Posted (edited)
For those with a Radxa Cubie A7A, I made a custom Armbian Build using the BSP kernel.
https://github.com/NickAlilovic/build/releases/tag/Radxa-a7a-v0.2
https://github.com/NickAlilovic/build/tree/Radxa-A7A
Now supports automatic first boot configuration by default. No need for a usb serial device to boot into a desktop image. First boot takes awhile to load. If you are using a server image you need a usb serial device/ssh to interact with the console. There is no Framebuffer console support in the BSP kernel.
If you want to edit the automatic first boot configuration read the documentation.
https://docs.armbian.com/User-Guide_Autoconfig/
Username: radxa
password: radxa
Edited by Nick A
Updated release to v0.2
  • Nick A changed the title to Radxa Cubie A7A - Allwinner a733
Posted (edited)
Fixed the automatic first boot configuration on Bookwarm. Now you can boot the desktop image without a usb serial device.
Edited by Nick A
Hey @Nick A, first of all, thanks for providing us with the build, I flashed and tried the image, But I could not see kvm enabled in the system. Is this expected?
some example outputs:
~$ ls -l /dev/kvm
ls: cannot access '/dev/kvm': No such file or directory
~$ sudo dmesg | grep -i kvm
[    0.184039] kvm [1]: HYP mode not available
also no output on
lscpu | grep Virtualization
Posted (edited)
@Shubham Singh
To check if KVM is compiled into the kernel, use the following command:
grep CONFIG_KVM /boot/config-$(uname -r)
CONFIG_KVM=y
CONFIG_KVM_MMIO=y
CONFIG_KVM_VFIO=y
CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y
CONFIG_KVM_XFER_TO_GUEST_WORK=y
You also need to ensure your CPU supports virtualization. Check with:
egrep -c '(vmx|svm)' /proc/cpuinfo
0
A return value greater than 0 indicates virtualization support is present.
CPU doesn't support virtualization.
Check the official Radxa image. Using these commands. I doubt it works. I'm using the same kernel config and Board support package.
Edited by Nick A
