Dec 25th image for Cubie a5e is not a bootable image
Go to solution Solved by Werner,
  • Meestor_X changed the title to Dec 25th image for Cubie a5e is not a bootable image
I don't have this hardware. However the last merged PR messing with code for this board/SoC was tested by Igor and he stated it boots just fine.
Can confirm that version trunk 130 is not bootable. Tried with balenaEtcher and Win32DiskImager.
Looks like trunk 130 is a GPT image unlike the older ones.
There is at least no primary GPT, all zeros from 0x200-0x20000
Fixed with:
# gdisk  Armbian_community_26.2.0-trunk.130_Radxa-cubie-a5e_trixie_edge_6.18.2_minimal.img
GPT fdisk (gdisk) version 1.0.10
Caution: invalid main GPT header, but valid backup; regenerating main header
from backup!
Warning: Invalid CRC on main header data; loaded backup partition table.
Warning! Main and backup partition tables differ! Use the 'c' and 'e' options
on the recovery & transformation menu to examine the two tables.
Warning! Main partition table CRC mismatch! Loaded backup partition table
instead of main partition table!
Warning! One or more CRCs don't match. You should repair the disk!
Main header: ERROR
Backup header: OK
Main partition table: ERROR
Backup partition table: OK
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
Command (? for help): w
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): y
OK; writing new GUID partition table (GPT) to Armbian_community_26.2.0-trunk.130_Radxa-cubie-a5e_trixie_edge_6.18.2_minimal.img.
Warning: The kernel is still using the old partition table.
The new table will be used at the next reboot or after you
run partprobe(8) or kpartx(8)
The operation has completed successfully.
Fixed with:
# gdisk Armbian_community_26.2.0-trunk.130_Radxa-cubie-a5e_trixie_edge_6.18.2_minimal.img GPT fdisk (gdisk) version 1.0.10 Caution: invalid main GPT header, but valid backup; regenerating main header from backup!
Thank you very much for that!
For once as stated don't use Balena. use Armbian imager or usbimager
For the other write the image anyway as it is, try to boot and grab serial logs if there is an actual issue or not.
3 hours ago, Meestor_X said:
Huh? How can you create logs when you can't make an image?
For you, 'make an image' means downloading a file from Armbian website and write it to an SD-card.
For me, 'make an image' means using the Armbian build environment https://github.com/armbian/build to create an image yourself locally on your computer. This is what 'make an image' is.
Already 2 people including myself showed that GPT is corrupted in the image file on the Armbian website. You can assume that the bootloader when run on the board itself also detects that, so it won't boot/proceed. So something goes wrong in the Armbian build infrastructure. However, that is what I assume.
So up to you confirm by showing the logs of the bootloader. You need serial console cable for that, so you can copy and paste for sharing that log here on the forum.
Other option, a step further ahead, is to make an image yourself. You need a Linux computer/environment for it. It also shows very detailed logs, share that.
---- Opened the serial port /dev/tty.PL2303G-USBtoUART8430 ----
U-Boot SPL 2026.01-rc4_armbian-2026.01-rc4-S0e0a-Peafc-H5aa4-Vd0f6-B4d1d-R448a (Dec 29 2025 - 03:26:30 +0000)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.12.0(debug):armbian
NOTICE:  BL31: Built : 03:26:10, Dec 29 2025
NOTICE:  BL31: Detected Allwinner A523 SoC (1890)
NOTICE:  BL31: Found U-Boot DTB at 0xa0ab9f8, model: Radxa Cubie A5E
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    Maximum SPI INTID supported: 287
INFO:    Configuring SPC Controller
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a55: CPU workaround for erratum 1530923 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
ns16550_serial serial@2500000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2026.01-rc4_armbian-2026.01-rc4-S0e0a-Peafc-H5aa4-Vd0f6-B4d1d-R448a (Dec 29 2025 - 03:26:30 +0000) Allwinner Technology
CPU:   Allwinner A523 (SUN55I)
Model: Radxa Cubie A5E
DRAM:  2 GiB
sunxi_set_gate: (CLK#35) unhandled
Core:  77 devices, 22 uclasses, devicetree: separate
WDT:   Not starting watchdog@2050000
MMC:   mmc@4020000: 0
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
In:    serial@2500000
Out:   serial@2500000
Err:   serial@2500000
Net:   eth0: ethernet@4500000
starting USB...
sun4i_usb_phy phy@4100400: External vbus detected, not enabling our own vbus
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@4101000: 1 USB Device(s) found
Bus usb@4101400: 1 USB Device(s) found
Bus usb@4200000: 1 USB Device(s) found
Bus usb@4200400: 1 USB Device(s) found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
4641 bytes read in 3 ms (1.5 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
190 bytes read in 2 ms (92.8 KiB/s)
The file sun55i-a527-radxa-a5e.dtb was not found in the path /dtb/allwinner
Load fdt: /dtb/allwinner/sun55i-a527-cubie-a5e.dtb
33947 bytes read in 6 ms (5.4 MiB/s)
Working FDT set to 4fa00000
Failed to load '/dtb/overlay/sun55i-a527-fixup.scr'
15452067 bytes read in 642 ms (23 MiB/s)
31721984 bytes read in 1315 ms (23 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42130000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Data Size:    15452003 Bytes = 14.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49143000, end 49fff763 ... OK
   Loading Device Tree to 00000000490d2000, end 0000000049142fff ... OK
Working FDT set to 490d2000
Starting kernel ...
