Genadi Manoilenko Posted 1 hour ago Posted 1 hour ago (edited) Hello everyone, I am new to Armbian and need some help. I tried to install Armbian 26.2.0-trunk (https://www.armbian.com/nanopi-neo/#collapse-widget-5-0-0-0) on a NanoPi NEO Core SBC. I used Armbian Imager and wrote the latest official image (the only one available) to the SD card. After writing the image, I see only one partition on the SD card named armbi_root. When I insert the card into the device and power it on, nothing happens — there are no boot messages or logs. I think the image is missing a bootloader. So my questions are: 1) If I’m right that the bootloader is missing, how can I add a bootloader to the image? 2) How can I apply OverlayFS to this setup? 3) Do you have a link to a good article or tutorial on these topics? Thanks in advance! Edited 54 minutes ago by Genadi Manoilenko 0 Quote
eselarm Posted 4 minutes ago Posted 4 minutes ago in the root of the rootfs do: find . -name platform_install.sh find . -name u-boot-sunxi-with-spl.bin essentially construct correct dd arguments somethings else might be wrong though, so make sure you have a serial console/debug able with loglevel=7 0 Quote
