JIN PRO Posted September 12 Posted September 12 Hi everyone, I need to enable the csi camera and i2c port on my zero3 development board. When I click on the management overlay, an error occurs. Is there any solution? 0 Quote
Werner Posted September 12 Posted September 12 Overlays can be added manually as well. Check /boot/armbianEnv.txt 0 Quote
JIN PRO Posted September 13 Author Posted September 13 This is the default configuration: verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rk35xx fdtfile=rockchip/rk3566-radxa-zero3.dtb rootdev=UUID=526007c3-3a0f-451d-a7a7-6d896d15f910 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 0 Quote
Solution Werner Posted September 13 Solution Posted September 13 Yes. This is an example of a rk3588 based board of mine: overlay_prefix=rockchip-rk3588 overlays=panthor-gpu opp-oc-24ghz The overlay names come from /boot/dtb/*/ find an overlay matching your soc and needs and enable by putting its name to overlays=. Then reboot. Having a serial console to read uboot logs can show if it has been loaded properly or in case it did not why. 0 Quote
JIN PRO Posted September 16 Author Posted September 16 It works, but I found that the i2c dtbo file I needed was not in the armbian repository, so I manually extracted it from the radxa official image. 0 Quote
Werner Posted September 16 Posted September 16 Feel free to pr any missing overlay here: https://github.com/armbian/linux-rockchip 0 Quote
opi-5-plus-user Posted October 26 Posted October 26 Would you mind sharing the steps you took to enable csi camera support? I'm trying to enabled the CSI port on the Radxa Zero 3W for the TC358743, but I have been unable to make progress. I'm currently using a Geekom X1301 HAT for the CSI to HDMI adapter which uses the TC358743, but it never shows up. What I have tried so far is extracting the .dtbo files from the official radxa image. Adding them to /boot/overlay-user and enabling the two tc358743 overlays radxa-zero3-tc358743.dtbo radxa-zero3-tc358743-audio.dtbo and finally enabling them in armbianEnv.txt with this line user_overlays=radxa-zero3-tc358743,radxa-zero3-tc358743-audio Is there anything that I missed? The CSI port still doesn't seem to be receiving any power, as the X1301's power LED has been off the whole time. 0 Quote
Werner Posted October 26 Posted October 26 Did you make sure they're actually loaded? Like by checking uboot boot logs via serial console? 0 Quote
opi-5-plus-user Posted October 26 Posted October 26 Yes. I check the dmesg logs and they aren't loading which is probably why it doesn't work, but I have tried a variety of methods to try and get them to load, however nothing worked. 0 Quote
opi-5-plus-user Posted October 26 Posted October 26 After checking uboot logs, it shows that it fails to load the dtbo files, although I'm not sure what the error is. ** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with script Boot script loaded from mmc 1:1 308 bytes read in 2 ms (150.4 KiB/s) 14207910 bytes read in 1182 ms (11.5 MiB/s) 48779776 bytes read in 4043 ms (11.5 MiB/s) 161122 bytes read in 26 ms (5.9 MiB/s) Working FDT set to a100000 Failed to load '/overlay-user/radxa-zero3-tc358743,radxa-zero3-tc358743-audio.dtbo' Trying kaslrseed command... Info: Unknown command can be safely ignored sincelrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x20840000 ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image : AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14207846 Bytes = 13.5 MiB Load Address: 00000int: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0a100000 Booting using the fdt blob at 0xa100000 Working FDT set to a100000 Loading Ramdisk to 7c133000, end 7cebfb66 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) Loading Device Tree to 000000007c0a3000, end 000000007c132fff .OK Working FDT set to 7c0a3000 0 Quote
opi-5-plus-user Posted October 26 Posted October 26 Okay I found out that the previous error was mainly user error, due to an invalid user_overlays=, however I am facing a new issue and it still doesn't seem to work This is the new error Boot script loaded from mmc 1:1 308 bytes read in 2 ms (150.4 KiB/s) 14207910 bytes read in 1182 ms (11.5 MiB/s) 48779776 bytes read in 4043 ms (11.5 MiB/s) 161122 bytes read in 26 ms (5.9 MiB/s) Working FDT set to a100000 3772 bytes read in 4 ms (920.9 KiB/s) Applying user provided DT overlay radxa-zer5028 bytes read in 8 ms (613.3 KiB/s) Applying user provided DT overlay radxa-zero3-tc358743-audio.dtbo Trying kaslrseed command... Info: Unknown command can be safely ignored since ot apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x220## Loading init Ramdisk from Legacy Image at 0a200000 ... Imagpe: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14207846 Bytes = 13.5 MiB Loadoint: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0a100000 Booting using the fdt blob at 0xa100000 Working FDT set Loading Ramdisk to 7c133000, end 7cebfb66 ... OK I'm not sure why it is saying it is loading radxa-zer5028 when that is clearly not what is listed in armbianEnv.txt This is what is in armbianEnv user_overlays=radxa-zero3-tc358743 radxa-zero3-tc358743-audio 0 Quote
opi-5-plus-user Posted October 26 Posted October 26 Update: It works now, however the power LED doesn't seem to light up, but the video card is detected in /dev 0 Quote
