magic_sam Posted February 15 Posted February 15 Dear all, I just received my new NanoPC-T6 Plus from FriendlyElec: https://www.friendlyelec.com/index.php?route=product/product&path=69&product_id=315 I couldn't find a dedicated image for this SBC, is it compatible with the one for the NanoPC T6 LTS (same board, upgraded LPDDR5 RAM) ? https://www.armbian.com/nanopct6-lts/ Best regards, Magic Sam 0 Quote
Werner Posted February 15 Posted February 15 Probably a new product. Images are not compatible unless specifically marked as such. 0 Quote
magic_sam Posted February 21 Author Posted February 21 (edited) Dear @Werner , Thank you very much for your quick reply, and sorry for the delay on my end (I started a new job last week). If this board is not yet compatible with Armbian, then why this article ? EDIT: FriendlyElec's Wiki seems to imply that the board is compatible with Armbian's M6 / T6 and R6 images... https://wiki.friendlyelec.com/wiki/index.php/NanoPC-T6_Plus#Install_OS Best regards, Samuel Edited February 21 by magic_sam 0 Quote
Werner Posted February 21 Posted February 21 1 hour ago, magic_sam said: then why this article ? I don't know, perhaps the author knows. 1 hour ago, magic_sam said: FriendlyElec's Wiki seems to imply that the board is compatible with Armbian's M6 / T6 and R6 images... Try. If it doesn't work, then fe's wiki is misleading. 0 Quote
magic_sam Posted 1 hour ago Author Posted 1 hour ago Dear @Werner , I have just created an issue on Github to keep track of this discussion: https://github.com/armbian/build/issues/9446 Is it safe to try possibly unsupported images on the NanoPC-T6 Plus ? It's a relatively expensive piece of kit and I'd rather not take any chances (new LPDDR5 RAM: possibly new memory timings, etc.) Best regards, Samuel 0 Quote
