ManeeshaC Posted March 8 Posted March 8 BOARD - Orange Pi 5 Pro PROBLEM Device Tree overlays defined in armbianEnv.txt are not being applied during boot. The overlay file exists but is not loaded by the system. verbosity=1 bootlogo=false console=both extraargs=cma=256M fdtfile=rockchip/rk3588s-orangepi-5-pro.dtb rootdev=UUID=a8beb1c4-8079-4e64-8216-8e893f7809d4 rootfstype=ext4 overlays=orangepi-5-pro-disable-leds usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u I also tried with overlay_prefix=rockchip overlays=orangepi-5-pro-disable-leds The Kernel is Linux orangepi5pro 6.1.115-vendor-rk35xx #1 SMP Mon Feb 23 05:39:00 UTC 2026 aarch64 GNU/Linux Additional Information I tested the same overlay using the official build system from: https://github.com/orangepi-xunlong/orangepi-build and it works correctly there. This suggests the issue may be related to how Armbian loads overlays for RK3588 boards. Question Is overlay loading from armbianEnv.txt supported on the Orange Pi 5 Pro with the vendor-rk35xx kernel, or is there another mechanism required (extlinux overlays, user overlays, etc.)? https://paste.armbian.com/xiteginoku 0 Quote
Werner Posted March 8 Posted March 8 Attach debug serial console so you can follow u-boot logs and get an idea what the overlay is not applied. 0 Quote
ManeeshaC Posted March 8 Author Posted March 8 picocom v3.1 port is : /dev/tty.usbserial-A5069RR4 flowcontrol : none baudrate is : 1500000 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : no noinit is : no noreset is : no hangup is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs, logfile is : none initstring : none exit_after is : not set exit is : no Type [C-a] [C-h] to see available commands Terminal ready ?DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff DQS rds:h1,l0, CH0 RX Vref:26.7%, TX Vref:20.0%,0.0% DQ rds:h7 l0 h2 l0 l0 h1 h1 l0 , h2 h1 l0 h1 h4 h3 h2 h1 DQS rds:h1,h1, CH1 RX Vref:26.7%, TX Vref:20.0%,0.0% DQ rds:h4 h3 h1 h3 l0 h2 h1 h1 , h2 h5 h3 h1 h7 l0 h5 h2 DQS rds:h1,h1, CH2 RX Vref:26.3%, TX Vref:21.0%,0.0% DQ rds:h2 h3 h1 h4 h6 h1 h4 h7 , h1 h1 h4 h1 h5 h6 h4 h3 DQS rds:l0,l0, CH3 RX Vref:28.5%, TX Vref:21.0%,0.0% DQ rds:h1 h2 h3 l0 h3 h2 h1 h1 , h1 h2 h1 h1 h4 l0 h6 h1 stride=0x2, ddr_config=0x2 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x0 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL board init U-Boot SPL 2017.09 (Feb 16 2026 - 04:05:08) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(31ad8d4f92...) + OK ## Checking fdt 0x003495b0 ... sha256(0195fe7e17...) + OK ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 353.110 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: enable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2400MHz INFO: dfs DDR fsp_params[1].freq_mhz= 534MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1320MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1968MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09 (Feb 24 2026 - 17:20:14 +0000) Model: RK3588 Orange Pi 5 Pro PreSerial: 2, raw, 0xfeb50000 DRAM: 8 GiB Sysmem: init Relocation Offset: eda2d000 Relocation fdt: eb9f9268 - eb9fecb8 CR: M/C/I Using default environment mmc@fe2c0000: 0, mmc@fe2e0000: 1 Bootdev(atags): mmc 0 MMC0: Legacy, 52Mhz PartType: EFI DM: v2 boot mode: None Model: RK3588 Orange Pi 5 Pro CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4149 bytes read in 11 ms (368.2 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0:1 286 bytes read in 10 ms (27.3 KiB/s) 15612135 bytes read in 1264 ms (11.8 MiB/s) 47405568 bytes read in 3810 ms (11.9 MiB/s) 244832 bytes read in 479 ms (499 KiB/s) 325 bytes read in 201 ms (1000 Bytes/s) Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-pro-disable-leds.dtbo Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15612071 Bytes = 14.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x0a100000 Booting using the fdt blob at 0x0a100000 reserving fdt memory region: addr=a100000 size=a2000 'reserved-memory' ramoops@110000: addr=110000 size=e0000 Using Device Tree in place at 000000000a100000, end 000000000a1a4fff Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000) Total: 6405.175 ms Starting kernel ... [!p]104[?7h[6n[32766;32766H[6n[40;1H[!p]104[?7h[6n[32766;32766H[6n[40;1H Armbian_community 26.2.0-trunk.493 Trixie ttyFIQ0 orangepi5pro login: 0 Quote
Werner Posted March 8 Posted March 8 Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-pro-disable-leds.dtbo Meaning the overlay was applied successful. If it does not work, perhaps this means some pin definitions or whatever differ from opi sources vs ours. 0 Quote
Solution ManeeshaC Posted March 8 Author Solution Posted March 8 UPDATE I was able to figure out what was happening. The board initially boots with the LEDs enabled. Because of this, applying the device tree overlay alone did not seem to disable them, even across reboots. However, after manually turning the LEDs off once using: echo 0 | tee /sys/class/leds/blue_led/brightness echo 0 | tee /sys/class/leds/green_led/brightness and then enabling the overlay, the LEDs remained disabled, and the overlay appeared to work as expected. So it seems the LEDs needed to be turned off once manually before the overlay behaviour became consistent. Everything now works as intended. It appears that when overlay_prefix is either not defined or is empty, the system behaves unexpectedly during overlay lookup. In such cases, the loader seems to attempt resolving overlays starting with -, rather than correctly resolving the overlay name. 0 Quote
