Posted (edited)
DISCLAIMERS (PLEASE READ):
- Everything in this post is provided AS-IS. This is not an official Armbian-supported target, and neither the Armbian project nor I am responsible for any damage, data loss, or broken devices caused by flashing or testing these images.
- As with other TV boxes, please assume there may be board variants, undocumented hardware changes, weak power supplies, and marginal NAND/eMMC chips. Test carefully before writing anything to internal storage.
- Please keep discussion and support in the forum thread, not in the official Armbian issue tracker.
Hi all,
I would like to share my work on bringing Armbian to Rockchip RK3128 TV boxes.
These boxes are quite old now, and I do not think they are especially common anymore. Still, I suspect a lot of people may have one lying around somewhere in a drawer, unused after Android updates stopped or the original firmware became too slow to care about. I also had several of them lying around at home, which is what pushed me to start this project in the first place. Since I could not find an RK3128 Armbian effort comparable to the RK322x one, I decided to try doing the port myself. Another important motivation was simply to reduce e-waste: if even some of these old boxes can be turned into usable Linux machines again instead of being thrown away, that already feels worthwhile to me.
First and foremost, I want to send special thanks to @jock and @fabiobassa for their RK322x TV box work on this forum. Their work was the foundation that made this RK3128 effort much easier to start from.
1. Main references and source code:
2. Current status
At the moment I have two kernel lines:
  • `4.4.194`, the older vendor-based line, which is already usable in practice
  • `6.6.89`, the newer line, which allows these boxes to run a more up-to-date Armbian userspace
What works in the current build:
  • Custom U-Boot based on Rockchip U-Boot 2017.09
  • All four CPU cores, up to 1.2 GHz
  • CPU frequency scaling and governors
  • DRAM frequency control, both dynamic and fixed
  • NAND, eMMC, SD card, and USB booting. The booting order is: USB >> SD Card >> NAND/eMMC (NAND and eMMC cannot be enabled at the same time because they share pins)
  • OTG and EHCI/OHCI USB support
  • Ethernet
  • Wi-Fi support for SSV6051P, ESP8089, and several Realtek chips
  • GPU acceleration
  • UART1 and UART2, configurable
Kernel `6.6.89` status in a bit more detail:
  • CPU DVFS is stable after replacing the inherited/leakage-based OPP assumptions with a board-specific RK3128-safe table. The stable points I ended up using are `216 / 408 / 600 / 816 / 1008 / 1200 MHz`
  • DMC / RAM devfreq works. In practice, simply enabling `dmc` works much better than I first expected, and boards can settle at different normal rates such as `396 MHz` or `456 MHz`
  • GPU on `6.6.89` uses `Lima`, not the old Mali blob stack. That gives a maintainable Mesa/DRM path and hardware-accelerated OpenGL ES instead of depending on a legacy userspace blob
  • VPU/video decode is still the weak point. I tried both `RKMPP` and `Hantro/V4L2` directions, but video processing is still limited, so I do not consider this a polished media-playback setup yet
What does not work yet / known limitations:
  • Bluetooth: not implemented or at least not validated, because I do not have a board with Bluetooth to test
  • VPU / hardware video decoding is not in good shape yet
  • SD card and SDIO Wi-Fi are currently using PIO mode on both kernel lines. This is slower than DMA, but stable enough for normal use
3. Image implementation
I also made two RK3128 Armbian images based on existing RK322x Armbian images rather than building everything from scratch:
  • Armbian 22.02: Based on the build provided by @jock, running kernel 4.4.189
  • Armbian 26.02: Based on the official Armbian build for rk322x, running kernel 6.6.89
In both cases, the idea was the same: keep the working RK322x Armbian userspace as a base, then replace the RK322x-specific parts with RK3128 ones, while the kernels themselves are based on Rockchip kernel sources.
