Igor Posted November 4, 2017 Posted November 4, 2017 Available for: 4.13.10 cubox (Cubox-i, Hummingboards) 4.13.10 mvebu64 (Espressobin) 4.9.58 odroidxu4 (Odroid XU3/XU4) 4.13.10 rockchip (Tinkerboard, MiQi) 4.13.10 sunxi (All Allwinner 32bit boards) 4.13.10 sunxi64 (All Allwinner 64bit boards) https://dl.armbian.com/_misc/realtime-kernel Requirements: - Armbian OS. Ubuntu or Debian bases. - root credentials Download: *dtb and *image packages at a minimum and install them with dpkg -i *.deb ... If you want to stay on this kernel, freeze upgrades in armbian-config -> system -> freeze kernel upgrades. Remember that those kernels are bleeding edge, made from upstream sources and may have troubles. Consider them as is/experimental, without end-user support. If you want to build them - patches are present but .disabled and might not apply cleanly with more recent sources without adjustements. What is RT? 4
gahabana Posted November 24, 2017 Posted November 24, 2017 hi @Igor thank you for the tip ! Did go and download XU4 RT kernel .debs installed and at reboot did not get usual blue-light kernel heart-beat. Thought maybe something was wrong with my image (built using instructions) and i downloaded the one https://dl.armbian.com/odroidxu4/Ubuntu_xenial_next.7z burned, booted, all usual - added user, rebooted one more time and then installed realtime kernel. When i power it on afterwards - same issue - blue light changes every 10-15seconds from off to on (no heaertbeat). can not ping it. Is there a tested scenario where you did get RT kernel to work on that i could try to replicate please ? thanks so much !
Igor Posted November 24, 2017 Author Posted November 24, 2017 No, those are first testing build of RT kernel for XU4, not very well tested. I will try to look into this when possible.
gahabana Posted November 24, 2017 Posted November 24, 2017 On 11/24/2017 at 10:10 AM, Igor said: No, those are first testing build of RT kernel for XU4, not very well tested. I will try to look into this when possible. Expand Thanks Igor ! For what it is worth - i tried building it 2-3 weeks ago with then current RT-patch that is included in Armbian and yesterday with latest from rt-patches repository (for 4.9.61 kernel at https://www.kernel.org/pub/linux/kernel/projects/rt/4.9/patches-4.9.61-rt61.tar.gz ). Either one (self built/latest) behave the same ... if it helps thank you !
sevi_at Posted December 12, 2017 Posted December 12, 2017 hy Igor, thanks for your information. Yesterday I switched to a RT kernel according to your instructions. My Thinkerboard work as a LogitechMediaServer with more then one squeezelite instance, librespot, MPD, shairplay, etc. it works! however, one thing does not work anymore the playback of my line input. it overrides and emits a very damaged sound. this command worked fine with kernel 4.4.73-rockchip: arecord -f S16_LE -c2 -r44100 -d 0 -D plug:dsnoop01 | aplay -B 1 -D plug:LineIn01 I also tried csound but here I have the same problem. my Kernel version now: 4.13.10-rt3-rockchip ask for info what could be the problem here and how I can solve it. THX
