Am 10.8.2021 um 06:19 schrieb TonyMac32:
The RAM controller was being starved for voltage.
I have recently rectified this problem and moved to the official mainline USB3 driver for this board.  The GPU and DMC share the same regulator, so there was conflict.  https://github.com/armbian/build/commit/ee610096bc5d252307789c3818aa8b59147bf1d5
I just built a new image and the board works again - *thank you*:thumbup:
I'll tie down the kernel package for now.
Hi everybody,
I'm having some troubles with my renegade board: I flashed the bullseye image with mainline kernel (5.10) in an sdcard, put it in my roc-rk3328-cc board (4GB) and tried to boot. U-boot starts without problems, the kernel and dtb gets loaded from the /boot partition on the sdcard, the system starts to boot but when it comes to look for the root filesystem (by uuid), it cannot be found. A little digging in the problem showed that the sdcard is not recognized by the kernel (in fact writing the same image in a USB key works, because the filesystem is found by uuid in it), and dmesg shows a problem with the sdmmc-regulator:
reg-fixed-voltage sdmmc-regulator: Failed to register regulator: -517
This error is repeated various time (around 20) and then stops. The following is the output of # cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-31, parent: platform/pinctrl, gpio0:
gpiochip1: GPIOs 32-63, parent: platform/pinctrl, gpio1:
 gpio-50  (                    |snps,reset          ) out hi ACTIVE LOW
 gpio-58  (                    |vcc-host1-5v-regulat) out hi
gpiochip2: GPIOs 64-95, parent: platform/pinctrl, gpio2:
 gpio-66  (                    |ir-receiver         ) in  hi ACTIVE LOW
gpiochip3: GPIOs 96-127, parent: platform/pinctrl, gpio3:
gpiochip4: GPIOs 511-511, parent: platform/ff100000.syscon:grf-gpio, ff100000.syscon:grf-gpio:
 gpio-511 (                    |vccio_sd            ) out hi
An the following is the output of cat /sys/kernel/debug/regulator/regulator_summary
 regulator                      use open bypass  opmode voltage current     min     max
 regulator-dummy                  3    2      0 unknown     0mV     0mA     0mV     0mV
    ff580000.usb-vusb_a           1                                 0mA     0mV     0mV
    ff580000.usb-vusb_d           1                                 0mA     0mV     0mV
 vcc_sys                          1    1      0 unknown  5000mV     0mA  5000mV  5000mV
    vcc_host1_5v                  1    0      0 unknown  5000mV     0mA     0mV     0mV
 vcc_phy                          2    1      0 unknown     0mV     0mA     0mV     0mV
    ff540000.ethernet-phy         1                                 0mA     0mV     0mV
 vccio_sd                         1    0      0 unknown  1800mV     0mA  1800mV  3300mV
In both cases, vcc_sd doesn't show up, which lets me think that the regulator doesn' register.
As far as I understand this is the regulator to power the sdcard, but I don't understand why it doesn't register. With various other OSes the sdcard works fine, so I would exclude an hardware problem.
Since I am able to boot from USB I can provide any output required (dmesg, decompiled dtb, etc).
Thanks for your help!
PS: reading various forums, I have the doubt that two boards exists, firefly and libre computer. I think mine is the libre computer one, but I didn't find a way to be 100% sure... I have this doubt because the product page states that the power LED is blue, while mine is red.
Has anyone ever thought about programming The Rock 3328cc Renegade to flash car PCMS and bcms is that possible and where could I find a program like that if so? Thanks
