iskra Posted 15 hours ago Posted 15 hours ago Armbianmonitor: https://paste.armbian.com/awedajesut Hello people! I have a NAS on my local network. I want to use its NFS share in Armbian Just like I do with the Debian x86 desktop. (I want to say that the NAS is configured correctly). Скрытый текст . /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.8.1 for RK3318 Box running Armbian Linux 6.12.42-current-rockchip64 Packages: Debian stable (bookworm), possible distro upgrade (trixie) . However, I had some problems with armbian. I followed the general NFS instructions for debian. but it didn't work. I followed the instructions for armbian. I created a directory for the mount point. I copied the fstab line from my desktop, where it is known to be correct and working properly. 192.168.xx.x:/d8/d8 /mnt/d8-nas nfs relatime,nfsvers=3 0 0 I've tried issuing commands from the command line. mount -vvvvv -t nfs -o vers=3 192.168.xx.x:/d8/d8 /mnt/d8-nas mount -vvvvv -t nfs -o vers=4 192.168.xx.x:/d8/d8 /mnt/d8-nas The result is nothing. Скрытый текст Sat Nov 22 19:56:03 root@rk3318-box>mount -vvvvv -a / : ignored /tmp : already mounted mount.nfs: timeout set for Sat Nov 22 20:02:15 2025 mount.nfs: trying text-based options 'nfsvers=3,addr=192.168.xx.x' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.xx.x prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.xx.x prog 100005 vers 3 prot UDP port 36831 mount.nfs: mount(2): No such device mount.nfs: No such device Status: 32 What a mystery "No such device"? I have another rockchip 3228 box with an older armbian 23.11 kernel, and nfs doesn't work there either. And I tried some different builds of 24.5 24.11 25.5. I couldn't get the nfs client to work on any of them. Can you tell me how to solve this quest? 0 Quote
Michael Robinson Posted 10 hours ago Posted 10 hours ago you can try: sudo systemctl status rpcbind if there are any problems or it's not enabled try: sudo systemctl enable rpcbind sudo systemctl start rpcbind 0 Quote
iskra Posted 1 hour ago Author Posted 1 hour ago 8 часов назад, Michael Robinson сказал: you can try: sudo systemctl status rpcbind RPCbind enabled and running. Скрытый текст Sun Nov 23 13:56:20 root@rk3318-box>systemctl status rpcbind ● rpcbind.service - RPC bind portmap service Loaded: loaded (/lib/systemd/system/rpcbind.service; enabled; preset: enabled) Active: active (running) since Sat 2025-11-22 20:24:50 MSK; 17h ago TriggeredBy: ● rpcbind.socket Docs: man:rpcbind(8) Main PID: 336 (rpcbind) Tasks: 1 (limit: 2187) Memory: 2.9M CPU: 263ms CGroup: /system.slice/rpcbind.service └─336 /sbin/rpcbind -f -w Nov 22 20:24:50 rk3318-box systemd[1]: Starting rpcbind.service - RPC bind portmap service... Nov 22 20:24:50 rk3318-box systemd[1]: Started rpcbind.service - RPC bind portmap service. Sun Nov 23 13:56:25 root@rk3318-box>mount -vvvvv -t nfs -o vers=3 192.168.xx.x:/d8/d8 /mnt/d8-nas mount.nfs: timeout set for Sun Nov 23 14:02:14 2025 mount.nfs: trying text-based options 'vers=3,addr=192.168.xx.x' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.xx.x prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.xx.x prog 100005 vers 3 prot UDP port 36831 mount.nfs: mount(2): No such device mount.nfs: No such device Status: 32 0 Quote
