Hello everyone.
I encourage you to write these lines after I spend all day reading and trying to solve the problem without success. Knowing that there are other many post about, I write this new that existing ones are already very old and refer to applications and concepts that no longer exist in the latest versions of ARMbian.
The fact is that I bought a new OrangePi Lite with a new SDHC Clase10 (80MBs) SanDisk and basically not I connect to the WIFI 2.4 g connection of my house where work perfectly without any problems other Zero OPI and OPI PC + with ARMbian 5.35 Ubuntu.
The summary problem is it asks me again the password and does not connect. (of course the password is correct).
Expanding the information about the problem:
-To this day (01 Dec 2017) to OPI LITE will install the latest version of the compilation of the RetrorangePi 4.1 using ARMbian 5.35 Ubuntu.
  1. Everything perfect until you try to configure the wifi by the usual channels:
  2. Failure through the execution of the Script in EmuStation.
  3. Failure through the X GUI.
  4. Failure through the virtual terminal with "nmtui" (Network Manager).
  5. Failure through the console with 'nmtui' mode.
Same error for all, finds the correct SSID, asks password, takes a few seconds and returns to show you the window so that you put the correct password.
Then after I thought it would be because of the distribution and tried more things.
-I thought try the latest version ARMbian available at this time "5.35 ARMbian Ubuntu Xenial 3.4.113" in Server and Desktop versions with the same results. I already started to look for the Forum and try without success.
-I have tested by discarding ARMbian 5.35 compilations Ubuntu and RetrorangePi 4.1 which correspond in the OPI PC + and have worked without incident, everything perfect.
-Finally I've tried previous versions 5.25 ARMbian Ubuntu Server and Desktop and connect by GUI and Network Manager (nmtui) without problems.
I could do:
    route -n
    ping 8.8.8.8
    nslookup google.es
    I have also been able to navigate with firefox perfectly.
i.imgur.com/cK24NcC.png
Well, I think that may be enough. I hope you can guide me so that I can connect from the latest version (ARMbian 5.35 Ubuntu) to WIFI and then apply the same arrangement to the RetrorangePi 4.1 compilation.
Thank you very much for your time and patience.
Español Original:
  Reveal hidden contents
Some visited sites:
Hi.
I have been testing with the Image of the RetroPi for OPI Lite and the Desktop image of ARMbian 5.36 and in appearance with the ARMbian it is always connected and with retrorangepi it is very unstable, it connects when you want ...
I find it a scam because in theory RetrOragePi 4.1 is based on the same version of ARMbian (the v5.36), do you think I should configure something?
