sven-ola Posted December 21, 2025 Posted December 21, 2025 Hey! Got it up and running - I have an Armbian SD card image based on the source trees found on https://github.com/orangepi-xunlong. Since I am a newbie to Armbian, please accept my apologies for beginner errors. Here's what I currently got on my UART: root@orangepirv2:~# uname -a Linux orangepirv2 6.6.63-current-ky #1 SMP PREEMPT Tue Mar 18 02:29:27 UTC 2025 riscv64 GNU/Linux root@orangepirv2:~# cat /etc/os-release PRETTY_NAME="Armbian-unofficial 26.02.0-trunk trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.2 ID=debian HOME_URL="https://www.armbian.com/" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian-unofficial 26.02.0-trunk trixie" This is not ready for prime time now. Needs a bit cleanup b/c I pulled in binaries and private project stuff not meant for armbian-build. Currently resides in this fork https://github.com/sven-ola/armbian-build/tree/orangepi-rv2. If you want to give it a try: it's compile.sh opirv2 after checkout. I've also managed to boot from the top 2230 M.2 SSD but this is also handmade (I'm pretty sure there is a script in here that copies the SD card boot blobs to SPI flash, will try before doing the MR). Best // Sven-Ola 1 Quote
sven-ola Posted December 22, 2025 Author Posted December 22, 2025 In the meantime, I spotted the pending MR from https://github.com/tmshlvck for this in the Pull Request Backlog. There are a number of issues with that, besides that it's very similar. Adding *.deb from xunlong without review is (mmm), better stay away from this. I'm not sure if the camera *.json is required. Not anything from the xunlong tree needs to be copied probably. I cleaned out my version (see https://github.com/sven-ola/armbian-build/tree/orangepi-rv2), but while this is open since October, I postpone to trigger another MR on that issue. My goal is: boot from upper 2230 SSD and use lower M.2 for Wifi (there are cheap Mediatek 3-band Wifi cards with 2280 adapter). If anyone wants similar setup, just checkout my branch from the link above and: ./compile.sh BOARD=orangepirv2 BRANCH=current RELEASE=trixie KERNEL_CONFIGURE=no BUILD_MINIMAL=yes KERNEL_GIT=shallow Write output/images/*.img to SD and boot with that. Use armbian-install to copy boot cfg on MTD. Again copy that *.img to /dev/nvme0n1. Remove SD card, reboot board. While investigating, there are a number of hints that the Ky X1 is in fact a SpacemiT K1 variant. Maybe stripped down, since the RCPU firmware (esos.elf) is much smaller. I have noticed, that Xunlong is not exactly welcome here. Chinese difficulties with the words upstream and donation probably. I think the hard work is to maintain / port the kernel and u-boot code drops with future versions. On the other hand: this board is cheap, offers a way to practice with a new CPU arch, and has the expected minimum number of M.2 slots. I'm currently compiling a kernel on that board. ETA 3 hours or so, board is not very fast. Anyhow, temp stays below 80°C if operated upright (above foto). No unusual hotspots, board and RAM seems stable, wifi and ethernet works. HTH and LG // Sven-Ola 0 Quote
sven-ola Posted December 24, 2025 Author Posted December 24, 2025 Today investigated, why BCM Bluetooth was not working with my image. What a rabbit hole 🙄 Also added OrangePi R2S board. Smaller brother of RV2 (I have no board but it's probably working). For the Bluetooth: everyone is obviously happy to hack the BCM firmware file instead of implementing bcm init into hciattach. The brcm_patchram_plus firmware hacking tool was added for this arch and that arch as a binary under BSP for different boards. Not very Debian-style. I grabbed the working source, compared to the one avail in Android AOSP and added it to my branch, added lib6-dev-riscv64-cross to the Docker image and now have a working image with BT. LG && HTH // Sven-Ola 0 Quote
