invalid overlay_prefix rk35xx
Go to solution Solved by Werner,
Hi everyone, I need to enable the csi camera and i2c port on my zero3 development board. When I click on the management overlay, an error occurs. Is there any solution?
This is the default configuration:
verbosity=1
bootlogo=false
console=both
extraargs=cma=256M
overlay_prefix=rk35xx
fdtfile=rockchip/rk3566-radxa-zero3.dtb
rootdev=UUID=526007c3-3a0f-451d-a7a7-6d896d15f910
rootfstype=ext4
  • Solution
Yes. This is an example of a rk3588 based board of mine:
overlay_prefix=rockchip-rk3588
overlays=panthor-gpu opp-oc-24ghz
The overlay names come from /boot/dtb/*/
find an overlay matching your soc and needs and enable by putting its name to overlays=. Then reboot. Having a serial console to read uboot logs can show if it has been loaded properly or in case it did not why.
Would you mind sharing the steps you took to enable csi camera support? I'm trying to enabled the CSI port on the Radxa Zero 3W for the TC358743, but I have been unable to make progress.
I'm currently using a Geekom X1301 HAT for the CSI to HDMI adapter which uses the TC358743, but it never shows up.
What I have tried so far is extracting the .dtbo files from the official radxa image. Adding them to
/boot/overlay-user
and enabling the two tc358743 overlays
radxa-zero3-tc358743.dtbo
radxa-zero3-tc358743-audio.dtbo
and finally enabling them in armbianEnv.txt with this line
user_overlays=radxa-zero3-tc358743,radxa-zero3-tc358743-audio
Is there anything that I missed?
The CSI port still doesn't seem to be receiving any power, as the X1301's power LED has been off the whole time.
After checking uboot logs, it shows that it fails to load the dtbo files, although I'm not sure what the error is.
** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with script
Boot script loaded from mmc 1:1
308 bytes read in 2 ms (150.4 KiB/s)
14207910 bytes read in 1182 ms (11.5 MiB/s)
48779776 bytes read in 4043 ms (11.5 MiB/s)
161122 bytes read in 26 ms (5.9 MiB/s)
Working FDT set to a100000
Failed to load '/overlay-user/radxa-zero3-tc358743,radxa-zero3-tc358743-audio.dtbo'
Trying kaslrseed command... Info: Unknown command can be safely ignored sincelrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
Moving Image from 0x20840000
## Loading init Ramdisk from Legacy Image at 0a200000 ...
   Image :   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    14207846 Bytes = 13.5 MiB
   Load Address: 00000int:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 0a100000
   Booting using the fdt blob at 0xa100000
Working FDT set to a100000   Loading Ramdisk to 7c133000, end 7cebfb66 ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0)
   Loading Device Tree to 000000007c0a3000, end 000000007c132fff .OK
Working FDT set to 7c0a3000
Okay I found out that the previous error was mainly user error, due to an invalid user_overlays=, however I am facing a new issue and it still doesn't seem to work
This is the new error
3772 bytes read in 4 ms (920.9 KiB/s)
Applying user provided DT overlay radxa-zer5028 bytes read in 8 ms (613.3 KiB/s)
Applying user provided DT overlay radxa-zero3-tc358743-audio.dtbo
Trying kaslrseed command... Info: Unknown command can be safely ignored since ot apply to all boards.
Moving Image from 0x2080000 to 0x220## Loading init Ramdisk from Legacy Image at 0a200000 ...
   Imagpe:   AArch64 Linux RAMDisk Image (gzip compressed)
   Loadoint:  00000000
Working FDT set    Loading Ramdisk to 7c133000, end 7cebfb66 ... OK
I'm not sure why it is saying it is loading radxa-zer5028 when that is clearly not what is listed in armbianEnv.txt
This is what is in armbianEnv
user_overlays=radxa-zero3-tc358743 radxa-zero3-tc358743-audio
