晓飞丁 Posted December 14, 2025 Posted December 14, 2025 1 hour ago, KhanhDTP said: + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom) + Zink (openGL) >=60fps@1080p How do you use Zink? 0 Quote
KhanhDTP Posted December 14, 2025 Author Posted December 14, 2025 (edited) 23 hours ago, 晓飞丁 said: How do you use Zink? Set var environments as below: export PAN_MESA_DEBUG=gl3 export MESA_GL_VERSION_OVERRIDE=4.3 export MESA_LOADER_DRIVER_OVERRIDE=zink export GALLIUM_DRIVER=zink export LIBGL_KOPPER_DRI2=true Edited December 15, 2025 by KhanhDTP 0 Quote
晓飞丁 Posted December 14, 2025 Posted December 14, 2025 8 hours ago, KhanhDTP said: + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom) + Zink (openGL) >=60fps@1080p I am trying to use Zink to play TomRaider , while comes out this error: [BOX64] Using emulated /home/xfding/tmp/wine-proton-10.0-3-amd64-wow64/lib/wine/x86_64-unix/winepulse.so [BOX64] Using native(wrapped) libpulse.so.0 [BOX64] Using emulated /home/xfding/tmp/wine-proton-10.0-3-amd64-wow64/lib/wine/x86_64-unix/winealsa.so [BOX64] Using native(wrapped) libasound.so.2 [BOX64] Using native(wrapped) libGL.so.1 WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance [BOX64] 15479|Ask to run at NULL, will segfault wine: Unhandled page fault on execute access to 0000000000000000 at address 0000000000000000 (thread 0024), starting debugger... [BOX64] winedbg detected, not launching it! 0024:err:seh:start_debugger Couldn't start debugger L"winedbg --auto 32 332" (731) Read the Wine Developers Guide on how to set up winedbg or another debugger Is "GE-proton" is a must to OpenEL games? 0 Quote
KhanhDTP Posted December 14, 2025 Author Posted December 14, 2025 3 hours ago, 晓飞丁 said: Is "GE-proton" is a must to OpenEL games? No, basically any wine/proton (wow64) will work! 3 hours ago, 晓飞丁 said: I am trying to use Zink to play TomRaider Btw, that version of the Tomb Raider! 0 Quote
晓飞丁 Posted December 14, 2025 Posted December 14, 2025 9 minutes ago, KhanhDTP said: Btw, that version of the Tomb Raider! It is Tomb Raider 1~3 remastered Gog version 0 Quote
KhanhDTP Posted December 15, 2025 Author Posted December 15, 2025 11 hours ago, 晓飞丁 said: It is Tomb Raider 1~3 remastered Gog version Have you tried other wine/proton versions? 0 Quote
晓飞丁 Posted December 15, 2025 Posted December 15, 2025 1 hour ago, KhanhDTP said: Have you tried other wine/proton versions? I just used wine-proton 10.0.3. While replace the wine to 11.0-rc1 to my previous proton environment, which is working fine on some games, such as VampireSuvivors, after installing Wine-mono, none game can be played. Comes out a dialog says that "Failed to initialize graphics, Make sure you have DirectX installed" 0 Quote
KhanhDTP Posted December 15, 2025 Author Posted December 15, 2025 1 hour ago, 晓飞丁 said: Comes out a dialog says that "Failed to initialize graphics, Make sure you have DirectX installed" (https://www.pcgamingwiki.com/wiki/Vampire_Survivors) Vampire_Survivors is a 64-bit / Direct3D 11.1 game. You may not be setting DXVK (stripped) properly. Set var environments as below: export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b" Download the DXVK (stripped) here: https://github.com/khanh-it/dxvk/releases/tag/releases (You may want to try to know which version works best for this game) Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file. If you're setting up the DXVK properly, you will see the output with something like the following: Quote info: Game: VampireSurvivors.exe info: DXVK: v1.6.1 info: Built-in extension providers: info: Win32 WSI info: OpenVR warn: OpenVR: Failed to locate module info: Enabled instance extensions: info: VK_KHR_surface info: VK_KHR_win32_surface warn: D3D9: VK_FORMAT_D16_UNORM_S8_UINT -> VK_FORMAT_D24_UNORM_S8_UINT info: Mali-G610: info: Driver: 26.0.0 info: Vulkan: 1.4.335 info: Memory Heap[0]: info: Size: 5945 MiB info: Flags: 0x1 info: Memory Type[0]: Property Flags = 0x7 info: Process set as DPI aware info: Device properties: info: Device name: : Mali-G610 info: Driver version : 26.0.0 info: Enabled device extensions: 0 Quote