sven-ola Posted December 29, 2025 Author Posted December 29, 2025 (edited) As a followup: hardware crypto is damn slow on the Ky / SpacemIt platform, at least for default LUKS block encryption with AES. This probably also affects the Banana Pi F3 image. With default sector-size of 512 byte, HW-AES is 5 times slower than SW-AES, while cryptsetup benchmark reports 5 times faster. Main reason: block size. With sector-size of 4096 LUKS is reasonable fast. Also there is leftover debug (cannot be switched off) and a small bugs in the driver that triggers SW crypto fallback after HW crypto succeeds. Patches: https://github.com/sven-ola/armbian-build/tree/orangepi-rv2/patch/kernel/ky-current Best // Sven-Ola Edited December 29, 2025 by sven-ola 0 Quote
sven-ola Posted January 7 Author Posted January 7 (edited) PCIe MSI is not working. At least with an Intel iwlwifi M.2 card. For that reason, I investigated the differences between the Xunlong KY tree and the Armbian Spacemit Tree. B/c loading the "official" 552kb esos.elf seems to work (even if the Ky version is only 104kb) on the OrangePi RV2, I started to backport Xunlong changes to Armbian/Spacemit family. Newer kernel, but no luck with that MSI. There should be a DMA-transfer-complete interrupt at the end of the firmware upload. Card is working in my PC. MSI is working on OpiRV2 with NVME. Current status: board runs with spacemit-family kernel, but some minor Does-Not-Work yet: LED, onboard Wifi+BT and I need to check that special RTL eth... LG // Sven-Ola Edit: Pic it or it didn't happen. RV2 underside with WIfi card. Edited January 7 by sven-ola +=IMG 1 Quote
sven-ola Posted January 8 Author Posted January 8 All clear for the PCIe MSI: it is something with that Intel 7260 card. Today, I got two other M.2 Wifis: MT7922 and RTL8822ce, both seem to work on current and also on edge. Thus, I consider this as a success. Here's some screen blurb. Zitat root@orangepirv2:~# modprobe -v mt7921e insmod /lib/modules/6.18.4-edge-spacemit/kernel/net/wireless/cfg80211.ko.xz insmod /lib/modules/6.18.4-edge-spacemit/kernel/net/mac80211/mac80211.ko.xz insmod /lib/modules/6.18.4-edge-spacemit/kernel/drivers/net/wireless/mediatek/mt76/mt76.ko.xz insmod /lib/modules/6.18.4-edge-spacemit/kernel/drivers/net/wireless/mediatek/mt76/mt76-connac-lib.ko.xz insmod /lib/modules/6.18.4-edge-spacemit/kernel/drivers/net/wireless/mediatek/mt76/mt792x-lib.ko.xz insmod /lib/modules/6.18.4-edge-spacemit/kernel/drivers/net/wireless/mediatek/mt76/mt7921/mt7921-common.ko.xz insmod /lib/modules/6.18.4-edge-spacemit/kernel/drivers/net/wireless/mediatek/mt76/mt7921/mt7921e.ko.xz root@orangepirv2:~# iw dev phy#0 Interface wlan0 ifindex 4 wdev 0x1 addr cc:5e:f8:e3:a9:05 type managed multicast TXQ: qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets 0 0 0 0 0 0 0 0 0 root@orangepirv2:~# iw phy |grep Band Band 1: Full Bandwidth UL MU-MIMO Partial Bandwidth UL MU-MIMO Partial Bandwidth Extended Range Full Bandwidth UL MU-MIMO Partial Bandwidth UL MU-MIMO Partial Bandwidth Extended Range Band 2: Full Bandwidth UL MU-MIMO Partial Bandwidth UL MU-MIMO Partial Bandwidth Extended Range Full Bandwidth UL MU-MIMO Partial Bandwidth UL MU-MIMO Partial Bandwidth Extended Range Band 4: Full Bandwidth UL MU-MIMO Partial Bandwidth UL MU-MIMO Partial Bandwidth Extended Range Full Bandwidth UL MU-MIMO Partial Bandwidth UL MU-MIMO Partial Bandwidth Extended Range root@orangepirv2:~# lspci 0001:00:00.0 PCI bridge: Device 201f:0001 (rev 01) 0001:01:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter 0002:00:00.0 PCI bridge: Device 201f:0001 (rev 01) 0002:01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9B1 (DRAM-less) (rev 02) // Sven-Ola 0 Quote