Never goes any further. It doesn't get an IP so I can't SSH into it. The "heatbeat" LED does keep flashing, though...
Comparing a the trunk 100 which DOES go on to the login prompt and finishes normally:
U-Boot SPL 2026.01-rc4_armbian-2026.01-rc4-Sd24f-P0000-He0b4-V52aa-Bbf55-R448a (Dec 19 2025 - 03:11:57 +0000)
DRAM: 2048 MiB
NOTICE:  BL31: Built : 03:11:45, Dec 19 2025
INFO:    SPSR = 0x3c9
U-Boot 2026.01-rc4_armbian-2026.01-rc4-Sd24f-P0000-He0b4-V52aa-Bbf55-R448a (Dec 19 2025 - 03:11:57 +0000) Allwinner Technology
DRAM:  2 GiB
MMC:   mmc@4020000: 0
In:    serial@2500000
Out:   serial@2500000
Err:   serial@2500000
starting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Scanning mmc 0:1...
4641 bytes read in 2 ms (2.2 MiB/s)
190 bytes read in 1 ms (185.5 KiB/s)
17944 bytes read in 4 ms (4.3 MiB/s)
14716909 bytes read in 834 ms (16.8 MiB/s)
31918592 bytes read in 1323 ms (23 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42150000
   Image Name:   uInitrd
   Data Size:    14716845 Bytes = 14 MiB
   Loading Ramdisk to 491f7000, end 49ffffad ... OK
   Loading Device Tree to 000000004918a000, end 00000000491f6fff ... OK
Working FDT set to 4918a000
Starting kernel ...
Very little is different, except that the ftd is about twice the size...
Please set verbosity to 7 in armbianenv.txt to get a clue about what happens after "starting kernel..."
data:image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
Interesting. While this isn't an actual issue since the correct dt was loaded nevertheless it seems like BOOT FDT FILE Is set wrong
Fair enough. "WRITE the image" would probably be clearer. The image file is from the repository, I'm using Balena to WRITE the image (rather than MAKE) to the SD card. I'm sure you knew what I meant, but I agree that clarity is important.
BTW - Where would I find the changelogs for these trunks?
I didn't know it was possible to edit a file within a boot image... I'm using MacOS, how would I do that?
I usually just re-plug the sdcard back into my laptop, the fs mounts automatically for me. Using Linux though, no clue about MacOS.
You could use the Cubie for it. The trunk.100 works you said, so you have a working Linux computer, can be operated via serial cable console.
There is a separate boot partiton, it should be there. MACOS same as Windows might hide/block it as it is tagged as not normal filesystem (0x8300) but boot related (0xea00 or 0xef00)
Linux has no issue with it.
This is way too much work. Basically I just came here to say that prebuilt images of trunk 100 work, 130 and 150 don't. So... Just a PSA to let people know that they likely won't be able to use those prebuilt images.
It's probably moot anyway as I expect there aren't any changes that fix the main issues.
--> (667) DEBUG: Partition table after write_uboot [ /dev/loop0 ]
--> (667) COMMAND: sfdisk -l /dev/loop0
   The primary GPT table is corrupt, but the backup appears OK, so that will be used.
   Disk /dev/loop0: 2.37 GiB, 2541748224 bytes, 4964352 sectors
   Units: sectors of 1 * 512 = 512 bytes
   Sector size (logical/physical): 512 bytes / 512 bytes
   I/O size (minimum/optimal): 512 bytes / 512 bytes
   Disklabel type: gpt
   Disk identifier: 62C4432A-F158-49BE-8F59-F5A5895C7057
   Device         Start     End Sectors  Size Type
   /dev/loop0p1    8192 1056767 1048576  512M Linux extended boot
   /dev/loop0p2 1056768 4962303 3905536  1.9G Linux root (ARM-64)
This is what the image looks while still on loop dev just before detaching from. But for some reason its messed up right after. Don't know why...yet
root@build:~/build/output/images# parted Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a5e_trixie_edge_6.18.2_minimal.img u b p
Error: /root/build/output/images/Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a5e_trixie_edge_6.18.2_minimal.img: unrecognised disk label
Model:  (file)
Disk /root/build/output/images/Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a5e_trixie_edge_6.18.2_minimal.img: 2541748224B
Sector size (logical/physical): 512B/512B
Partition Table: unknown
Disk Flags:
That fixed the image writing error, and it does boot. However, it also crashes with a kernel panic...
