xiboliyadongtu Posted 4 hours ago Posted 4 hours ago Thank you very much for your suggestions; I have tested both of them using Protonge. I replaced the BdO launcher to rule out any issues with Chinese language support. Both suggestions caused the launcher to display an error window. Furthermore, I tested the solution involving DXVK using Wine 11.4 staging, but the launcher only displayed a black window; I have uploaded the logs and screenshots. Additionally, I downloaded the Windows version of VKcube, which displays the rotating cube correctly. Translated with DeepL.com (free version) log-protonge.txt log-wine11.4staging.txt 0 Quote
KhanhDTP Posted 4 hours ago Author Posted 4 hours ago @xiboliyadongtu as your ss, the launcher is 32-bits. So, can you copy x32/d3d11.dll, x32/dxgi.dll files to the game folder and try again? 0 Quote
xiboliyadongtu Posted 1 hour ago Posted 1 hour ago i delete the previous 64-bit version of DXVK, copy the 32-bit version DXVK, and tried to luanch the game; the game dispalyed a logo and then disappeared. Maybe it have crashed. log-dxvk log-zink 0 Quote
KhanhDTP Posted 49 minutes ago Author Posted 49 minutes ago @xiboliyadongtu Can this game be started without a launcher? Is there an executable file besides BlackDesertLauncher.exe (like BlackDesert.exe)? The BlackDesertLauncher.exe is definitely a 32-bit file. So, you might need to run it with GE-Proton10-32 in WoW64 mode. Delete the created GE-Proton10-32's prefix to make sure. Then start it again with envs Quote export PROTON_USE_WOW64=1 export PROTON_USE_WINED3D=1 export WINEDLLOVERRIDES="d3d11,dxgi=n,b" export DXVK_HUD="api,version,compiler,fps,scale=1" export DXVK_CONFIG="d3d11.maxFeatureLevel=12_1" If everything is right, you will see the Dxvk output log with something like below: Quote info: Game: BlackDesertLauncher.exe info: DXVK: v1.6.1 info: Built-in extension providers: info: Win32 WSI info: OpenVR warn: OpenVR: Failed to locate module info: Enabled instance extensions: info: VK_KHR_surface info: VK_KHR_win32_surface warn: D3D9: VK_FORMAT_D16_UNORM_S8_UINT -> VK_FORMAT_D24_UNORM_S8_UINT info: Mali-G610: ... 0 Quote
xiboliyadongtu Posted 32 minutes ago Posted 32 minutes ago This game cant start without the launcher, I will try these options 0 Quote
xiboliyadongtu Posted 15 minutes ago Posted 15 minutes ago i just delete the default file named umu-defalut. and i try to start the launcher, but it still crash. Did i got right things? log 0 Quote
xiboliyadongtu Posted 9 minutes ago Posted 9 minutes ago this game do have a file named blackdesert64.exe 0 Quote
