confuseruser Posted 7 hours ago Posted 7 hours ago Friends, as shown in the image, I am trying to install a Linux system on this BTV: OTT BOX, model B11 with an Amlogic S905X3 CPU. However, I am not succeeding because it cannot read the USB drive. I have already tried changing the .ext, attempted to burn the image using Rufus, Balena, and nothing worked. I am using a Multilaser USB drive which I believe is 2.0. At the moment I don’t have another USB drive or memory card to test. Any suggestions? 0 Quote
SteeMan Posted 7 hours ago Posted 7 hours ago The screen shot you have shows you are using the Ugoos X3 version of uboot. That will not work as that is specific to that box. 1 Quote
confuseruser Posted 7 hours ago Author Posted 7 hours ago Thanks for clarifying. And which would be the correct version of u‑boot for my BTV OTT BOX (model B11, Amlogic S905X3)? I admit I’m a bit lost at this point. 0 Quote
SteeMan Posted 1 hour ago Posted 1 hour ago The s905x3 one. Also, how are you booting this? You say it doesn't recognize usb, so what are you using to boot Armbian? 0 Quote
confuseruser Posted 1 hour ago Author Posted 1 hour ago I am trying to boot from a USB stick, but it shows the error you can see in the screenshot. I am using the update button on the back of the TV box. It does start the boot process from the USB, but according to the error message it seems unable to actually read the drive. I have been stuck on this issue for several days now. 0 Quote
