Posted (edited)
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115)
+ PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco)
+ Box64 arm64 v0.4.1 652da4fbc (https://ryanfortner.github.io/box64-debs/)
+ wine-10.20-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.20)
+ dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases)
+ DXVK-stripped v1.10.3
~40fps@720p (low shadow setting, high texture, no AA)
box64 environment variables:
Quote
export BOX64_DYNAREC_BIGBLOCK=3
export BOX64_DYNAREC_FORWARD=512
export BOX64_DYNAREC_CALLRET=1
Resident Evil - Revelations
Edited by KhanhDTP
Posted (edited)
+ proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz)
+ DXVK-stripped v1.7.1
~60fps@1080p (max settings, static lightning, no AA)
Quote
S.T.A.L.K.E.R. Shadow of Chernobyl
Edited by KhanhDTP
Posted (edited)
+ DXVK-stripped v1.6.1
30~60fps@720p (low settings, high texture, no AA)
Quote
Black Mesa
Edited by KhanhDTP
Posted (edited)
+ proton-10.0-4-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-4/wine-proton-10.0-4-amd64-wow64.tar.xz)
~50fps@720p (low settings)
Quote
export BOX64_DYNAREC_SAFEFLAGS=2 # <-- fix boot
Injustice Gods Among Us Ultimate Edition
Edited by KhanhDTP
+ Box64 arm64 v0.4.1 1aed7e028 (https://ryanfortner.github.io/box64-debs/)
+ ge-proton10-29 (https://github.com/GloriousEggroll/proton-ge-custom/releases/tag/GE-Proton10-29)
~30fps@720p (ultra settings)
Quote
export BOX64_DYNAREC_SAFEFLAGS=2 # <-- fix boot crash
Spider-Man Shattered Dimensions
+ DXVK-stripped v2.1
40~60fps@1080p (max settings, no AA)
Quote
Grand Theft Auto San Andreas
@KhanhDTPHi. First off, great job with all these games.
Would it be possible to test FarmingSimulator 17 please?
I got the game working, but the image is offset a lot. Mouse also.
I needed to set wine to win7 and use the x86 FarmingSimulator2017.exe in the x86 folder.
I've got no clue how to fix this issue, maybe you have more tips and tricks.
In windowed mode I can see everything, but mouse goes out of the window and stops working. Otherwise it looks playable if it was outputting correctly.
Cheers, NicoD
@NicoD How was your setup? I can't get the game up and running. The x86/FarmingSimulatorGame2017.exe won't detect the GPU and quit. The x64/FarmingSimulatorGame2017.exe boots but will crash immediately after the splash screen with this error
Quote
01f8:err:seh:call_seh_handlers invalid frame 00000000041F9394 (00000000055B2000-00000000056B0000)
01f8:err:seh:NtRaiseException Exception frame is not in stack limits => unable to dispatch exception.
Posted (edited)
I understand now, because the x86/FarmingSimulatorGame2017.exe file forces the use of the OpenGL renderer.
Both full-screen and windowed modes are working normally for me.
+ OpenGL (Panfrost)
Edited by KhanhDTP
Awesome. Let me try that. Had to reinstall my SBC cause I done a stupid thing, removed my boot partition. :) Wanted to format another sd-card of the same size and didn't look well enough.
Installing wine and all the others now, will try with all you've mentioned. Big thank you, I'm in the hospital with little to do, and I miss Farming Simulator to make the time pass quickly.
Thank you for the great work.
Could you please explain how to install wine-proton? I've been out of it for a while and don't remember a thing.
I'll add it to armbian-gaming when I can make it work. And make a video about the process.
@NicoD I download and extract the Wine-Proton prebuilt binaries, then let Box64 do the rest.
