KhanhDTP Posted Saturday at 03:03 PM Author Posted Saturday at 03:03 PM Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.5.5 ~60fps@720p Left 4 Dead 2 0 Quote
KhanhDTP Posted Saturday at 03:06 PM Author Posted Saturday at 03:06 PM Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.5.5 >=60fps@720p Super Robot Wars V 0 Quote
晓飞丁 Posted 18 hours ago Posted 18 hours ago Have you guys ever try FEX-emu instead of box64? I heard FEX is 10%~20% faster than box64 0 Quote
NicoD Posted 17 hours ago Posted 17 hours ago 52 minutes ago, 晓飞丁 said: Have you guys ever try FEX-emu instead of box64? I heard FEX is 10%~20% faster than box64 I tried FEX-emu, but on our devices it's slower. It is optimised for snapdragon while box64 is more optimised for the lower-end SBC ARM-SOC. Here a video I once made about it. Things have changed a lot, fex-emu has matured at lot in this time. I didn't know it was build for steam back then so didn't test that. Also have no steam games that would run. 1 Quote
KhanhDTP Posted 16 hours ago Author Posted 16 hours ago 2 hours ago, 晓飞丁 said: Have you guys ever try FEX-emu instead of box64? I heard FEX is 10%~20% faster than box64 I am using hangover-10.18, which is Fex-Emu 2510. https://github.com/AndreRH/hangover/releases/tag/hangover-10.18 I didn't benchmark. But I think rn, the main bottleneck is the GPU (PanVk driver is now only ~60% performance of the libMali driver). 0 Quote
KhanhDTP Posted 16 hours ago Author Posted 16 hours ago 1 hour ago, NicoD said: Also have no steam games that would run. Steam games are working now, I tested some games a week ago. But the steam client alone took ~5gb. So, I would not recomend unless you have a 16gb board. 0 Quote
晓飞丁 Posted 13 hours ago Posted 13 hours ago 3 hours ago, KhanhDTP said: I didn't benchmark. But I think rn, the main bottleneck is the GPU (PanVk driver is now only ~60% performance of the libMali driver). Sorry I am an amateur on rk3588. If libMali have better performance. But why most of you are using PanVk? 2 hours ago, KhanhDTP said: Steam games are working now, I tested some games a week ago. But the steam client alone took ~5gb. So, I would not recomend unless you have a 16gb board. Without steam it is meanlingless, while we could only play games with no drm? 2 hours ago, KhanhDTP said: Steam games are working now, I tested some games a week ago. But the steam client alone took ~5gb. So, I would not recomend unless you have a 16gb board. I found a way to shrink the memory occupation by not starting the steamclientwebhelp. See the tips here :https://www.howtogeek.com/694531/how-to-reduce-steams-ram-usage-from-400-mb-to-60-mb/ 0 Quote
KhanhDTP Posted 12 hours ago Author Posted 12 hours ago 1 hour ago, 晓飞丁 said: If libMali have better performance. But why most of you are using PanVk? Because the compatibility, I can't get the libMali driver to work with 32bit games (DXVK specifically). Also, although 64bit games work with the libMali, most of the games I have tested are black screen, or missing textures. 1 hour ago, 晓飞丁 said: I found a way to shrink the memory occupation by not starting the steamclientwebhelp. See the tips here :https://www.howtogeek.com/694531/how-to-reduce-steams-ram-usage-from-400-mb-to-60-mb/ Thanks for the sharing, I will try it later. 0 Quote
KhanhDTP Posted 12 hours ago Author Posted 12 hours ago Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-proton-10.25 (https://github.com/GloriousEggroll/proton-ge-custom) + DXVK-stripped v1.6.1 ~60fps@1080p Half Life 2 0 Quote
KhanhDTP Posted 49 minutes ago Author Posted 49 minutes ago 12 hours ago, 晓飞丁 said: I found a way to shrink the memory occupation by not starting the steamclientwebhelp. See the tips here :https://www.howtogeek.com/694531/how-to-reduce-steams-ram-usage-from-400-mb-to-60-mb/ Still the same 0 Quote