brunorro Posted January 12 Posted January 12 Hey, Thank you for working on this one. I have the very same and the sunxi scripts to create the Ubuntu image (tricked into trixie) are horrible. For instance, to create ky image they download all toolchains (ARM and so on) from its site and it's kind of difficult to even change that one. I would love to use upstream u-boot and spacemit 6.19 kernel on this one (already compiled for it) but I'm no expert and the lack of docs and ways to work on this one kills me Thank you! 0 Quote
sven-ola Posted January 12 Author Posted January 12 Hello @brunorro. Yes, sometimes people are hacking badly. I have it working again after restarting with Armbian/Spacemit: u-boot starts, onboard BT and Wifi works, SD card is again reading with 80mb/s, transfer u-boot and SBI to MTD via armbian-install works (MTD boot is required for starting from SSD), both M.2 slots can boot from NVME. Sadly, the Broadcom SDIO wifi driver is a smoking mess. This driver needs heavy porting so its not available with linux-6.18 / edge currently. Are you willing to test anyhow? I can provide a 6.6.99 Trixie image for download if you ACK. There are always things that I may have overlooked such as USB, HDMI. All those little things I have not tested, I' on UART currently. LG // Sven-Ola 1 Quote
brunorro Posted January 13 Posted January 13 Hey!! Of course, I will test that one. Let me know (here or in a PM) what can I do for you. I only have a RV2 8GB RAM, but both M.2 slots are filled up (a 256GB nvme on the 2230 and a 512GB on the 2280) so I could test those as well. Everything I can learn will be welcome. Personally I would love to create a musl based, systemd free distro (alpine, void, etc.) for this little thing, but my knowledge is out of that league, I've only got some experience with OpenWRT on old routers Thank you!! 0 Quote
sven-ola Posted January 13 Author Posted January 13 Hello @brunorro, I have uploaded two images to https://privat-in.de/ (navigate to downloads, grab Armbian*.img). Simply post findings here. The "edge" image is rather unstable, e.g. my NVME gives a read-error while working fine with "current", while a Mediatek Wifi card seems to work. Probably no easy task, could be anywhere in the IOMMU - DMA - PCIe triangle. The images are compiled from https://github.com/sven-ola/armbian-build/tree/orangepi-rv2 kernel with defaults plus switched on every Mediatek Wifi driver module. Here's my Todo for ref (+ marks ok): To be merged + Boot from SSD (upper+lower) + SPI NOR flash boot / install + SD/TF speed too slow (15mb/s) - Check SD UHS in uboot speed limit + Brcm SDIO wifi not working - Armbian edge: Brcm SDIO Wifi - Armbian edge: PCIe NVME IOErr + Bluetooth not working - RTL ethernet (2.5gbit R2V board?) - Ky overlay dtbo's missing - Focaltech touch driver from Ky? - Ky MIPI/CSI cam modules - What is that realtime r_uart? - GPU? USB2-OTG? USB3? Sound? Personal wishlist: - Device-mapper / dm_era missing + Mediatek PCIe wifi modules - PCIe adapter: Radeon GPU test Ah, yes. OpenWrt is on the Ky list of supported systems. I have a personal history on that too. While getting rid of systemd may be not that difficult (see Devuan) exchanging libc is another beast probably. LG // Sven-Ola 0 Quote
brunorro Posted January 13 Posted January 13 (edited) Hey, thank you very much!! Downloading and testing current (did a dd on an sd card, didn't boot, I'll check it again) But edge... Boots! I have to check it with some more care so I can see how does it work And yes, the guys from Devuan make a good work keeping stuff a bit simpler. I like quite a lot Void Linux (in fact this laptop I'm writing in has it installed) I'll test current with some more care Thank you! current.txt edge.txt Edited January 13 by brunorro Add logs 0 Quote