Compared with the original RK322x images, the RK3128 work mainly replaces or adds:
  • boot.cmd / boot.scr changes so the boot flow can handle NAND and USB properly
  • RK3128-specific Wi-Fi drivers and boot-time module loading logic
  • rk3128-config
  • a delayed Wi-Fi loader service
  • RK3128-specific motd information
  • the RK3128 kernel, DTB, and overlays
For the `6.6.89` image specifically, there is some extra image-level cleanup and repackaging:
  • remove the RK322x kernel / dtb / u-boot / BSP packages from the donor image
  • pin those RK322x packages so they do not come back on upgrade
  • install the RK3128 `6.6.89` Debian kernel packages
  • rebuild the BSP package under the RK3128 name
4. Quick installation notes
All required files are available from the releases page:
There are three installation layouts that are currently supported:
  • 1. SD card only
    • Pros: safest option, does not touch internal storage, easy to test and easy to remove, and if a board has an SD slot it can still be useful even when NAND/eMMC is completely dead
    • Cons: slower than internal storage, and not every board has an SD slot
    • Best for: first boot, testing, and boards where you want to keep the original Android install untouched
  • 2. Full install to NAND / eMMC
    • Pros: fastest and cleanest setup, uses the internal storage already present on the board
    • Cons: overwrites the original Android install, and old NAND/eMMC may already be unreliable
    • Best for: boards with healthy internal storage when you want a fully self-contained install
  • 3. Hybrid install: bootloader on NAND / eMMC, rootfs on USB or SD card
    • Pros: usually the most practical option for old TV boxes, works well when internal storage is only reliable enough for bootloader pieces, and can also help on boxes with problematic Android boot behavior
    • Cons: more manual than the other methods, still depends on internal storage for the bootloader, and performance depends on the USB drive or SD card used
    • Best for: boxes with weak or aging internal NAND/eMMC, or boxes where you want to avoid a full install to internal storage
I describe each method in more detail below.
4.1. Install and boot from SD card
Prepare:
  • idbloader.img
  • uboot.img
  • trust.img
  • rootfs.img
Create an MBR partition table on the SD card, leave the first 16 MB empty, create one Linux partition, then write:
  • idbloader.img to the raw device at seek=64
  • uboot.img to the raw device at seek=16384
  • trust.img to the raw device at seek=24576
  • rootfs.img to the first partition, not to the whole disk
Example:
DEV=/dev/sdX
sudo parted -s "$DEV" mklabel msdos
sudo parted -s "$DEV" mkpart primary ext4 16MB 100%
sudo partprobe "$DEV"
sudo dd if=idbloader.img of="$DEV" seek=64 conv=fsync
sudo dd if=uboot.img of="$DEV" seek=16384 conv=fsync
sudo dd if=trust.img of="$DEV" seek=24576 conv=fsync
sudo dd if=rootfs.img of="${DEV}1" bs=4M status=progress conv=fsync
sync
I also provide a bootcardmaker.sh helper script in the same release directory to simplify this process.
4. 2. Full install to NAND / eMMC
Prepare:
  • rkxx_loader_vx.xx.xxx.bin
  • parameter.txt
  • uboot.img
  • trust.img
  • rootfs.img
Then:
  • Boot the board normally
  • Connect a USB cable to the OTG port
  • Open RKDevTool v2.69
  • In Advanced Function, erase the first 0x10000 sectors with Start LBA = 0x0 and Count = 0x10000
  • Press ResetDevice
  • Wait for the board to return in MaskROM mode
  • Go to Download Image
  • Flash Loader, parameter, U-Boot, Trust, and rootfs
4. 3. Hybrid install: bootloader on NAND / eMMC, rootfs on USB or SD card
This is the layout I use most often, and in practice it is probably the most useful one for old TV boxes.
It is especially useful when internal NAND/eMMC is still good enough for Loader / parameter / U-Boot / Trust, but not reliable enough for a full root filesystem. A common symptom on these old boxes is that Android starts to boot and then hangs, or that the internal storage is simply too unreliable to trust with a full install.
In this hybrid layout:
  • Internal NAND/eMMC stores Loader, parameter, U-Boot, and Trust
  • The root filesystem lives on USB or SD card
Important:
  • rootfs.img is a filesystem image, not a full disk image
  • Write rootfs.img to a partition such as /dev/sdX1, not to the whole device
  • Tools like BalenaEtcher are the wrong fit for this particular image layout
Example:
sudo dd if=rootfs.img of=/dev/sdX1 bs=4M status=progress conv=fsync
sync
4.4. Post-install configuration
After the board boots successfully, you can configure it either from the local console over HDMI or remotely over SSH if Ethernet is connected.
Default login:
  • user: root
  • password: 1234
The first login will ask you to change the password.
After that, run:
rk3128-config
This is the board-specific configuration tool for enabling and adjusting hardware features that may differ between RK3128 boxes.
