Tim Zhang Posted 6 hours ago Posted 6 hours ago Build logs: https://paste.armbian.com/tujekosudu clone the latest armbian/build repo, run ./compile.sh but fail. I try native or docker build, all fail. 0 Quote
Igor Posted 4 hours ago Posted 4 hours ago Welcome! Strange. Works here without a problem: https://paste.armbian.com/uqutokajas 0 Quote
Tim Zhang Posted 4 hours ago Author Posted 4 hours ago Thanks for you help. The host system must be Ubuntu Noble 24.04.x? 0 Quote
Igor Posted 4 hours ago Posted 4 hours ago 12 minutes ago, Tim Zhang said: The host system must be Ubuntu Noble 24.04.x? Yes, highly recommended in order to avoid troubles. We mainly use Noble and all of our build & test automation runs on Jammy / Noble. However, when using Docker, you should have more freedom. 0 Quote
Tim Zhang Posted 3 hours ago Author Posted 3 hours ago Very strange, still fail when build with docker. Maybe I need to try use Ubuntu Noble. https://paste.armbian.com/ojadabewej [🐳|🔨] Processing triggers for man-db (2.12.0-4build2) ... [🐳|🔨] Processing triggers for dbus (1.14.10-4ubuntu4.1) ... [🐳|🔨] Errors were encountered while processing: [🐳|🔨] systemd-timesyncd [🐳|🔨] E: Sub-process /usr/bin/dpkg returned an error code (1) [🐳|💥] Error 1 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:15 chroot_sdcard_apt_get_install() --> lib/functions/logging/runners.sh:15 install_distribution_agnostic() --> lib/functions/rootfs/distro-agnostic.sh:327 do_with_logging() --> lib/functions/logging/section-logging.sh:81 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:31 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:36 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208 main() --> ./compile.sh:50 0 Quote
eselarm Posted 1 hour ago Posted 1 hour ago 2 hours ago, Tim Zhang said: [🐳|🔨] systemd-timesyncd If this fails on multiple build host environments, maybe check your network/internet connectivity. Else I don't really know what could be the cause. I use Armbian Aarch64 (RK3588s) with various tweaks ans kernels and it works fine for builds. 0 Quote