radxa-cubie-a5e login: root
Password:
    _             _    _                             __  __ _    _      _
   /_\  _ _ _ __ | |__(_)__ _ _ _ ___ _  _ _ _  ___ / _|/ _(_)__(_)__ _| |
  / _ \| '_| '  \| '_ \ / _` | ' \___| || | ' \/ _ \  _|  _| / _| / _` | |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|   \_,_|_||_\___/_| |_| |_\__|_\__,_|_|
 v26.02 rolling for radxa cubie a5e running Armbian Linux 6.18.2-edge-sunxi64
 Packages:     Debian stable (trixie)
 Support:      DIY (custom image)
 IPv4:         (LAN) 192.168.1.29 (WAN) 75.159.194.201
 IPv6:         2001:56a:7490:ce00:1010:b0ff:fe32:6e82 (WAN) 2001:56a:7490:ce00:50a4:a426:bd37:13c8
 Performance:
 Load:         14%               Uptime:       3 minutes
 Memory usage: 7% of 1.93G
 CPU temp:     39°C              Usage of /:   3% of 58G
 Commands:
 Configuration : armbian-config
 Monitoring    : htop
root@radxa-cubie-a5e:~# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
mmcblk0     179:0    0  59.5G  0 disk
������mmcblk0p1 179:1    0   512M  0 part /boot
������mmcblk0p2 179:2    0  58.4G  0 part /var/log.hdd
zram0       254:0    0 989.2M  0 disk [SWAP]
zram1       254:1    0    50M  0 disk /var/log
zram2       254:2    0     0B  0 disk
root@radxa-cubie-a5e:~# INFO: task rfkill:1190 blocked for more than 120 seconds.
      Tainted: G           O        6.18.2-edge-sunxi64 #17
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
task:rfkill          state:D stack:0     pid:1190  tgid:1190  ppid:1      task_flags:0x400100 flags:0x00000019
Call trace:
 __switch_to+0xcc/0x178 (T)
 __schedule+0x328/0x948
 schedule+0x30/0x100
 schedule_timeout+0xc4/0xd4
 wait_for_completion+0x84/0x144
 mmc_wait_for_req_done+0x68/0x94
 mmc_wait_for_req+0xa4/0xec
 mmc_wait_for_cmd+0x50/0x6c
 mmc_io_rw_direct+0x88/0x110
 sdio_release_irq+0x6c/0x120
 aicbsp_sdio_release+0x28/0x78 [aic8800_bsp]
 aicbsp_set_subsys+0x264/0x28c [aic8800_bsp]
 bluetooth_set_power+0x3c/0x70 [aic8800_btlpm]
 rfkill_set_block+0x8c/0x16c [rfkill]
 rfkill_fop_write+0x118/0x20c [rfkill]
 vfs_write+0xbc/0x350
 ksys_write+0xc0/0xe0
 __arm64_sys_write+0x18/0x20
 invoke_syscall.constprop.0+0x4c/0xd8
 do_el0_svc+0x3c/0xb8
 el0_svc+0x38/0x140
 el0t_64_sync_handler+0x98/0xdc
 el0t_64_sync+0x170/0x174
Kernel panic - not syncing: hung_task: blocked tasks
CPU: 5 UID: 0 PID: 60 Comm: khungtaskd Tainted: G           O        6.18.2-edge-sunxi64 #17 PREEMPT
Tainted: [O]=OOT_MODULE
Hardware name: Radxa Cubie A5E (DT)
Call trace:
 show_stack+0x14/0x1c (C)
 dump_stack_lvl+0x30/0x80
 dump_stack+0x14/0x1c
 vpanic+0x2cc/0x2f8
 nmi_panic+0x0/0x5c
 watchdog+0x274/0x6bc
 kthread+0x114/0x1cc
 ret_from_fork+0x10/0x20
SMP: stopping secondary CPUs
Kernel Offset: disabled
CPU features: 0x080000,00008000,48006281,0400701b
Memory Limit: none
---[ end Kernel panic - not syncing: hung_task: blocked tasks ]---
Here's the 1st part of the boot log:
U-Boot SPL 2026.01-rc5_armbian-2026.01-rc5-S0f6f-Peafc-He0b4-V2edd-B4d1d-R448a (Dec 30 2025 - 18:27:43 +0000)
DRAM: 2048 MiB
NOTICE:  BL31: v2.13.0(debug):armbian
NOTICE:  BL31: Built : 17:24:26, Dec 30 2025
NOTICE:  BL31: Found U-Boot DTB at 0xa0ab958, model: Radxa Cubie A5E
INFO:    SPSR = 0x3c9
U-Boot 2026.01-rc5_armbian-2026.01-rc5-S0f6f-Peafc-He0b4-V2edd-B4d1d-R448a (Dec 30 2025 - 18:27:43 +0000) Allwinner Technology
DRAM:  2 GiB
MMC:   mmc@4020000: 0
In:    serial@2500000
Out:   serial@2500000
Err:   serial@2500000
starting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Scanning mmc 0:1...
