Loshta Posted April 17 Posted April 17 Zero 3E, all images, same UUID/initramfs error on boot. Tried different flashing methods, sd cards. All the same fail. Board works with the old Joshua riek dist. 0 Quote
Loshta Posted April 18 Author Posted April 18 My bad I didn't specify. On Windows. I lost 4h on it. I needed to use dd on a Mac to create a bootable SD card. Arbian Imager didn't help, it killed my Window stuck on storage finding and couldn't be killed. on Mac made a bad job of flashing, didn't even started boot. Btw on Windows, all methods I used (Raspberry Imager, Etcher, Rufus) all made like 50ish small 0 bite partitions and one big unallocated. Somehow it started booting, Armbian logo on, but then it failed. 0 Quote
Ary Posted 6 hours ago Posted 6 hours ago (edited) Same thing is happeing with me at first it booted correctly with armbian imager then suddenly it crashed and after that whenever i tried to flash it using armbian imgaer its giving error of initramfs , btw iam using Radxa zero 3w , any solution or any step iam doing wrong , i have tried it with different imager but same problem. Edited 4 hours ago by Ary 0 Quote
eselarm Posted 2 hours ago Posted 2 hours ago If it worked once and now not anymore, it might be the SD-card that is the problem. It might be a as bad that it is a fake SD-card. 0 Quote
Ary Posted 1 hour ago Posted 1 hour ago I also thought the same so i was using a sandisk 32 gb sd card so i switched to samsung 64 gb one but same issue in it also, i think the problem is something else. 0 Quote
eselarm Posted 48 minutes ago Posted 48 minutes ago The other usual thing is then PSU. So also maybe try a different one. Else I cannot really help you, not being able to find rootfs can have pure software cause, but is unlikely if other people can run it successfully. I wish I had bought this SBC a year ago, but I didn't and now they are sold out where I looked, so cannot see If I can reproduce the problem. You need to look in more detail yourself, like connecting serial debug console and setting loglevel to 7 in armbianEnv.txt. Also post which exact image is (sha256sum), so other people can try the same thing. 0 Quote
