October 12, 2025 Posted October 12, 2025 I can confirm that switching to network-manager seems to make the Bookworm image more stable on my hardware. @bobby3605 @bundle @Eatocee can you confirm if one of the two options below work for you as well. Use Debian Trixie image instead of Bookworm. These can be found by scrolling a bit further down on the official download page at https://www.armbian.com/bigtreetech-cb1/ OR switch to NetworkManager sudo apt install network-manager -y Change renderer from networkd to NetworkManager in /etc/netplan/10-dhcp-all-interfaces.yaml --- /etc/netplan/10-dhcp-all-interfaces.yaml.orig 2025-10-12 20:53:08.558759013 +0300 +++ /etc/netplan/10-dhcp-all-interfaces.yaml 2025-10-12 20:53:28.826717724 +0300 @@ -6,7 +6,7 @@ network: version: 2 - renderer: networkd + renderer: NetworkManager ethernets: all-eth-interfaces: match: Thank you! 1 Quote
Martin Emrich Posted November 9, 2025 Posted November 9, 2025 Same/similar issue. Armbian Bookworm v25.8.1 on BTT Pi. wlan0/wlan1 devices are visible, but after first reboot, do not connect anymore. Even after stopping any networking-related services/processes, "iw wlan0 scan" just returns "device or resource busy". Changing the netplan renderer to network-manager as recommended did not work for me either. I also experienced the sunxi64-mmc kernel error messages when trying to reload the rt8189fs module. After switching kernel from 6.12.47-current to 6.16.8-edge, WLAN worked right away. But in exchange the wired eth0 device is now gone completely... you can't have it all (Maybe related to this?) 0 Quote
DaveTheBuskerUK Posted November 19, 2025 Posted November 19, 2025 (edited) This issues has had me sticking with the old BTT images for ages, then I found a different issue with those so was forced to come back to try again with Armbian. After going down many rabbit holes a friend said just install KlipperScreen earlier than you normally would when running up a Klipper install, that will pull in network manager. It was so simple for my use case I hadn't even considered it. Worked a treat, I could set up the wifi on the touchscreen and it survived reboots. I then found a slow down in the boot process because networkd was still waiting for a connection, a solution to that wasn't as hard to find I ran these two commands in the terminal and now it doesn't slow anything down during boot up. I have no idea if this is the correct way but I'll post it in case it helps anyone else following the same breadcrumbs I've been chasing. sudo systemctl disable systemd-networkd-wait-online.service sudo systemctl mask systemd-networkd-wait-online.service Edited November 19, 2025 by DaveTheBuskerUK 0 Quote
Martin Emrich Posted November 19, 2025 Posted November 19, 2025 Yes, I removed that as well quite quickly. Now the printer is ready in 30s after power-on. 0 Quote
DaveTheBuskerUK Posted November 20, 2025 Posted November 20, 2025 On 10/12/2025 at 7:05 PM, anttix said: OR switch to NetworkManager Apologies, I somehow missed this comment until after I'd posted mine Would have saved me a fair bit of searching had I read it 0 Quote
DaveTheBuskerUK Posted November 20, 2025 Posted November 20, 2025 Quick update, having sorted this out I went on to install a CanBus device only to have to enable it again, so I'm back to the same delay 0 Quote
legitsu Posted January 27 Posted January 27 so whats the status on this issue is it resolved by running the rolling forky release and using network manager ? 0 Quote
Raj Srikrishnan Posted February 26 Posted February 26 I'm on the current Debian Trixie build Armbian 26.2.1 Minimal / IOT, and Wifi is not working. What are the current suggestions to get it back up on BigTreeTech CB1? 0 Quote
Raj Srikrishnan Posted March 16 Posted March 16 After some experimentation, I realized that the full xfce images are working fine, likely because NetworkManager is built in. The minimal CLI images, even after switching to NetworkManager per the instructions here, never worked for me to retain Wifi after a reboot. I'm going through the process of removing the XFCE desktop from my install as CPU utilization in Klipper is very high otherwise. 0 Quote
