noisepic Posted December 12, 2017 Posted December 12, 2017 What's happen with my nano pi k2 just boot up and stop here. GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:AA;SD:0;READ:0;0.0;CHK:0; no sdio debug board detected TE: 194208 BL2 Built : 13:48:56, Sep 23 2016. gxl g7459bd4 - jianxin.pan@droid06 set vcck to 1120 mv set vddee to 1000 mv Board ID = 6 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 792MHz - PASS Rank0: 1024MB(auto)-2T-11 Rank1: 1024MB(auto)-2T-11 DataBus test pass! AddrBus test pass! Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from SD, src: 0x00020200, des: 0x10100000, size: 0x00015400 Load bl33 from SD, src: 0x00038200, des: 0x01000000, size: 0x000a3400 NOTICE: BL3-1: v1.0(debug):2e39a99 Is the problem with boot loader or kernel or OS?
TonyMac32 Posted December 12, 2017 Posted December 12, 2017 What image is this? You're not getting into Uboot with the info pasted. A corrupted SD card is possible.
noisepic Posted December 18, 2017 Author Posted December 18, 2017 Thanks tony Mac32, I had try with another SD card and eMMC. The same problem, I try to custom my own boot loader it might something wrong.