239 bytes read in 1 ms (233.4 KiB/s)
Failed to load '/dtb/allwinner/overlay/sun55i-a527-fixup.scr'
15461313 bytes read in 642 ms (23 MiB/s)
31652352 bytes read in 1311 ms (23 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42120000
   Image Name:   uInitrd
   Data Size:    15461249 Bytes = 14.7 MiB
   Loading Ramdisk to 49141000, end 49fffb81 ... OK
   Loading Device Tree to 00000000490d0000, end 0000000049140fff ... OK
Working FDT set to 490d0000
Starting kernel ...
Booting Linux on physical CPU 0x0000000000 [0x412fd050]
Linux version 6.18.2-edge-sunxi64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #17 SMP PREEMPT Thu Dec 18 13:03:43 UTC 2025
KASLR disabled due to lack of seed
Machine model: Radxa Cubie A5E
efi: UEFI not found.
OF: reserved mem: Reserved memory: No reserved-memory node in the DT
Zone ranges:
  DMA      [mem 0x0000000040000000-0x00000000bfffffff]
  DMA32    empty
  Normal   empty
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x0000000040000000-0x00000000bfffffff]
Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
cma: Reserved 64 MiB at 0x00000000b9800000
psci: probing for conduit method from DT.
psci: PSCIv1.1 detected in firmware.
psci: Using standard PSCI v0.2 function IDs
psci: MIGRATE_INFO_TYPE not supported.
psci: SMC Calling Convention v1.5
percpu: Embedded 24 pages/cpu s58712 r8192 d31400 u98304
Detected VIPT I-cache on CPU0
CPU features: detected: GICv3 CPU interface
CPU features: detected: Virtualization Host Extensions
CPU features: detected: ARM errata 1165522, 1319367, or 1530923
alternatives: applying boot alternatives
Kernel command line: root=UUID=2782653c-c693-428c-b157-01071e773e18 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=7 ubootpart=3633d9eb-8271-425a-9e37-7ba36a001dbc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory
Unknown kernel command line parameters "splash=verbose ubootpart=3633d9eb-8271-425a-9e37-7ba36a001dbc cgroup_enable=memory", will be passed to user space.
printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
software IO TLB: area num 8.
software IO TLB: mapped [mem 0x00000000b9600000-0x00000000b9800000] (2MB)
Built 1 zonelists, mobility grouping on.  Total pages: 524288
mem auto-init: stack:all(zero), heap alloc:off, heap free:off
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
rcu: Preemptible hierarchical RCU implementation.
        Trampoline variant of Tasks RCU enabled.
        Tracing variant of Tasks RCU enabled.
rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
GIC: enabling workaround for GICv3: non-coherent attribute
GICv3: GIC: Using split EOI/Deactivate mode
GICv3: 256 SPIs implemented
GICv3: 0 Extended SPIs implemented
Root IRQ handler: gic_handle_irq
GICv3: GICv3 features: 16 PPIs
GICv3: GICD_CTLR.DS=0, SCR_EL3.FIQ=0
GICv3: CPU0: found redistributor 0 region 0:0x0000000003460000
ITS [mem 0x03440000-0x0345ffff]
GIC: enabling workaround for ITS: non-coherent attribute
ITS@0x0000000003440000: allocated 8192 Devices @42470000 (indirect, esz 8, psz 64K, shr 0)
ITS@0x0000000003440000: allocated 32768 Interrupt Collections @42480000 (flat, esz 2, psz 64K, shr 0)
ITS: using cache flushing for cmd queue
GICv3: using LPI property table @0x0000000042490000
GIC: using cache flushing for LPI property table
GICv3: CPU0: using allocated LPI pending table @0x00000000424a0000
rcu: srcu_init: Setting srcu_struct sizes based on contention.
arch_timer: cp15 timer running at 24.00MHz (phys).
clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Console: colour dummy device 80x25
printk: legacy console [tty1] enabled
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
pid_max: default: 32768 minimum: 301
LSM: initializing lsm=capability,yama,selinux,tomoyo
Yama: becoming mindful.
SELinux:  Initializing.
TOMOYO Linux initialized
Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
cacheinfo: Unable to detect cache hierarchy for CPU 0
rcu: Hierarchical SRCU implementation.
rcu:    Max phase no-delay instances is 1000.
Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
EFI services will not be available.
smp: Bringing up secondary CPUs ...
