I have Cubieboard with armbian.
ARMBIAN 5.36 user-built Ubuntu 16.04.3 LTS 3.4.113-sun7i
# apt-get upgrade
Setting up linux-firmware (1.157.14) ...
ln: failed to create hard link '/boot/initrd.img-3.4.113-sun7i.dpkg-bak' => '/boot/initrd.img-3.4.113-sun7i': Operation not permitted
update-initramfs: Generating /boot/initrd.img-3.4.113-sun7i
gzip: stdout: No space left on device
root@cubietruck:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/nand1       32M   24M  8.6M  74% /boot
Can you advise me something to solve this issue?
Thank you.
Hi Alexey,
my problem ist quiet the same...
On my Cubietruck I boot from nand-Bootpartition witch is like yours 32M and 98% full.
Rootpartition is on SD.
I also got the "No space left on device" - message after an apt-get upgrade...:-(
I was looking around for some advice to change the size of the boot-partition but didn´t find anything.
There are 8G Nandflash on Cubietruck and just 32M used - I thought, there must be a way to increase the size of the /boot...
...hope to get an answer here...
(please excuse my english - it ist a little bit rusty)
Klaus
Hi Igor,
thanks for your fast reply!
But now my problem is grown up a little...
I rebootet and the system didn´t start up again.
Fortunatly I still had the SD-card from where I booted before using the nand-install.
Now, because acting with nand is a bit tricky for a newbie like me - is it possible, to boot from SD and use the rootfs on SSD by editing the boot.cmd and compiling it like posted from you in
I have openhab2 installed on rootfs and it worked great since yesterday - I don´t want to set it all up again.
thanks in advance
Klaus
Hi Igor,
I boldly tried to change the boot.cmd, the armbianEnv.txt and finaly etc/fstab - and it worked.
I now use the mmc-card to boot und the rootfs from /deb/sda1.
Thanks for guidance!
Klaus
On 12/15/2017 at 4:08 PM, Alexey Goncharenko said:
# apt-get upgrade
Thank you.
Hi!
I've got the same problem and my solution was:
# umount /boot
# ls -lh /boot
... returned empty folder result ...
# mount  /dev/nand1 /mnt
# cp -rp /mnt/* /boot
# nano /etc/fstab
...  comment string  #/dev/nand1 /boot vfat    defaults 0 0
# reboot
... then
# apt update
# apt upgrade
Regards,
Yuri
Edited by ymf
