Go to solution Solved by sven-ola,
Posted (edited)
@c0rnelius: Thanks for the info, I'll fiddle with the GPU in the meantime.
@Cristian Apas: that hack above is necessary if you use the Xunlong Ubuntu userspace. They have replaced every hint on the OEM, which includes the GPU driver name. Hack not necessary if we simply use the Spacemit Bianbu Ubuntu userspace.
I hacked an image together with this (see my site https://privat-in.de goto Downloads). It has a glmark2 score of 424 (not very fast). This is not for everybody. I compiled a standard OrangepiRv2 Armbian image with a legacy kernel and put in a Bianbu 3.01 minimal userspace as root. Details from my notes:
# Image creation starts with Armbian-Orangepirv2_trixie_legacy_6.6.99_minimal.img
Root from https://archive.spacemit.com/image/k1/version/bianbu/v3.0.1/ -> minimal.img
Default LANG=zh_CN.UTF-8, change: dpkg-reconfigure locales -> en_US.UTF-8
Copy from Armbian: /etc/netplan/10-dhcp-all-interfaces.yaml, /etc/fstab, /boot/*,
/lib/modules/*, /etc/modprobe.d/orangepirv2.conf /etc/modules-load.d/orangepirv2.conf
Purge spacemit-flash-dtbs (and thereby remove linux-image-6.6.63*)
Uploaded this image to https://privat-in.de/ (Downloads)
First steps after flashing
apt-get install parted
parted /dev/mmcblk0 (or /dev/nvme0n1): resizepart 1 100%
resize2fs /dev/mmcblk0p1 (or /dev/nvme0n1p1)
apt-get install cinnamon-core glmark2-es2-wayland
Reboot and login as root/bianbu (select Cinnamon/Wayland)
Click on Terminal, run glmark2-es2-wayland
Notes: other Spacemit K1 boards can run Bianbu without any changes, this is exclusively for OpiRV2. Also, do not try to update kernel, update-initramfs files from Armbian are missing thus the initrd needs to be massaged by hand or so. Expect oopses at every corner...
Edited by sven-ola
