As title says.
Here's the bash script I use to download the dependencies and compile the latest mesa: https://pastebin.com/1n7Sv0dZ
How /boot/*Env* looks like right now: https://pastebin.com/mUqHs14Y
And the error message I get when I try to run sway goes as follows:
MESA: error: ZINK: failed to choose pdev
libEGL warning: egl: failed to create dri2 screen
[wlr] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: "DRI2: failed to create screen"
[wlr] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: "DRI2: failed to load driver"
[wlr] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: "eglInitialize"
[wlr] [render/egl.c:268] Failed to initialize EGL
[wlr] [render/egl.c:571] Failed to initialize EGL context
[wlr] [render/gles2/renderer.c:499] Could not initialize EGL
[wlr] [render/wlr_renderer.c:272] Could not initialize renderer
[sway/server.c:236] Failed to create renderer
Oddly enough, "eglinfo -B" shows that everything is fine: https://pastebin.com/6k05DcAS
How my .bashrc looks like right now: https://pastebin.com/3W7Qib6U
I've tried copying the firmware in (with "cd /lib/firmware
sudo wget https://github.com/JeffyCN/mirrors/raw/libmali/firmware/g610/mali_csffw.bin
sudo chmod 644 mali_csffw.bin"), forcing "card0" to be used with the env. value WLR_DRM_DEVICES=/dev/dri/card0, and panfrost with "MESA_LOADER_DRIVER_OVERRIDE=panfrost" and "GALLIUM_DRIVER=panfrost" but none of those options helped. I also added my user to "render" and "video" (with sudo usermod -aG video $USER and sudo usermod -aG render $USER), which also didn't do me any good. I also manually removed any trace of panfrost that was left into the system and reinstalled with "libgl1-mesa-dri" and manually compiling everything in again...and it also didn't worked. I don't know what else I should do, and I'm in the verge of reinstalling everything back in. Please help me. And thanks for reading.
  • Werner changed the title to Cannot run sway with hardware acceleration after compiling the latest mesa.
