Good morning
I have a BPI M1 and M1+ currently running an image from https://banana-pi.org/. Everything works, except it's Ubuntu 16.04. Since yesterday, I've been testing the Armbian images, which are great and up-to-date, but none of them recognize the SATA connection on my SSD.
fdisk -l
` shows no SATA SSD.
Since I absolutely need this connection, I'm stuck. What am I doing wrong, or where do I need to activate the SATA connection?
The SATA connection is what makes the BPI M1+ unique.
With Ubuntu 16.04, the SATA connection is recognized with both SSD and HDD on the BPI M3.
Can someone please help me? I'm completely lost.
Regards, Henry
Feature regressions are sadly something that happens all the time. There are many variants out there and (part of) Armbian OS is different for every board ... First resolve confusion - do you have M1 (we call it just bananapi) or M3. You mention M3 in the text, while title says M1+. Those are totally different boards.
Proceed from older images and find out when this feature stopped working:
https://fi.mirror.armbian.de/archive/
https://fi.mirror.armbian.de/oldarchive/
For your information, I have a
BPI M1
BPI M1+
BPI M3
All three are currently running Ubuntu 16.04, where SATA works, but it's a very old version. All tests with Armbian were performed using the BPI M1+, although SATA did not work.
BPI M1+ tested with:
Armbian_23.8.1_Bananapim1plus_jammy
Armbian_24.11.1_Bananapi_noble
Armbian_26.2.0-trunk.342_Bananapi_noble
and the SATA interface doesn't work on any of the three.
Does nobody use a BPI M1+ with an Armbian image where the SATA interface works?
fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 14.84 GiB, 15931539456 bytes, 31116288 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x4c58faaa
Device         Boot Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       8192 30801920 30793729 14.7G 83 Linux
Disk /dev/zram0: 483.1 MiB, 506564608 bytes, 123673 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 50 MiB, 52428800 bytes, 12800 sectors
Out of desperation, I plugged in an SSD via USB adapter, and it is recognized as:
/dev/sda:
Detected
One might think the SATA connection is defective, but when I boot with the Ubuntu 16.04 image without changing anything, the SATA SSD is recognized! So the SATA connection on the BPI M1+ works, and so does the SSD. It's definitely the Armbian image that's the problem, but where exactly is it?
Probably, my guess, issue with a boot loader - fail to / disabled by mistake power SATA port? We don't have anyone actively maintaining this kind of (10+years) hardware anymore. Support is "community / upstream" maintained "as is". But this forum / community can provide assistance to fix this. I gave a tip - where I think is the problem.
Not working feature on particular hardware is not Armbian problem. This is custom hardware world and our work is tooling https://github.com/armbian/build and best effort hardware maintenance on this principle https://docs.armbian.com/User-Guide_Board-Support-Rules/ If we try to fix everything, everyone would be long burned out ...
