Of course, you can build an A7S image now as well. There's no display output yet.
Edited by humanus
Add detail
Thanks, I compiled one myself too, and it works fine. I actually thought Nick A said A7S support was only added in 6.18.
I also built a desktop version for A7S, but the GUI doesn't seem to start or work properly.
Edited by qq20739111
https://github.com/alexcaoys/allwinner-bspThere are numerous issues with the NPU driver code in the repository, with almost all header files incorrectly set to "<>", resulting in compile time dependencies that cannot be found. I initially wanted to try modifying the makefile, but I found that the header file settings were very confusing, including mixing<>and "", incorrect header file paths, and a series of other problems. In the end, I gave up modifying the makefile and instead relied entirely on relative paths to locate header files, almost all of which needed to be modified.
However, it is reassuring that the repository has no other issues except for the header file error of the NPU code. Of course, it may be necessary to add a ** sunxi-autogen. h ** file to the include directory
The following is the NPU section that I have modified, completely by replacing and modifying the directory ../
npu.7z
Hi @xuyitao,
My repository is focused on moving toward a usable mainline kernel.
As of this week, there are no longer any dependencies on BSP NPU drivers. I plan to remove those, along with the BSP GPU drivers, to avoid any potential confusion.
Could you take a look at the mainline etnaviv driver? Hopefully it meets your needs.
@eli
I think I’ve got KVM enabled, but as they discussed previously, it's not a Linux kernel issue, there's some specific u-boot firmware needed. Since I don't think the open source firmware is ready yet, I guess KVM likely is not feasible on A733 for now.
@Dalibor Pospíšil
I haven't tested if the pcie works, maybe others did? But it's a bsp driver so it should.
If that works, and if the SATA device has a driver in Linux 6.18, simply enable it in menuconfig and you should be good to go.
EDIT: Right, I don't have A7A so I didn't really touch the dts for A7A, there might be a little works needed for it to boot.
Edited by alexc
@210518-nick-a, please tell me about
AIPU / Zhouyi driver
RemoteProc enabled
RPMsg support,
are those existing in your kernel or should we add them ?
Edited by operator
I could not get PCIE to work properly on BSP 6.6 on the A7S, but maybe it was my mistake.
For SATA over M.2 to work (in case on m.2 SATA drives), the device need to support this electrically, which I'm not sure if A7x boards do.
Sent from my SM-S931B using Tapatalk
vkmark works on the Sway desktop. The mainline GPU driver still needs some work. I added A7A and A7S support; however, the A7S still needs to be tested.
https://github.com/NickAlilovic/build/tree/Radxa-mainline-WIP
I am using Debian Trixie with the XFCE desktop environment. A popup message should appear for the Sway installation. Please note that I haven't tested this configuration on other settings.
Edited by Nick A
@Nick A
Great! and Good job!
I've tested both the server and desktop versions of v0.6.4 on the A7S, and the DP output works perfectly on both. I've attached a screenshot for your reference.
I’m using a USB‑C to HDMI docking station to test it. When I repeatedly plug and unplug it, the display works fine. The dock also has a keyboard receiver plugged in, which works normally. However, if I then plug a USB flash drive into the dock, the display output stops working (probably due to power supply issues). If I unplug the USB drive and plug it back in, the display works normally again.
Additionally, I tested the Mainline v0.1. It seems to have issues on the A7S: the blue LED flashes after boot, but neither the Ethernet nor WiFi connects, and there is no output on the DP port. It appears the system cannot be login (I haven't tested via UART). However, the A7Z handles dual screens fine over HDMI and DP.
A733 User Manual: GitLab Link https://gitlab.com/tina5.0_aiot/product/docs/-/blob/product-aiot-stable/A733/Hardware硬件类文档/芯片手册/A733_User Manual_V0.92.pdf?ref_type=heads
Decompiled boot0: https://paste.armbian.eu/akajigufep.kotlin
My ATF Fork: https://github.com/rvdr/arm-trusted-firmware/tree/sun60i-a733
My Armbian Build Tree (containing the U-Boot/Kernel patches): https://github.com/rvdr/build/tree/cubie-a7a-7.0
Can somebody look into the u-boot patches (in the v2026.01 directory). I cant even get UART output and I would be grateful if somebody could look into it to check for errors or if something is missing entirely.
In my case, WiFi connects correctly on mainline on A7S. Haven't gotten any DP output yet, only on 6.6. There is some spam about DP in UART.
@humanus Did you build it yourself, or did you just download Nick's version? Also, doesn't the WiFi connection need to be set up first? I downloaded Nick's A7S Mineline v0.1 directly, but I can't connect even with a wired NIC, so I can't get the WiFi working either.
@Nick A
I re-tested v0.6.4 on the A7S several times.
It turns out that if you unplug and replug the DP cable before the GUI loads, you won't get a signal back. The only fix is to restart the device.
Additionally, the restart button on the A7S is not functional with this image.
The MLIR pipeline, lowering from TOSA to TIM-VX C++, is now available here:
https://github.com/MaverickLong/MLIR-TIM-VX
It's *kinda* working, currently only supports conv2d (image processing) CNN models or simple MLPs, and it's far from mature, so expect a lot of errors.
With this (plus the unified driver) we are heading towards running any ML model on the NPU...
@humanus I thought Nick was referring to version 6.6, but I must have misunderstood. Since I knew 6.18 was still in development, I assumed he meant 6.6. Turns out he was actually talking about 6.18.
Thanks Nick A for the A7S image! I've been trying out v0.6.4 using Sway on top of the server image w/ a pair of Viture Luma Pro AR glasses as a display.
A few things I noticed:
- It seems like a display needs to be plugged in at some point during boot for DP to work, but can be unplugged and replugged afterwards without breaking anything. I'd guess that this is the same issue @qq20739111 noted.
- Audio over DP doesn't seem to work, and I don't see any sinks available through pactl. Fwiw, I've at least verified DP audio to work on the vendor image, and Bluetooth audio to work on this one.
If it'd be useful, here are some boot logs taken over UART:
DP plugged in at boot, display output works - https://paste.armbian.eu/vuvoyufuto.yaml
DP plugged in after boot finished, no display output - https://paste.armbian.eu/ohoqorupiy.yaml
@Nick A
I compiled the image for version 6.18.19 using the parameters you preset, but the system fails to boot correctly on the A7S.
Upon power-up, the green LED stays solid for about 15 seconds. Then, the green LED flashes once, and the blue LED turns solid (unlike the official system where the blue LED blinks). After that, the system becomes unresponsive. There is no signal output on the DP interface, and the Ethernet port indicator light does not turn on even when a cable is connected.
Here is the hash value of the compiled file. I'm not sure if there was an issue with my compilation process, as the network connection dropped several times, and it took a few attempts to finally complete the build.
Image: Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a7s_trixie_edge_6.18.19_xfce_desktop.img
sha256: a7c6baf463b233bad0abb08d2fcfde7ac107509d69fada77ebaafc2bd00979c5
Hi @qq20739111,
Thanks for testing!
It looks like your system may be getting stuck during boot. The SHA256 hash will change every time you rebuild the image. The best way to debug this is by connecting to the UART console, since it should show exactly where the boot process is failing.
That said, I’ve also made some updates to the 6.18 kernel, including changes for the A7A and A7S device trees, along with enabling the Ethernet port. Unfortunately I don’t have either an A7A or A7S on hand, so I haven’t been able to test those changes myself.
Nick hasn’t updated the Armbian build yet, but you can also try building the kernel yourself and manually replacing the kernel image and DTBs in the /boot directory for testing.