The most important options are:
  • Wi-Fi chip selection
  • RAM dynamic frequency: disabled by default. Enabling it can improve performance, but on some boards it may cause kernel hangs. If that happens, switch it back to disabled
  • SD card storage enablement when booting from another device
  • Display resolution
  • OTG mode selection
5. Testing feedback is welcome
If anyone here has RK3128 boards and wants to test, feedback would be very useful, especially for:
  • Board photos and PCB markings
  • Whether the board uses NAND or eMMC
  • Boot method that works: SD, USB, NAND, eMMC
  • Which Wi-Fi chip is present
  • Serial logs, dmesg, and failure reports
If there is enough interest and enough board coverage, I would be happy to keep improving this, cleaning it up further, and making it easier for other people to test.
6. Credits
- @jock and @fabiobassa for the RK322x TV box work on the Armbian forum, which provided the main starting point, the images and practical reference for this RK3128 effort
- Rockchip for the original kernel code base used as the foundation for both kernel lines
Edited by Chiều Nhạt Nắng
First of all, a huge thank you for your work on bringing Armbian to RK3128 TV boxes. Your guide is incredibly detailed and practical — not just theoretically correct, but actually usable in real-world scenarios where hardware varies wildly. That’s something many tutorials lack. It’s clear you spent a lot of time testing across different boards, and it really helps people like me who are dealing with these unpredictable cheap TV boxes.
I also want to say I truly appreciate how you approached the NAND installation process using rkdeveloptool. The way you structured the workflow, especially handling boot components and low-level flashing, made it much easier to understand what’s actually happening under the hood instead of just blindly following commands.
I happen to have a bunch of RK3128 devices myself, and thanks to your work, I’ve successfully brought several of them back to life. Even with different variants of RK3128, I was able to get them running properly on NAND with kernel 4.x, which is honestly impressive given how inconsistent these boards can be.
That said, I’d like to ask if you might consider extending your approach to RK3228/RK3229 devices using rkdeveloptool on Windows, similar to what you’ve done for RK3128. I’ve been trying to replicate a similar workflow based on your guide and also by studying the multitool source, especially the step-nand function.
So far, I’ve attempted:
Reusing trust.img and legacy U-Boot from the multitool BSP folder
Manually creating a GPT at 0x8000
Writing the image with dd while skipping the first 4MB (similar to step-nand logic)
Unfortunately, none of these attempts have worked so far.
The main challenge is that many RK3229 boards don’t have an accessible SD card slot (or even pads for one), which makes recovery and testing much harder. If SD boot were available, this would be much easier to debug and iterate.
Since you’ve already done the hard work of figuring things out for RK3128 using rkdeveloptool, I was wondering if you might be willing to give RK3229 a try using a similar method. Even a partial guide or some hints about differences in bootloader layout, trust image, or NAND handling would be extremely helpful.
Thanks again for your contribution — it’s genuinely valuable for the community. Hopefully RK3229 can be the next one to crack :)
Cheers!
Posted (edited)
I’ve updated the kernel and Armbian image with the following improvements:
  • RKNAND driver enhancements: Significantly improved stability, even on very old and degraded NAND flash. Testing was performed on an 8GB NAND device with over 2TB of writes and more than 3000 erase cycles (as reported by /proc/rknand). The system runs reliably under these conditions, whereas the original Android ROM fails to boot.
  • ESP8089 driver improvements: Increased stability when handling large packets.
  • Docker support added
Release Files
Kernel 6.6: https://github.com/chieunhatnang-personal/linux-kernel-6.6-rk3128-tvbox/releases/tag/stable-1.1
If you are already running the image, download the .deb packages and place them in a directory (e.g., /tmp). Then run:
dpkg -i /tmp/*.deb
Reboot after installation.
Armbian Image:
https://github.com/chieunhatnang-personal/RK3128-Linux-SupportingScripts/releases/tag/kernel-6.6-armbian-26-v1.1
Cheers!
Thank you for your kind words. For RK3229, I thought it's supported by mainline kernel and you can easily install using method provided by Jock?
On 4/15/2026 at 5:03 PM, Chiều Nhạt Nắng said:
Could you please provide more detailed instructions, or perhaps make a video tutorial?
I tried but failed because I didn't understand at first, but now I understand part of it, and my TV box is malfunctioning. The problem is that when I plug in the power cord with the adapter, no lights or anything come on, but when I plug in the USB cable near the LAN port, it starts up normally (because I initially followed method 4.2. Full install to NAND / eMMC). Now I've flashed the Android firmware and it's working, but the error is as I described above. So, is the power IC dead or is the problem somewhere else?
Hi there, I followed the instructions in section 4.1 to install it onto the memory card, but when I plug it into the TV box, it won't boot from the card. Could you please provide instructions again?
