callegar Posted October 22 Posted October 22 Looks like the package in subject is not in the repos. However, there are other packages depending on it (explicitly indicating that the required version is >=25.8.2) so this prevents package updates. Interestingly, for the armhf target the package is available, so I suspect a build issue. Any clue? 0 Quote
Igor Posted October 22 Posted October 22 3 hours ago, callegar said: I suspect a build issue Correct. It's a problem of: https://github.com/armbian/os/blob/main/.github/workflows/complete-artifact-matrix-all-stable.yml and this configuration: https://github.com/armbian/os/blob/main/userpatches/targets-all-not-eos.yaml It is something to study 0 Quote
callegar Posted October 22 Author Posted October 22 Thanks for the quick confirmation! From your answer I guess it is an issue that is already under investigation. No need to open a dedicated issue on some tracker, right? 0 Quote
Igor Posted October 22 Posted October 22 3 hours ago, callegar said: that is already under investigation Only that its a known issue. In open source world it is normal to see magnitude more issues then its resolving capacity. I'll look into when possible - its high on 2do list. 3 hours ago, callegar said: No need to open a dedicated issue on some tracker, right? No need. 0 Quote
binkerd Posted November 8 Posted November 8 Thanks for the update. I really appreciate your help. 0 Quote