This is the script I used (You might want to change the directories)
Quote
#!/bin/bash
export WINE_LARGE_ADDRESS_AWARE=1; export PROTON_FORCE_LARGE_ADDRESS_AWARE=1
export PROTON_USE_WOW64=1; export PROTON_USE_WINED3D=1
_DNVME="/mnt/nvme-data/Download/x86_64/Games.wine"
_GEXE="FarmingSimulator2017Game.exe"; _GDIR="$_DNVME/Farming Simulator 17/x86/"; _GARGS="-restart"
_WINEROOT=/mnt/nvme-data/Download/x86_64/wine
_WINEVER=wine-proton-10.04-amd64-wow64
_WINEDIR=$_WINEROOT/$_WINEVER
export WINE=$_WINEDIR/bin/wine
export WINEPREFIX=~/_$_WINEVER
export BOX64_MMAP32=1
export BOX64_RESERVE_HIGH=1
export BOX64_PREFER_EMULATED=1
export WINEDEBUG=fixme-all
# export WINEDEBUG=-all; export BOX64_LOG=0
##### HUD
export GALLIUM_HUD="simple,cpu,fps"
cd "$_GDIR"; $WINE "$_GDIR$_GEXE" $_GARGS # > "$_GDIR/_0.run.log" 2>&1
Posted (edited)
+ Box64 arm64 v0.4.1 ed9827920 (https://ryanfortner.github.io/box64-debs/)
~40fps@720p (low settings)
Quote
Dead Space
Edited by KhanhDTP
50~60fps@720p (no AA, no AO, high Shadows)
Quote
Neon White
(GE-proton is more likely to be segment fault-proof than other wine-proton versions)
+ DXVK-stripped v2.5.3
30~40fps@720p (low settings)
(Some minor flickering bug, but still playable)
Quote
export BOX64_DYNAREC_CALLRET=0
export BOX64_DYNAREC_SAFEFLAGS=2 # fix boot crash
export BOX64_DYNAREC_STRONGMEM=1 # likely random crash proof
DmC - Devil May Cry
+ DXVK-stripped v2.4.1
40~60fps@720p (medium settings, no AA)
Quote
Fallout 3
~40fps@720p (medium settings, no AA)
Quote
Fallout New Vegas
>=60fps@1080p (medium/high settings)
Quote
export BOX64_DYNAREC_FORWARD=1024
export BOX64_DYNAREC_SAFEFLAGS=0
export BOX64_DYNAREC_WEAKBARRIER=1
Hollow Knight
Posted (edited)
Quote
DRAGON BALL XENOVERSE
Edited by KhanhDTP
Posted (edited)
30~40fps@720p (low settings, texture high)
Quote
RESIDENT EVIL 6
Edited by KhanhDTP
+ DXVK-stripped v2.7.1
~30fps@720p (high settings - the lowest settings in game)
Quote
Crysis 2 Maximum Edition
Posted (edited)
+ wine-11.3-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/11.3)
+ vkd3d-1.19 (wine's built-in)
~60fps@1024x576 (medium settings)
Quote
#!/bin/bash
export VKD3D_CAPS_OVERRIDE="feature_level=12.2"
_GEXE="Hades2.exe"; _GDIR="$_DNVME/Hades II/Ship/";
_WINEVER=wine-11.3-staging-tkg-amd64-wow64
_WINEDIR=${_WINEDIR:-$_WINEROOT/$_WINEVER}
export BOX64_MAXCPU=4
export BOX64_MMAP32=0
export BOX64_RESERVE_HIGH=0
##### Post processing effects
export VKBASALT_CONFIG_FILE=$_GDIR"vkBasalt.conf"; export ENABLE_VKBASALT=1
##### HUD
export MANGOHUD=1; export MANGOHUD_CONFIG="fps_limit=0,frame_timing=0,hud_compact,font_scale=0.75"
_WINECMD=$_GDIR$_GEXE; cd "$_GDIR"
gamemoderun taskset -c 4-7 $WINE "$_WINECMD" $_GARGS # > "$_GDIR/_0.run.log" 2>&1
Hades 2
Edited by KhanhDTP