晓飞丁 Posted December 15, 2025 Posted December 15, 2025 2 hours ago, KhanhDTP said: (https://www.pcgamingwiki.com/wiki/Vampire_Survivors) Vampire_Survivors is a 64-bit / Direct3D 11.1 game. You may not be setting DXVK (stripped) properly. Set var environments as below: export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b" Download the DXVK (stripped) here: https://github.com/khanh-it/dxvk/releases/tag/releases (You may want to try to know which version works best for this game) Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file. If you're setting up the DXVK properly, you will see the output with something like the following: Thank you so much! I will try it tonight! 1 Quote
晓飞丁 Posted December 15, 2025 Posted December 15, 2025 4 hours ago, KhanhDTP said: Set var environments as below: export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b" Download the DXVK (stripped) here: https://github.com/khanh-it/dxvk/releases/tag/releases (You may want to try to know which version works best for this game) Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file. If you're setting up the DXVK properly, you will see the output with something like the following: Everytime you change you wine version, should the $WINEPREFIX dir such as ~/.wine/driver_c should be deleted and install DVXK dll again? 0 Quote
KhanhDTP Posted December 15, 2025 Author Posted December 15, 2025 1 minute ago, 晓飞丁 said: Everytime you change you wine version, should the $WINEPREFIX dir such as ~/.wine/driver_c should be deleted and install DVXK dll again? You extract and copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file folder. So no need to change anything in $WINEPREFIX dir. 0 Quote
晓飞丁 Posted December 15, 2025 Posted December 15, 2025 Have you ever met the issue "lack of OpenAl32.dll". I try to run "isaac:rebirth" and come out cannot find "openAl32.dll", I got a copy of openAl32.dll from my windows laptop and put it into $WINEPREIX/windows/system32 or the game's executable file folder, cannot get the right result. 0 Quote
KhanhDTP Posted December 15, 2025 Author Posted December 15, 2025 2 minutes ago, 晓飞丁 said: Have you ever met the issue "lack of OpenAl32.dll" No You can try to set env: export BOX64_PREFER_EMULATED=1 0 Quote
晓飞丁 Posted December 15, 2025 Posted December 15, 2025 6 minutes ago, KhanhDTP said: export BOX64_PREFER_EMULATED=1 Thank you so much! 0 Quote
晓飞丁 Posted December 15, 2025 Posted December 15, 2025 On 12/14/2025 at 12:26 PM, KhanhDTP said: export PAN_MESA_DEBUG=gl3 export MESA_GL_VERSION_OVERRIDE=4.3 export MESA_LOADER_DRIVER_OVERRIDE=zink export GALLIUM_DRIVER=zink export LIBGL_KOPPER_DRI2=true After applying these settings, TomeRaider can be run perfectly now, Thank you ! 1 Quote
KhanhDTP Posted December 15, 2025 Author Posted December 15, 2025 (edited) Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14) + WineD3D / Zink (OpenGL) ~30fps@720p (this game is capped at 30fps) NARUTO SHIPPUDEN - Ultimate Ninja STORM 3 Full Burst HD Edited December 15, 2025 by KhanhDTP 0 Quote
晓飞丁 Posted December 16, 2025 Posted December 16, 2025 On 12/8/2025 at 11:46 PM, KhanhDTP said: Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-proton-10.25 (https://github.com/GloriousEggroll/proton-ge-custom) + DXVK-stripped v1.6.1 ~60fps@1080p How do you use GE-proton? I see no wine dir in the released tar.gz but a bunch of python script. When I try to run the "proton", comes out "Proton: No compat data path?" 0 Quote
