ChrisO Posted 14 hours ago Posted 14 hours ago (edited) Hi I dd the Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img to a SD card (/dev/sdc) and then run a fsck -f /dev/sdc1 and got errors: sudo fsck -f /dev/sdc1 fsck from util-linux 2.39.3 e2fsck 1.47.0 (5-Feb-2023) Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Entry '.' in ??? (1065) is duplicate '.' entry. Fix<y>? .... Tried few SD cards, same result. Tried those SD cards with other images, i.e. Armbian_24.8.4_Rock-5c_bookworm_vendor_6.1.75_minimal.img no problems. Could anybody verify this behavior? Thanks Chris Armbian_25.11.1_Rock-5c_trixie_vendor_6.1.115_minimal.img image generates the same problem. Edited 13 hours ago by ChrisO typo, added a sentence 0 Quote
laibsch Posted 14 hours ago Posted 14 hours ago Images shall only be written with imaging tools that validate burning results. This saves you from corrupted SD card contents. Approved Tools: USBImager a lightweight cross-platform imaging tool Balena Etcher an electron / node.js based cross-platform imaging tool (may contain spyware) 0 Quote
Werner Posted 8 hours ago Posted 8 hours ago 6 hours ago, laibsch said: Balena Etcher This is not recommended. https://docs.armbian.com/User-Guide_Getting-Started/#flash-to-sd-card 0 Quote
ChrisO Posted 32 minutes ago Author Posted 32 minutes ago (edited) I do verify what is written to the SD card. It's a homegrown script I have used for at least ten years. It's not the cause of my problem. And as for all those shiny clicky-clickity tools, no thanks! I prefer to know what is going on on my computer. Any comments on my question, anyone? If anybody could write one of the images using his his preferred/recommended imaging tool and run fsck on the resulting partition it would help me much. Thank you. Edited 15 minutes ago by ChrisO 0 Quote
