H3 custom board usb error
ozhvankov
Hi All!
does anyone know how to resolve next error
My custom board  based on h3 this is oem china's set-top box
right now Im used Beelink X2 for build image
for some resone i need mainline kernel
but if i buld image with mainline or dev
I get the scoring result
Quote
U-Boot 2017.11-armbian (Nov 27 2017 - 20:54:33 +0300) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Beelink X2
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
230454 bytes read in 158 ms (1.4 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 3 for devices... ERROR:  USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did
not provide a handshake (OUT) (5)
unable to get device descriptor (error=-1)
scanning bus 5 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3708 bytes read in 209 ms (16.6 KiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
175 bytes read in 169 ms (1000 Bytes/s)
5807625 bytes read in 756 ms (7.3 MiB/s)
6779416 bytes read in 853 ms (7.6 MiB/s)
Found mainline kernel configuration
31210 bytes read in 616 ms (48.8 KiB/s)
1065 bytes read in 1419 ms (0 Bytes/s)
Applying kernel provided DT overlay sun8i-h3-spdif-out.dtbo
382 bytes read in 1353 ms (0 Bytes/s)
Applying kernel provided DT overlay sun8i-h3-cir.dtbo
4179 bytes read in 1367 ms (2.9 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    5807561 Bytes = 5.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49a76000, end 49fffdc9 ... OK
   reserving fdt memory region: addr=43000000 size=6d000
   Loading Device Tree to 49a06000, end 49a75fff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Loading, please wait...
starting version 229
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
   - Check root= (did the system wait for the right device?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  UUID=c4f45323-542b-4392-86c4-4664a3089878 does not exist.  Dropping to a shell!
Rebooting automatically due to panic= boot argument
[   68.551887] reboot: Restarting system
When I build an image with a legacy kernel
everything works although there is a usb error
but I need a mainline kernel for docker
and I upgrade system to mainline kernel
and usb stop working
tell me where to look or what you can fix !
Thanx
Quote
U-Boot SPL 2017.09-armbian (Nov 22 2017 - 13:56:04)
DRAM: 1024 MiB
Failed to set core voltage! Can't set CPU frequency
Trying to boot from MMC2
U-Boot 2017.09-armbian (Nov 22 2017 - 13:56:04 +0100) Allwinner Technology
Model: Beelink X2
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 1, SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
230454 bytes read in 177 ms (1.2 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
mmc0(part 0) is current device
Scanning mmc 0:1...
3708 bytes read in 175 ms (20.5 KiB/s)
U-boot loaded from eMMC or secondary SD
324 bytes read in 212 ms (1000 Bytes/s)
5699229 bytes read in 753 ms (7.2 MiB/s)
6790944 bytes read in 835 ms (7.8 MiB/s)
31210 bytes read in 326 ms (92.8 KiB/s)
1065 bytes read in 410 ms (2 KiB/s)
382 bytes read in 456 ms (0 Bytes/s)
4179 bytes read in 290 ms (13.7 KiB/s)
   Image Name:   uInitrd
   Data Size:    5699165 Bytes = 5.4 MiB
   Loading Ramdisk to 49a90000, end 49fff65d ... OK
   Loading Device Tree to 49a20000, end 49a8ffff ... OK
Starting kernel ...
Hello Igor !
thanx for U post
I tested many images
for some reson i need
this patch -
@@ -4,7 +4,7 @@
-CONFIG_MMC0_CD_PIN="PH13"
+CONFIG_MMC0_CD_PIN=""
  but every day I build custom image's with different patches
PS thank U for this project - very cool
8 minutes ago, ozhvankov said:
start to build image based on u-boot v2017.11
No. Start to build with build script v2017.11 :) which has a known working configuration based on U-boot v2017.09
Hello again!
maybe i do something wrong ?!
Igor can U give me some simple example what I can to edit ? and how to ?
for build image with main line build script but with 2017.09
rewrite files or something smarter ? )))
thanx
All my attempts did not have a positive result (((
good evening colleagues.
unfortunately I can not solve the problem with yusb
scanning bus 3 for devices ... ERROR: USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did
unable to get device descriptor (error = -1)
1 USB Device (s) found
scanning bus 5 for devices ... 1 USB Device (s) found
        scanning usb for storage devices ... 0 Storage Device (s)
I tried various build scripts
different versions of u-boot
various fex settings
3.4.113 kernel usb work fine
next build (4.13(14)) usb don't work
dev build cant boot
any help???
thanx
