TerrorPUP Posted 5 hours ago Posted 5 hours ago Hi, I've tried to setup the latest Debian 13 (Trixie) for the Renegade board. I can flash the image with no issue. The problem comes it boots up, prompts for root password. I can type in then press enter, and then it goes to login. This only happens on the Debian 13 (Trixie). I am using the Debian 12 XFCE imange no issue. I am not sure if this is a bug or what, but I loved to use Debian 13, I am trying to setup Docker with the latest OS. 0 Quote
laibsch Posted 3 hours ago Posted 3 hours ago Are you saying you are missing further steps in between setting root passwd and being logged in? 0 Quote
TerrorPUP Posted 1 hour ago Author Posted 1 hour ago I type the root password once, press enter to retype it, but it jumps straight to the login prompt. Do not pass Go, do not collect $200. I’ve been dealing with this for the past month. At first, I thought it was just my 2GB model acting weird, but today I had two 4GB units do the same thing. It only happens with the Debian 13 Minimal/IOT image. I didn't want the overhead, but I am using the Debian 12/XFCE Desktop image that works. 0 Quote
laibsch Posted 50 minutes ago Posted 50 minutes ago Can you run a uefi-x86 image in a VM and see if you can reproduce the behaviour? I doubt this is specific to your board but an error somewhere else. 0 Quote
TerrorPUP Posted 37 minutes ago Author Posted 37 minutes ago Yes, give me a couple days as I am in the middle of project. 0 Quote