Detected VIPT I-cache on CPU1
GICv3: CPU1: found redistributor 100 region 0:0x0000000003480000
GICv3: CPU1: using allocated LPI pending table @0x00000000424b0000
CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
Detected VIPT I-cache on CPU2
GICv3: CPU2: found redistributor 200 region 0:0x00000000034a0000
GICv3: CPU2: using allocated LPI pending table @0x00000000424c0000
CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
Detected VIPT I-cache on CPU3
GICv3: CPU3: found redistributor 300 region 0:0x00000000034c0000
GICv3: CPU3: using allocated LPI pending table @0x00000000424d0000
CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
Detected VIPT I-cache on CPU4
GICv3: CPU4: found redistributor 400 region 0:0x00000000034e0000
GICv3: CPU4: using allocated LPI pending table @0x00000000424e0000
CPU4: Booted secondary processor 0x0000000400 [0x412fd050]
Detected VIPT I-cache on CPU5
GICv3: CPU5: found redistributor 500 region 0:0x0000000003500000
GICv3: CPU5: using allocated LPI pending table @0x00000000424f0000
CPU5: Booted secondary processor 0x0000000500 [0x412fd050]
Detected VIPT I-cache on CPU6
GICv3: CPU6: found redistributor 600 region 0:0x0000000003520000
GICv3: CPU6: using allocated LPI pending table @0x0000000042500000
CPU6: Booted secondary processor 0x0000000600 [0x412fd050]
Detected VIPT I-cache on CPU7
GICv3: CPU7: found redistributor 700 region 0:0x0000000003540000
GICv3: CPU7: using allocated LPI pending table @0x0000000042510000
CPU7: Booted secondary processor 0x0000000700 [0x412fd050]
smp: Brought up 1 node, 8 CPUs
SMP: Total of 8 processors activated.
CPU: All CPU(s) started at EL2
CPU features: detected: 32-bit EL0 Support
CPU features: detected: 32-bit EL1 Support
CPU features: detected: Data cache clean to the PoU not required for I/D coherence
CPU features: detected: Common not Private translations
CPU features: detected: CRC32 instructions
CPU features: detected: RCpc load-acquire (LDAPR)
CPU features: detected: LSE atomic instructions
CPU features: detected: Privileged Access Never
CPU features: detected: PMUv3
CPU features: detected: Speculative Store Bypassing Safe (SSBS)
alternatives: applying system-wide alternatives
Memory: 1936768K/2097152K available (15040K kernel code, 1534K rwdata, 10588K rodata, 3584K init, 854K bss, 90016K reserved, 65536K cma-reserved)
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
posixtimers hash table entries: 4096 (order: 4, 65536 bytes, linear)
futex hash table entries: 2048 (131072 bytes on 1 NUMA nodes, total 128 KiB, linear).
24800 pages in range for non-PLT usage
516320 pages in range for PLT usage
pinctrl core: initialized pinctrl subsystem
DMI not present or invalid.
NET: Registered PF_NETLINK/PF_ROUTE protocol family
DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1
thermal_sys: Registered thermal governor 'fair_share'
thermal_sys: Registered thermal governor 'bang_bang'
thermal_sys: Registered thermal governor 'step_wise'
thermal_sys: Registered thermal governor 'user_space'
cpuidle: using governor ladder
cpuidle: using governor menu
hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
ASID allocator initialised with 65536 entries
/soc/clock-controller@2001000: Fixed dependency cycle(s) with /soc/rtc@7090000
/soc/interrupt-controller@3400000: Fixed dependency cycle(s) with /soc/interrupt-controller@3400000
/soc/clock-controller@7010000: Fixed dependency cycle(s) with /soc/clock-controller@2001000
/soc/clock-controller@7010000: Fixed dependency cycle(s) with /soc/rtc@7090000
/soc/rtc@7090000: Fixed dependency cycle(s) with /soc/clock-controller@7010000
/soc/i2c@7081400: Fixed dependency cycle(s) with /soc/pinctrl@7022000/r-i2c-pins
raid6: neonx8   gen()  1457 MB/s
raid6: neonx4   gen()  1429 MB/s
raid6: neonx2   gen()  1399 MB/s
raid6: neonx1   gen()  1218 MB/s
raid6: int64x8  gen()   911 MB/s
raid6: int64x4  gen()  1004 MB/s
raid6: int64x2  gen()   959 MB/s
raid6: int64x1  gen()   746 MB/s
raid6: using algorithm neonx8 gen() 1457 MB/s
raid6: .... xor() 1086 MB/s, rmw enabled
raid6: using neon recovery algorithm
fbcon: Taking over console
iommu: Default domain type: Translated
iommu: DMA domain TLB invalidation policy: strict mode
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
mc: Linux media interface: v0.10
videodev: Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
NetLabel: Initializing
NetLabel:  domain hash size = 128
NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
NetLabel:  unlabeled traffic allowed by default
mctp: management component transport protocol core
NET: Registered PF_MCTP protocol family
vgaarb: loaded
clocksource: Switched to clocksource arch_sys_counter
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
netfs: FS-Cache loaded
CacheFiles: Loaded
NET: Registered PF_INET protocol family
IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
TCP: Hash tables configured (established 16384 bind 16384)
UDP hash table entries: 1024 (order: 4, 65536 bytes, linear)
UDP-Lite hash table entries: 1024 (order: 4, 65536 bytes, linear)
NET: Registered PF_UNIX/PF_LOCAL protocol family
NET: Registered PF_XDP protocol family
PCI: CLS 0 bytes, default 64
Unpacking initramfs...
