Stanislav Berghici Posted October 21, 2025 Posted October 21, 2025 (edited) Yesterday, Oct 20th, I installed armbian version "Minimal/IOT images with Armbian Linux v6.1" to the Orange PI 5 PRO and updated kernel using armbian-config to kernel 6.18 RC1(2 options were available 6.12 and 6.18 R1, note 6.12 did not work). Armbian works fine including vulkan support(I tested with swith emulator) with this kernel(6.18 rc1), but today option to update to any kernel is not available anymore. I'm getting warning "No other kernels available!" System is pretty stable with this version. stas@orangepi5pro:~$ uname -r 6.18.0-rc1-edge-rockchip64 stas@orangepi5pro:~$ vulkaninfo --summary ========== VULKANINFO ========== Vulkan Instance Version: 1.4.309 Instance Extensions: count = 24 ------------------------------- VK_EXT_acquire_drm_display : extension revision 1 VK_EXT_acquire_xlib_display : extension revision 1 VK_EXT_debug_report : extension revision 10 VK_EXT_debug_utils : extension revision 2 VK_EXT_direct_mode_display : extension revision 1 VK_EXT_display_surface_counter : extension revision 1 VK_EXT_headless_surface : extension revision 1 VK_EXT_surface_maintenance1 : extension revision 1 VK_EXT_swapchain_colorspace : extension revision 5 VK_KHR_device_group_creation : extension revision 1 VK_KHR_display : extension revision 23 VK_KHR_external_fence_capabilities : extension revision 1 VK_KHR_external_memory_capabilities : extension revision 1 VK_KHR_external_semaphore_capabilities : extension revision 1 VK_KHR_get_display_properties2 : extension revision 1 VK_KHR_get_physical_device_properties2 : extension revision 2 VK_KHR_get_surface_capabilities2 : extension revision 1 VK_KHR_portability_enumeration : extension revision 1 VK_KHR_surface : extension revision 25 VK_KHR_surface_protected_capabilities : extension revision 1 VK_KHR_wayland_surface : extension revision 6 VK_KHR_xcb_surface : extension revision 6 VK_KHR_xlib_surface : extension revision 6 VK_LUNARG_direct_driver_loading : extension revision 1 Instance Layers: count = 2 -------------------------- VK_LAYER_MESA_device_select Linux device selection layer 1.4.303 version 1 VK_LAYER_MESA_overlay Mesa Overlay layer 1.4.303 version 1 Devices: ======== GPU0: apiVersion = 1.1.305 driverVersion = 25.0.7 vendorID = 0x13b5 deviceID = 0xa8670000 deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU deviceName = Mali-G610 driverID = DRIVER_ID_MESA_PANVK driverName = panvk driverInfo = Mesa 25.0.7-2 conformanceVersion = 1.4.1.2 Edited October 21, 2025 by Stanislav Berghici add logs 0 Quote
Igor Posted October 22, 2025 Posted October 22, 2025 8 hours ago, Stanislav Berghici said: I'm getting warning "No other kernels available!" This kernel is available only when you change repository to beta.armbian.com , which provides daily builds. EDGE kernels comes as is - glad to hear it works, but beware it might also break down as kernel is changing rapidly. 0 Quote
