dabozz Posted November 15 Posted November 15 Hi, I currently have the issue of a non working usb port on my odroidhc4. dmesg output: [ 133.464610] usb usb1-port2: connect-debounce failed The port does not show up when lsusb is entered. uname -a: Linux odroidhc4 6.12.56-current-meson64 #1 SMP PREEMPT Wed Oct 29 13:09:02 UTC 2025 aarch64 GNU/Linux I solved this temporairly a while ago by booting an older kernel (linux-image-6.12.43+deb12-arm64) like mentioned here: Are there any progresses on how to fix this reliably? Because I think still running kernel 6.6.63 is not save. Thanks for your answer in advance, if you need more information I am happy to deliver. 0 Quote
Igor Posted November 23 Posted November 23 On 11/15/2025 at 11:59 AM, dabozz said: running kernel 6.6.63 is not save 6.6 is LTS kernel https://www.kernel.org/category/faq.html When some security issue is found, it goes into all LTS kernels. Higher version number does not guarantee bigger safety. Most recent has more functional bug fixes and new features and is generally more fragile - bugs / holes yet to be found. On 11/15/2025 at 11:59 AM, dabozz said: Are there any progresses on how to fix this reliably? Yes, v25.11.1 with 6.12.y https://www.armbian.com/odroid-hc4/ doesn't have those problems. At least I could not recreate them. Booting HC4, plugged in two usb devices, all good: https://paste.armbian.com/ibifozegof P.S. Life is deadly dangerous 0 Quote
dabozz Posted November 24 Author Posted November 24 Great news! So a simple apt update/upgrade will fix it for me? 0 Quote
Igor Posted November 24 Posted November 24 1 hour ago, dabozz said: Great news! So a simple apt update/upgrade will fix it for me? Yes, but packages hasn't been pushed out yet. We need to test and possibly fix last problems on images. In 10-14 days. 0 Quote
dabozz Posted December 8 Author Posted December 8 Hi Igor, I recently updated to Armbian 25.11.2 bookworm aarch64 with kernel Linux odroidhc4 6.12.58-current-meson64. This should be a working version? There I still get the same connect-debounce error. Do you have any advice? 0 Quote
