Posted (edited)
Wi-Fi works → so the problem is only in GPIO / DTB initialization for Bluetooth
It worked on the older kernel, but now it doesn't 😞....
Supposedly this is the cause, but is it really?
Quote
DTB (device tree) does not configure GPIO reset/power for the UWE5622.
hci_uart cannot initialize the controller → hci0 is not created.
The overlay for BT in mainline 6.x does not yet exist in Trixie.
Result: hciconfig -a and bluetoothctl list show nothing.
armbianmonitor -u
https://paste.armbian.com/uzudezufit
Edited by kris777
Which kernel? Should work on 6.12.y, although I see issues with it on 6.18.y, as there were changes made to that wireless patch set that don't agree with my DTS changes.
In fairness, I haven't checked to see if it works at all regardless of my changes on that kernel though. Its on my list of things to investigate.
The new DTS changes require an updated hciattach_opi binary. "known to work on 6.12.y"
https://github.com/armbian/build/blob/main/packages/blobs/bt/hciattach/hciattach_opi_arm64_upstream
Welcome to Armbian!
Documentation: https://docs.armbian.com | Community support: https://forum.armbian.com
IP address: xx.x.x.xx
Create root password: *****
Repeat root password: *****
Developer Preview Build
This Armbian image was generated automatically for development and testing purpose.
It may include unfinished features or unstable components.
If you are not here to report issues or just test it, please do not use this image in production.
Expect things to change — or even break — as improvements are made.
Creating a new user account. Press <Ctrl-C> to abort
Please provide a username (eg. your first name):
Disabling user account creation procedure
root@orangepi3-lts:~# rfkill
ID TYPE      DEVICE         SOFT      HARD
 0 bluetooth bluetooth unblocked unblocked
 1 wlan      phy0      unblocked unblocked
 2 bluetooth hci0      unblocked unblocked
root@orangepi3-lts:~# bluetoothctl
[NEW] Media /org/bluez/hci0
	SupportedUUIDs: 0000110a-0000-1000-8000-00805f9b34fb
	SupportedUUIDs: 0000110b-0000-1000-8000-00805f9b34fb
Agent registered
[CHG] Controller 30:96:18:9E:A7:02 Pairable: yes
hci0 new_settings: powered bondable ssp br/edr le secure-conn
[bluetoothctl]> show
Controller 30:96:18:9E:A7:02 (public)
	Manufacturer: 0x01ec (492)
	Version: 0x09 (9)
	Alias: orangepi3-lts
	Class: 0x00400000 (4194304)
	Powered: yes
	PowerState: on
	Discoverable: no
	DiscoverableTimeout: 0x000000b4 (180)
	Pairable: yes
	UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
	UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
	UUID: SIM Access                (0000112d-0000-1000-8000-00805f9b34fb)
	UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
	UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
	UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
	UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
	Modalias: usb:v1D6Bp0246d0554
	Discovering: no
	Roles: central
	Roles: peripheral
Advertising Features:
	ActiveInstances: 0x00 (0)
	SupportedInstances: 0x10 (16)
	SupportedIncludes: tx-power
	SupportedIncludes: appearance
	SupportedIncludes: local-name
	SupportedSecondaryChannels: 1M
	SupportedSecondaryChannels: 2M
	SupportedSecondaryChannels: Coded
	SupportedCapabilities.MinTxPower: 0xffffffec (-20)
	SupportedCapabilities.MaxTxPower: 0x0008 (8)
	SupportedCapabilities.MaxAdvLen: 0xfb (251)
	SupportedCapabilities.MaxScnRspLen: 0xfb (251)
	SupportedFeatures: CanSetTxPower
	SupportedFeatures: HardwareOffload
[bluetoothctl]> exit
root@orangepi3-lts:~# uname -a
Linux orangepi3-lts 6.12.74-current-sunxi64 #6 SMP Thu Feb 19 15:29:56 UTC 2026 aarch64 GNU/Linux
Posted (edited)
That's strange  🙂 ...we have the same kernel. Maybe something's broken in the system? But I haven't messed with Bluetooth in the system. I've only updated the system: apt update /apt upgrade /reboot 🙂
bluetoothctl
Waiting to connect to bluetoothd...
it keeps reading but shows nothing?
 bt-device -l
ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self))
Bail out! ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self))
Aborted
Something must have broken in the system, but what and where?
Can you give me the exact: Armbian image + version ...
Contents of ..../lib/firmware/uwe5622/
also: armbianEnv.txt
Output dmesg | grep -i uart i dmesg | grep -i bluetooth
Maybe that will help me figure out where the errors are in my system? Or maybe I have Debian and you have Ubuntu?
Ps. or, more simply, information from the file: diagnostics.txt
command in terminal:
uname -a
cat /etc/os-release
ls -lh /lib/firmware/uwe5622/
lsmod | grep -iE "bt|sprd|uwe"
ls /dev/tty* | grep -i "ttyS\|ttyAMA\|ttyBT"
cat /boot/armbianEnv.txt
rfkill list
hciconfig -a
bluetoothctl list
hcitool dev
bt-device -l
dmesg | grep -iE "bluetooth|uwe|sprd|hci"
) > diagnostics.txt
Edited by kris777
Posted (edited)
I tested the new version (Armbian_26.2.0-trunk.591_Orangepi3-lts_forky_current_6.18.18_minimal) in terms of bloototh and it's OK... but there are errors that rule out this image. Namely, the system lacks 4 working processor cores 🙂 ... only one. Something is wrong at startup because the green LED is on and the red LED is constantly flashing/pulsing.
Bringing up secondary CPUs ...
[ 5.092655] CPU1: failed to come online [ 5.092666] CPU1: failed in unknown state : 0x0
[ 10.217311] CPU2: failed to come online [ 10.217324] CPU2: failed in unknown state : 0x0
[ 15.341948] CPU3: failed to come online [ 15.341961] CPU3: failed in unknown state : 0x0
[ 15.342047] smp: Brought up 1 node, 1 CPU [ 15.342057] SMP: Total of 1 processors activated.
[ 15.342063] CPU: All CPU(s) started at EL2
[ 15.342112] CPU features: detected: 32-bit EL0 Support
[ 15.342119] CPU features: detected: 32-bit EL1 Support
[ 15.342129] CPU features: detected: CRC32 instructions
[ 15.342146] CPU features: detected: PMUv3
[ 15.342193] alternatives: applying system-wide alternatives
It's some kind of incompatibility: U-Boot / TF-A / kernel  ....
Similar errors are found in the version uploaded by: armbian imager (minimal / cli / debian - trixie) more information: https://paste.armbian.com/afokonucej
command "poweroff" not working ! ?
On version: Ubuntu / minimal (cli) there are the same errors regarding CPU...etc
dmesg | grep "CPU"
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.006129] smp: Bringing up secondary CPUs ...
[    5.092344] CPU1: failed to come online
[    5.092356] CPU1: failed in unknown state : 0x0
[   10.216761] CPU2: failed to come online
[   10.216771] CPU2: failed in unknown state : 0x0
[   15.341165] CPU3: failed to come online
[   15.341176] CPU3: failed in unknown state : 0x0
[   15.341242] smp: Brought up 1 node, 1 CPU
[   15.341258] CPU: All CPU(s) started at EL2
[   15.341291] CPU features: detected: 32-bit EL0 Support
[   15.341297] CPU features: detected: 32-bit EL1 Support
[   15.341309] CPU features: detected: CRC32 instructions
[   16.273971] ledtrig-cpu: registered to indicate activity on CPUs
[   17.351303] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
Edited by kris777