KhanhDTP Posted December 16, 2025 Author Posted December 16, 2025 5 minutes ago, 晓飞丁 said: How do you use GE-proton? You have to use umu-launcher https://github.com/Open-Wine-Components/umu-launcher 0 Quote
晓飞丁 Posted December 16, 2025 Posted December 16, 2025 1 hour ago, KhanhDTP said: You have to use umu-launcher https://github.com/Open-Wine-Components/umu-launcher I am trying to use umu-launcher, using this cmd : umu-run "./VampireSuvivors.exe", the steamrt & wine did start up. However, it stucked in "g_proton.winserver_bin" and nothing happened. 0 Quote
KhanhDTP Posted December 16, 2025 Author Posted December 16, 2025 4 minutes ago, 晓飞丁 said: I am trying to use umu-launcher, using this cmd : umu-run "./VampireSuvivors.exe", the steamrt & wine did start up. However, it stucked in "g_proton.winserver_bin" and nothing happened. You should try other Kron4ek's Wine-Builds wine/proton versions. It's easier to set up! 0 Quote
晓飞丁 Posted December 16, 2025 Posted December 16, 2025 4 minutes ago, KhanhDTP said: You should try other Kron4ek's Wine-Builds wine/proton versions. It's easier to set up! Sorry I missed the "dxvk-stripped", Now it works fine! thank you so much! 1 Quote
KhanhDTP Posted December 16, 2025 Author Posted December 16, 2025 (edited) 25 minutes ago, 晓飞丁 said: Sorry I missed the "dxvk-stripped", Now it works fine! thank you so much! Do you mind sharing some screenshots + your settings ? Edited December 16, 2025 by KhanhDTP 0 Quote
晓飞丁 Posted December 16, 2025 Posted December 16, 2025 1 hour ago, KhanhDTP said: Do you mind sharing some screenshots + your settings Sure. However, I am in PRC, Google is blocked. I cannot login in on my SBC since I am using Google account to login. I have to use my laptop which has vpn. I will find a way this weekend. 0 Quote
晓飞丁 Posted December 16, 2025 Posted December 16, 2025 1 hour ago, KhanhDTP said: Do you mind sharing some screenshots + your settings ? I noticed that some games are using DXVK while some are using wined3d, what is the reason? It that a way that force every game using DXVK? 0 Quote
晓飞丁 Posted December 16, 2025 Posted December 16, 2025 3 hours ago, KhanhDTP said: Do you mind sharing some screenshots + your settings ? I've read your DXVK-stripped code on github. Looks like your code is far behind the original one. Is your code can match the release "stripped 2.7.1" libs you provide? Thanks you so much! 0 Quote
KhanhDTP Posted December 17, 2025 Author Posted December 17, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + FEX-Emu 2510 + hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18) + Dxvk 1.10.3 (stripped) 30~60fps@720p (mixed settings) Tomb Raider (2013) Definitive Edition 0 Quote
KhanhDTP Posted December 20, 2025 Author Posted December 20, 2025 Armbian 25.11.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14) + Dxvk 2.1 (stripped) ~60fps@1080p MiSide Full 0 Quote
KhanhDTP Posted December 20, 2025 Author Posted December 20, 2025 Armbian 25.11.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + FEX-Emu 2510 + hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18) + Dxvk 1.7.1 (stripped) ~60fps@1080p Dave The Diver 0 Quote
KhanhDTP Posted December 21, 2025 Author Posted December 21, 2025 Armbian 25.11.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14) + Dxvk 2.1 (stripped) ~24fps@720p Sleeping Dogs - Definitive Edition 0 Quote
晓飞丁 Posted December 22, 2025 Posted December 22, 2025 On 12/20/2025 at 11:52 PM, KhanhDTP said: + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + FEX-Emu 2510 + hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18) + Dxvk 1.7.1 (stripped) ~60fps@1080p I failed to run DaveTheDiver using these settings: PanVk-mesa 26.0 + wine-Proton-10.0.3 + Dxvk 2.7.1(stripped) the log shows: Unsupported ioctl 74080 Faking StorageDeviceProperty data Is FEX or DXVK 1.7.1 is a must ? 0 Quote