sven-ola Posted January 13 Author Posted January 13 In the meantime I fiddled with HW crypto and PCIe sleep states. While the former is working on edge and current, the latter may be an individual error with my Samsung PM9b1 128Gb NVME SSD not working in the upper 2230 M.2 on edge. While the current 6.6 kernel does not use ASPM eventually, the edge 6.18 kernel has it and it leads to read errors. Adding pcie_aspm=off to /boot/extlinux/extlinux.conf::append helped, but I think adding a "No ASPM" to pci-quirks for this device is a better solution b/c the PCIe wifi is working (has L1 and L0s sleep). So if you like then test your NVME SSDs with the edge kernel. I'am especially interested in NVMEs reporting Capabilities L1 PM Substates with lspci -v LG // Sven-Ola 1 Quote
sven-ola Posted January 14 Author Posted January 14 Hello @brunorro. That "current.txt" from above: the UART output shows you are booting an older KY-Uboot from NOR flash. Probably SD card not fully inserted. "edge.txt" shows a correct SD card boot sequence. Best // Sven-Ola 1 Quote
brunorro Posted January 14 Posted January 14 Thank you! I will check later today. If there is anything else I can help about, let me know. By the way, both of my nvme drives are `Capabilities L1 PM Substates`, what is the best way to install everything there? I suppose it's not as simple as a dd of the image on them... My "low-level" skills are not what they used to be (and they were not that good in my good days), but I will check if I can build some stuff around here Thank you, and again sorry about my technical limitations 0 Quote
sven-ola Posted January 14 Author Posted January 14 If inserted, SD is booted first. If not inserted or SD read err, NOR flash is booted. NOR flash in turn boots from lower 2280 NVME. I have added boot-from-upper 2230 NVME to uboot. To install Boot via SD. Log in as root. Start armbian-install Select 7 Install to MTD Put fresh image to NVME via dd of=/dev/nvme... Eject SD, press [reset] If anything is wrong, start over with 1. Boot via SD. I am not sure wich NVME (upper or lower?) is used first. Note: If you put the same image to both NVMEs and insert SD, you may have up to three ext4 partitions with the same UUID in the box. So on reboot it is very unclear which of the three ext4 is used as root. Check with df -h /. If necessary, you can use uuidgen from uuid-runtime package and tune2fs -U as well as nano to change extlinux.conf for a different ID. HTH // Sven-Ola 0 Quote
robertoj Posted January 15 Posted January 15 Thank you guys for the work toward this RiscV SBC The website http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-RV2.html claims 130% faster than ARM A55 (which is 25% slower than my H618)... have you tested that? Are the USB, GPIO, SPI and MIPI DSI working? Are there any NPU examples provided by Orange Pi? 0 Quote
sven-ola Posted January 15 Author Posted January 15 (edited) I operate an Odroid HC4, that has 4 x A55@1.8 and the board discussed here has 8 x X60@1.?. A fast sysbench says: single thread on OpiRv2 is slower (792 vs 1034) , multithreaded is faster (6342 vs 4151). Compiling a current kernel on RV2 needs 3 hours, nothing one would do do regularly. If you really need speed buy a Radxa Rock 5 (see platinum support devices on this site). Edit1: NPU -> Opi Wiki, USB and SPI yes, for MIPI DSI/CSI you need to test yourself. Edit2: Just remembered that I have a H618 (Opiz3). Single=708, Multi=2828 with the same Trixie sysbench. HTH + LG // Sven-Ola Edited January 15 by sven-ola 1 Quote
robertoj Posted January 16 Posted January 16 I got surprised by "GPU: Mesa llvmpipe" ... but then I searched, and it means CPU rendering. But still very nice! 0 Quote