kvm [1]: nv: 568 coarse grained trap handlers
kvm [1]: IPA Size Limit: 40 bits
kvm [1]: GICv3: no GICV resource entry
kvm [1]: disabling GICv2 emulation
kvm [1]: GIC system register CPU interface enabled
kvm [1]: vgic interrupt IRQ9
kvm [1]: VHE mode initialized successfully
Initialise system trusted keyrings
workingset: timestamp_bits=46 max_order=19 bucket_order=0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
SGI XFS with ACLs, security attributes, scrub, repair, no debug enabled
cryptd: max_cpu_qlen set to 1000
NET: Registered PF_ALG protocol family
xor: automatically using best checksumming function   32regs
Key type asymmetric registered
Asymmetric key parser 'x509' registered
Asymmetric key parser 'pkcs8' registered
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
io scheduler mq-deadline registered
io scheduler bfq registered
ledtrig-cpu: registered to indicate activity on CPUs
Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
misc dump reg init
loop: module loaded
wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
tun: Universal TUN/TAP device driver, 1.6
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered PF_PPPOX protocol family
usbcore: registered new interface driver usblp
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
sun6i-rtc 7090000.rtc: registered as rtc0
sun6i-rtc 7090000.rtc: setting system clock to 1970-01-02T00:00:07 UTC (86407)
i2c_dev: i2c /dev entries driver
usbcore: registered new interface driver uvcvideo
Driver for 1-wire Dallas network protocol.
sunxi-wdt 2050000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
SMCCC: SOC_ID: ID = jep106:091e:1890 Revision = 0x00000002
hid: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available
gnss: GNSS driver registered with major 238
usbcore: registered new interface driver snd-usb-audio
NET: Registered PF_INET6 protocol family
Segment Routing with IPv6
In-situ OAM (IOAM) with IPv6
NET: Registered PF_PACKET protocol family
bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
8021q: 802.1Q VLAN Support v1.8
9pnet: Installing 9P2000 support
Key type dns_resolver registered
registered taskstats version 1
Loading compiled-in X.509 certificates
zswap: loaded using pool lzo
Key type .fscrypt registered
Key type fscrypt-provisioning registered
Btrfs loaded, zoned=no, fsverity=no
Key type encrypted registered
gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
sun55i-a523-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
sun55i-a523-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
axp20x-i2c 0-0034: AXP20x variant AXP717 found
input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0034/axp20x-pek/input/input0
platform axp717-adc: DMA mask not set
platform axp20x-usb-power-supply: DMA mask not set
axp20x-i2c 0-0034: AXP20X driver loaded
axp20x-i2c 0-0036: AXP20x variant AXP323 found
axp20x-i2c 0-0036: AXP20X driver loaded
vcc-mipi-cam: Bringing 2800000uV into 3300000-3300000uV
thermal_sys: No trip points found for thermal-sensor id=2
gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
sun55i-a523-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
printk: legacy console [ttyS0] disabled
2500000.serial: ttyS0 at MMIO 0x2500000 (irq = 466, base_baud = 1500000) is a 16550A
printk: legacy console [ttyS0] enabled
Freeing initrd memory: 15096K
2500400.serial: ttyS1 at MMIO 0x2500400 (irq = 467, base_baud = 1500000) is a 16550A
dwmac-sun8i 4500000.ethernet: IRQ eth_wake_irq not found
dwmac-sun8i 4500000.ethernet: IRQ eth_lpi not found
dwmac-sun8i 4500000.ethernet: IRQ sfty not found
dwmac-sun8i 4500000.ethernet: supply phy-io not found, using dummy regulator
dwmac-sun8i 4500000.ethernet: PTP uses main clock
dwmac-sun8i 4500000.ethernet: No HW DMA feature register supported
dwmac-sun8i 4500000.ethernet: RX Checksum Offload Engine supported
dwmac-sun8i 4500000.ethernet: COE Type 2
dwmac-sun8i 4500000.ethernet: TX Checksum insertion supported
dwmac-sun8i 4500000.ethernet: Normal descriptors
dwmac-sun8i 4500000.ethernet: Chain mode enabled
dwmac-sun55i 4510000.ethernet: IRQ eth_wake_irq not found
dwmac-sun55i 4510000.ethernet: IRQ eth_lpi not found
dwmac-sun55i 4510000.ethernet: IRQ sfty not found
dwmac-sun55i 4510000.ethernet: PTP uses main clock
dwmac-sun55i 4510000.ethernet: User ID: 0x20, Synopsys ID: 0x52
dwmac-sun55i 4510000.ethernet:  DWMAC4/5
dwmac-sun55i 4510000.ethernet: DMA HW capability register supported
dwmac-sun55i 4510000.ethernet: RX Checksum Offload Engine supported
dwmac-sun55i 4510000.ethernet: TX Checksum insertion supported
dwmac-sun55i 4510000.ethernet: Enable RX Mitigation via HW Watchdog Timer
dwmac-sun55i 4510000.ethernet: Enabled RFS Flow TC (entries=10)
dwmac-sun55i 4510000.ethernet: Using 32/40 bits DMA host/device width
sunxi-mmc 4020000.mmc: Got CD GPIO
phy phy-4100400.phy.0: Changing dr_mode to 1
ehci-platform 4200000.usb: EHCI Host Controller
ehci-platform 4200000.usb: new USB bus registered, assigned bus number 1
WCN: marlin_init entry!
