Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115)
 + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco)
 + box64 3.9 (https://ryanfortner.github.io/box64-debs/)
 + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz)
+ DXVK-stripped v1.5.5
~60fps@720p
Left 4 Dead 2
>=60fps@720p
Super Robot Wars VSRWV-PanVk(3).thumb.jpg.b02188d87462171fa3a30e39b97397c7.jpgSRWV-PanVk(2).thumb.jpg.95b03112fd1f5cbc5cfda8dfc6435fee.jpgSRWV-PanVk.thumb.jpg.2376a5fdac1c357eb811ea4a7b0bf8cc.jpg
52 minutes ago, 晓飞丁 said:
Have you guys ever try FEX-emu instead of box64? I heard FEX is 10%~20% faster than box64
I tried FEX-emu, but on our devices it's slower. It is optimised for snapdragon while box64 is more optimised for the lower-end SBC ARM-SOC.
Here a video I once made about it. Things have changed a lot, fex-emu has matured at lot in this time. I didn't know it was build for steam back then so didn't test that. Also have no steam games that would run.
Steam games are working now, I tested some games a week ago. But the steam client alone took ~5gb. So, I would not recomend unless you have a 16gb board.
3 hours ago, KhanhDTP said:
I didn't benchmark. But I think rn, the main bottleneck is the GPU (PanVk driver is now only ~60% performance of the libMali driver).
Sorry I am an amateur on rk3588. If libMali have better performance. But why most of you are using PanVk?
Without steam it is meanlingless, while we could only play games with no drm?
I found a way to shrink the memory occupation by not starting the steamclientwebhelp. See the tips here :https://www.howtogeek.com/694531/how-to-reduce-steams-ram-usage-from-400-mb-to-60-mb/
Because the compatibility, I can't get the libMali driver to work with 32bit games (DXVK specifically). Also, although 64bit games work with the libMali, most of the games I have tested are black screen, or missing textures.
Thanks for the sharing, I will try it later.
Posted (edited)
I failed to get a working OpenGL with libmali. A more performant GLES may give a more performant desktop, but won't make most games working.
Since the community have been doing excellent work bringing rk3588 to mainline, it makes no sense to stick to a 5.x vendor kernel for a closed-source library with flaws, at least in my use case.
5 hours ago, 晓飞丁 said:
It's wierd that in native Windows environment. steamwebhelper will only cost about 500MB memroy
The FEX's developer has explained the reason why memory usage is high under arm64, and I think box64 may also have similar problems.
Edited by heyrict
+ DXVK-stripped v2.6.2
>=60fps@1080p
Cuphead
>=60fps@1080p
Blasphemous
>=60fps@1080p
Blasphemous 2
>=60fps@1080p
Shovel Knight Dig
+ DXVK-stripped v1.7.1
~60fps@1080p
Ori and the Blind Forest: Definitive Edition
Posted (edited)
+ FEX-Emu 2510
+ hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18)
+ Zink
30~60fps@720p
Quote
I tried all the DXVK(-stripped) possible for both dx9, dx10. Either crashes or black screen, or missing textures; only Zink works.
I also tried box64, but it's not working (crashed)
Crysis x64 (dx10)
Edited by KhanhDTP
Are you using X11 or wayland? I am not able to run wayland  while under X11 it is very slow
I am using X11 (XFCE), make sure you installed the driver.
How do you use proton/wine. I download the archieve file and after extraction, there are bin & lib files,  how can I use them ? set some environment variables?
I've tested niri, hyprland, sway and i3, all of them should work if properly configured.
+ DXVK-stripped v1.6.1
~60fps@720p
Left 4 Dead
Posted (edited)
+ GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom)
+ Zink (openGL)
>=60fps@1080p
Tomb Raider Remastered IV - V - VI
Edited by KhanhDTP
