humanus Posted 4 hours ago Posted 4 hours ago @alexc @qq20739111 I would be very surprised if the UART log showed anything other than mine. You can find it attached above. 0 Quote
alexc Posted 4 hours ago Posted 4 hours ago @humanus Thanks, just noticed the log. Interestingly looks like it's the mmc part. A few things I can think of: 1. emmc is only presented on A7A/S, so if you are using emmc or your board has an emmc, it might be a problem. You can try to disable sdc2 on device tree and see if it works. 1. sd card part is the same on A7A/S/Z, but I don't think my card is a UHS-II card. Looking at the log, it might be doing something with UHS-II, so it might be worth trying a different SD card to see if it behaves differently. If it does turn out to be related to UHS-II handling, I can look into a proper fix later. on. 0 Quote
humanus Posted 3 hours ago Posted 3 hours ago (edited) I have no eMMC and the card isn't UHS-II (I use WD Purple cards, they are UHS-I). I don't think I have any UHS-II cards at the moment... Could try a different one though. Edited 3 hours ago by humanus clarify 0 Quote
alexc Posted 1 hour ago Posted 1 hour ago (edited) @humanus I took a second look at the log, I think it's probably due to the enabled eMMC. EDIT: I added the emmc part to my A7Z dts, it also crashes... So that's definitely the root cause. I disable it for A7S in my repo for now, you can compile it yourself with a Linux 6.18 kernel or wait for Nick. By the way A733 eMMC seems to use the same eMMC driver as A523, so probably mainline already supports it. Edited 1 hour ago by alexc 0 Quote