ohci-platform 4200400.usb: Generic Platform OHCI controller
ohci-platform 4200400.usb: new USB bus registered, assigned bus number 2
WCN: wcn config bt wake host
ehci-platform 4200000.usb: irq 473, io mem 0x04200000
ohci-platform 4200400.usb: irq 475, io mem 0x04200400
WCN_ERR: dts node for bt_wake not found
WCN: marlin2 parse_dt some para not config
sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
sdiohal:sdiohal_init ok
ohci-platform 4101400.usb: Generic Platform OHCI controller
ehci-platform 4101000.usb: EHCI Host Controller
ehci-platform 4101000.usb: new USB bus registered, assigned bus number 3
ehci-platform 4101000.usb: irq 472, io mem 0x04101000
WCN: marlin_probe ok!
ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 6.18.2-edge-sunxi64 ehci_hcd
usb usb1: SerialNumber: 4200000.usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci-platform 4101400.usb: new USB bus registered, assigned bus number 4
sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
ehci-platform 4101000.usb: USB 2.0 started, EHCI 1.00
ohci-platform 4101400.usb: irq 474, io mem 0x04101400
sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
mmc1: new high speed SDIO card at address 390b
usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
mmc0: host does not support reading read-only switch, assuming write-enable
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
mmc0: new high speed SDXC card at address aaaa
clk: Disabling unused clocks
PM: genpd: Disabling unused power domains
ALSA device list:
  No soundcards found.
usb usb3: Product: EHCI Host Controller
mmcblk0: mmc0:aaaa SR64G 59.5 GiB
usb usb3: Manufacturer: Linux 6.18.2-edge-sunxi64 ehci_hcd
 mmcblk0: p1 p2
usb usb3: SerialNumber: 4101000.usb
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.18
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Generic Platform OHCI controller
usb usb2: Manufacturer: Linux 6.18.2-edge-sunxi64 ohci_hcd
usb usb2: SerialNumber: 4200400.usb
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.18
usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb4: Product: Generic Platform OHCI controller
usb usb4: Manufacturer: Linux 6.18.2-edge-sunxi64 ohci_hcd
usb usb4: SerialNumber: 4101400.usb
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
Freeing unused kernel memory: 3584K
Run /init as init process
usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests (id=vbus)
dwmac-sun55i 4510000.ethernet end1: renamed from eth1
dwmac-sun8i 4500000.ethernet end0: renamed from eth0
EXT4-fs (mmcblk0p2): mounted filesystem 2782653c-c693-428c-b157-01071e773e18 ro with writeback data mode. Quota mode: none.
Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
systemd[1]: System time advanced to timestamp on /var/lib/systemd/timesync/clock: Tue 2025-12-30 19:26:57 UTC
systemd[1]: systemd 257.9-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
systemd[1]: Detected architecture arm64.
systemd[1]: Hostname set to <radxa-cubie-a5e>.
systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
systemd[1]: Queued start job for default target graphical.target.
systemd[1]: Created slice system-getty.slice - Slice /system/getty.
systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
systemd[1]: Created slice user.slice - User and Session Slice.
systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
systemd[1]: Expecting device dev-disk-by\x2duuid-C2FC\x2d76E8.device - /dev/disk/by-uuid/C2FC-76E8...
systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
systemd[1]: Reached target paths.target - Path Units.
systemd[1]: Reached target remote-fs.target - Remote File Systems.
systemd[1]: Reached target slices.target - Slice Units.
systemd[1]: Reached target swap.target - Swaps.
systemd[1]: Listening on syslog.socket - Syslog Socket.
systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl).
systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
fuse: init (API version 7.45)
systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
systemd[1]: fake-hwclock-load.service: Deactivated successfully.
systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
systemd[1]: modprobe@configfs.service: Deactivated successfully.
systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
systemd[1]: modprobe@drm.service: Deactivated successfully.
systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
Bluetooth: Core ver 2.22
systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
NET: Registered PF_BLUETOOTH protocol family
Bluetooth: HCI device and connection manager initialized
systemd[1]: modprobe@fuse.service: Deactivated successfully.
Bluetooth: HCI socket layer initialized
systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
systemd[1]: Finished systemd-network-generator.service - Generate network units from Kernel command line.
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
Bluetooth: RFCOMM TTY layer initialized
systemd[1]: Reached target network-pre.target - Preparation for Network.