robertoj Posted January 16 Posted January 16 23 hours ago, sven-ola said: I operate an Odroid HC4, that has 4 x A55@1.8 and the board discussed here has 8 x X60@1.?. A fast sysbench says: single thread on OpiRv2 is slower (792 vs 1034) , multithreaded is faster (6342 vs 4151). Compiling a current kernel on RV2 needs 3 hours, nothing one would do do regularly. If you really need speed buy a Radxa Rock 5 (see platinum support devices on this site). Edit1: NPU -> Opi Wiki, USB and SPI yes, for MIPI DSI/CSI you need to test yourself. Edit2: Just remembered that I have a H618 (Opiz3). Single=708, Multi=2828 with the same Trixie sysbench. HTH + LG // Sven-Ola Great I thought RiscV was still much slower than ARMs of similar prices. 0 Quote
sven-ola Posted January 16 Author Posted January 16 Thanks for the feedback. This is welcome 👾 I'm currently fiddling with Wifi for the 6.18 kernel. No good karma: the adapted bcmdhd sdio wifi from the Spacemit kernel 6.6 was removed from 6.18. So I'm using the bcmdhd extension instead, as it's done with OrangePi 5, based on the github/armbian/bcmdhd-dkms repo. That one has ALLWINNER changes under the #ifdef CUSTOMER_HW_RK (probably Rockchip origin). I need to re-add SPACEMIT changes. Also, I need to revert a Wake-on-WLAN change submitted by Spacemit to RFKILL in order to get the necessary Interrupt init called. Bonus: OPi5-edge also uses that extension driver but does not compile b/c a PR for 6.17 on bcmdhd-dkms from October was ignored. Will need time 🤪 LG // Sven-Ola 0 Quote
sven-ola Posted January 17 Author Posted January 17 (edited) Have uploaded a new "edge" image for RV2 for testing. This time, wifi works. "current" image is the same. If you want to test, go to https://privat-in.de and grab Downloads. If you want to compile, clone https://github.com/sven-ola/armbian-build/tree/orangepi-rv2 and run Zitat ./compile.sh CPUTHREADS=$(nproc) BOARD=orangepirv2 BRANCH=edge RELEASE=trixie KERNEL_CONFIGURE=no BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_GIT=shallow Edit: forget to activate Mediatek wifi drivers as well. Also merged current Armbian/main. Uploaded again. LG // Sven-Ola Edited January 17 by sven-ola 0 Quote
sven-ola Posted January 19 Author Posted January 19 Have solved another todo: grab overlay *.dtbo from Ky/Xunlong. There is still some quirks with SD/TF read/write speed (UHS / 1.8v mode). Also applied for Armbian maintainership on orangepirv2 in advance. Had some experiments with that M.2 to PCIe adapter I recently got. That oversized thing is an older Radeon with an Opi RV2 mounted on top. That does not work (no, card is so old it does not require extra 12V). Second image is a even older Nividia Geforce, That one shows up with "lspci" but does not work b/c no RiscV drivers (that's expected). Next ist an TP-Link / Aquantic 10 GbE Ethernet card. That one works, even without that extra power supply from the PC next to it. Not sure, if the Spacemit CPU can handle the ten gigs... Last image: the 2280-to-PCIe adapter with the eternal SATA power feed cable. LG // Sven-Ola 0 Quote
Malay Posted January 23 Posted January 23 Hello. Thank you for your work on orangepirv2. I have a board with 2 Gb of RAM. I compiled it on your git https://github.com/sven-ola/armbian-build/tree/orangepi-rv2 Armbian-unofficial_26.02.0-trunk_Orangepirv2_noble_current_6.6.99_xfce_desktop.img and Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.6.99_xfce_desktop.img Booting was done from the rear M.2 2280 1TB Armbian-unofficial_26.02.0-trunk_Orangepirv2_noble_current_6.6.99_xfce_desktop.img The download went fine. The network is working, HDMI video is working. is HDMI audio not working (I was upset by this fact) Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.6.99_xfce_desktop.img It won't load, the network isn't working, and there's no HDMI output. I tried your image and the same behavior - It won't load, the network isn't working, and there's no HDMI output. Your image is not working with the rear M.2? 0 Quote