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
aic8800_bsp: loading out-of-tree module taints kernel.
systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
-->rfkill_bluetooth_init
bluetooth_set_power: start_block=1
bluetooth_set_power: end_block=1
<--rfkill_bluetooth_init
systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
EXT4-fs (mmcblk0p2): re-mounted 2782653c-c693-428c-b157-01071e773e18 r/w.
systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
systemd[1]: Starting systemd-resolved.service - Network Name Resolution...
systemd[1]: Starting systemd-timesyncd.service - Network Time Synchronization...
systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
systemd[1]: Started systemd-timesyncd.service - Network Time Synchronization.
systemd[1]: Reached target time-set.target - System Time Set.
systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
systemd[1]: Mounting tmp.mount - /tmp...
systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
systemd[1]: Starting systemd-networkd.service - Network Configuration...
systemd[1]: Mounted tmp.mount - /tmp.
systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
random: crng init done
systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
panfrost 1800000.gpu: clock rate = 432000000
panfrost 1800000.gpu: bus_clock rate = 200000000
panfrost 1800000.gpu: mali-g57 id 0x9091 major 0x0 minor 0x1 status 0x0
panfrost 1800000.gpu: features: 00000000,000019f7, issues: 00000001,80000400
panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
panfrost 1800000.gpu: shader_present=0x1 l2_present=0x1
systemd[1]: Started systemd-resolved.service - Network Name Resolution.
[drm] Initialized panfrost 1.4.0 for 1800000.gpu on minor 0
systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups.
cfg80211: Loading compiled-in X.509 certificates for regulatory database
Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
systemd[1]: Found device dev-disk-by\x2duuid-C2FC\x2d76E8.device - /dev/disk/by-uuid/C2FC-76E8.
systemd[1]: Starting systemd-fsck@dev-disk-by\x2duuid-C2FC\x2d76E8.service - File System Check on /dev/disk/by-uuid/C2FC-76E8...
systemd[1]: Started systemd-networkd.service - Network Configuration.
systemd[1]: Starting systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd...
dwmac-sun55i 4510000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
dwmac-sun55i 4510000.ethernet end1: PHY [stmmac-1:01] driver [Generic PHY] (irq=POLL)
sunxi-mmc 4021000.mmc: data error, sending stop command
aicbsp: sdio_err:<aicwf_sdio_tx_msg,996>: aicwf_sdio_send_pkt fail-110
dwmac4: Master AXI performs fixed burst length
aicbsp: sdio_err:<aicwf_sdio_bus_txmsg,1140>: send faild:0, 0,4de
dwmac-sun55i 4510000.ethernet end1: No Safety Features support found
dwmac-sun55i 4510000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported
dwmac-sun55i 4510000.ethernet end1: registered PTP clock
dwmac-sun55i 4510000.ethernet end1: configuring for phy/rgmii-id link mode
8021q: adding VLAN 0 to HW filter on device end1
dwmac-sun8i 4500000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
dwmac-sun8i 4500000.ethernet end0: PHY [stmmac-0:01] driver [Generic PHY] (irq=POLL)
dwmac-sun8i 4500000.ethernet end0: No Safety Features support found
dwmac-sun8i 4500000.ethernet end0: No MAC Management Counters available
dwmac-sun8i 4500000.ethernet end0: PTP not supported by HW
dwmac-sun8i 4500000.ethernet end0: configuring for phy/rgmii-id link mode
systemd[1]: Finished systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd.
systemd[1]: Finished systemd-fsck@dev-disk-by\x2duuid-C2FC\x2d76E8.service - File System Check on /dev/disk/by-uuid/C2FC-76E8.
systemd[1]: Mounting boot.mount - /boot...
systemd[1]: Mounted boot.mount - /boot.
systemd[1]: Reached target local-fs.target - Local File Systems.
systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management.
systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
systemd[1]: Starting console-setup.service - Set console font and keymap...
systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
systemd[1]: Finished console-setup.service - Set console font and keymap.
systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 328 (systemd-binfmt)
systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
zram: Added device: zram0
zram: Added device: zram1
zram: Added device: zram2
zram0: detected capacity change from 0 to 2025816
Adding 1012904k swap on /dev/zram0.  Priority:5 extents:1 across:1012904k SS
zram1: detected capacity change from 0 to 102400
systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
EXT4-fs (zram1): mounted filesystem 81b9ded1-bf3b-46ee-bb7f-bf31de2b5cdc r/w without journal. Quota mode: none.
systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
systemd[1]: Starting systemd-journald.service - Journal Service...
systemd-journald[416]: Collecting audit messages is disabled.
systemd[1]: Started systemd-journald.service - Journal Service.
systemd-journald[416]: Received client request to flush runtime journal.
---- Closed the serial port /dev/tty.PL2303G-USBtoUART8430 ----
I forget if WiFi is supported yet for this board in Armbian. I know that PCIe/NVME is not, as well as USB3.
Not sure if 2nd Ethernet nic and WiFi is supported yet.
From what I hear, it may be quite some time until a trixie build can be made to support the hardware on this board. Radxa's os is still on Bullseye (which is ridiculous, IMHO)
The userspace is behind, that's not an issue. Hardware support is a kernel thing. If its not there an up-to-date userspace like Forky or Sid means nothing.