sven-ola Posted January 23 Author Posted January 23 (edited) Hello @Malay! No need to raise your voice. Anyhow - thanks for the feedback. The missing HDMI audio has a deeper reason: the communication with the Realtime-CPUs does not work. Background: HDMI audio needs a special DMA: adma, that in turn is supported by the rCPUs (the extra Cores running the real-time-OS from esos.elf) and that does not communicate correctly via rpmsg currently. Not sure why and also not sure if this is true with the other RiscV/Spacemit boards. The 2280 M.2 slot works, I am pretty sure. If you need a running Armbian *with* HDMI audio, grab the orangepi-rv2-ky branch from my repo. It's older and I use it to compare working vs. non-working currently. Also, there's a reason this has no pull request to Armbian/main: it's work-in-progress. LG // Sven-Ola Edited January 23 by sven-ola Typo 0 Quote
sven-ola Posted January 23 Author Posted January 23 Got HDMI audio working. We need to enable SPACEMIT_DUMMYCODEC (done with a Kconfig change). And we need a working audio DMA. But this raises questions: the fix was to enable the extra kthread found e.g. from Xunlong/Ky into drivers/remoteproc. This fixes the communication to the Realtime CPU (the esos.elf driven Undoc) -> ADMA working -> HDMI audio working for edge and current. However, with edge the extra kthread addon was removed upstream recently [1]. I think it's best to ask the change authors. I will upload fixed images in an hour or so. Best // Sven-Ola [1] https://github.com/jmontleon/linux-spacemit/commit/d6a6ebede205669d2def873c3ab694a6ef1a4826 0 Quote
Malay Posted January 23 Posted January 23 7 часов назад, sven-ola сказал: No need to raise your voice Unfortunately, English is not my native language, and you may have misunderstood me. I apologize. I didn't mean to do anything like that. And I am grateful for your work! So, following your suggestion, I compiled the versions from your other git branch - git clone https://github.com/sven-ola/armbian-build.git --branch orangepi-rv2-ky ./orangepi-rv2-ky I first tried building an image with Orangepirv2_noble_current_6.6.99_xfce_desktop. The network worked, and booting from the rear m.2 2280 also worked, but unfortunately, there was no HDMI video, just a black screen. Then I tried building a different build with Orangepirv2_trixie_current_6.6.63_xfce_desktop, and lo and behold, almost everything worked – the network worked, there was HDMI sound, HDMI output worked, Bluetooth worked, and the built-in WiFi worked. I just have one question: is video really that bad on RISCV? It's impossible to watch anything, it's incredibly slow. I assume they're using software video decoding? 0 Quote
JamesCL Posted January 23 Posted January 23 Thanks for your work, @sven-ola. I'm going to try your image. I only need Ethernet (no sound, no wireless, no Bluetooth, and definitely no HDMI). Cheers! 0 Quote
sven-ola Posted January 23 Author Posted January 23 Hello @Malay. Never mind - I' am not a native English speaker too. I have not tested the GUI intensively because my Goal is using this little board as a mini-server. Also, I think it's best getting the basics up before turning to the high-level GUI and media stuff. The "current" 6.6.99 kernel seems not to work with Wayland. You can switch to X11, change /etc/gdm3/custom.conf. The "edge" 6.18.7 is works with Wayland. Integrating GPU support is out of my focus currently, I am even unsure if this applies for Orange Pi RV2: https://sdk.spacemit.com/en/graphics/graphics_driver_framework/ ? HW Video decoding is another rabbit hole. The documentation is Chinese at best 🤪 LG + HTH // Sven-Ola 1 Quote
