confuseruser Posted May 6 Posted May 6 Friends, as shown in the image, I am trying to install a Linux system on this BTV: OTT BOX, model B11 with an Amlogic S905X3 CPU. However, I am not succeeding because it cannot read the USB drive. I have already tried changing the .ext, attempted to burn the image using Rufus, Balena, and nothing worked. I am using a Multilaser USB drive which I believe is 2.0. At the moment I don’t have another USB drive or memory card to test. Any suggestions? 0 Quote
SteeMan Posted May 6 Posted May 6 The screen shot you have shows you are using the Ugoos X3 version of uboot. That will not work as that is specific to that box. 1 Quote
confuseruser Posted May 6 Author Posted May 6 Thanks for clarifying. And which would be the correct version of u‑boot for my BTV OTT BOX (model B11, Amlogic S905X3)? I admit I’m a bit lost at this point. 0 Quote
SteeMan Posted May 6 Posted May 6 The s905x3 one. Also, how are you booting this? You say it doesn't recognize usb, so what are you using to boot Armbian? 0 Quote
confuseruser Posted May 6 Author Posted May 6 I am trying to boot from a USB stick, but it shows the error you can see in the screenshot. I am using the update button on the back of the TV box. It does start the boot process from the USB, but according to the error message it seems unable to actually read the drive. I have been stuck on this issue for several days now. 0 Quote
SteeMan Posted May 6 Posted May 6 Does the box have an sd card slot and have you tried booting from that? (That is the common method). Also are you sure the box has an s905x3? Have you opened the box and inspected the chip? You might want to try all the uboot binaries just in case. 0 Quote
bedna Posted May 7 Posted May 7 "mmc1(part 0) is current device". Is that really a usb? Never seen a usb be named that, sound more like an internal storage. 0 Quote
confuseruser Posted May 7 Author Posted May 7 Yes, I opened it and it really does have the Amlogic chipset. However, it is still not booting from the USB stick. Do you have any recommendations? I’ve been stuck on this for a week and I’m quite new to this area. 0 Quote
SteeMan Posted May 7 Posted May 7 15 minutes ago, confuseruser said: Do you have any recommendations? Have you tried all of the uboot binaries as I suggested above? Also, you didn't answer my question about SD card. Does the box have an SD card slot and have you tried that? 0 Quote
confuseruser Posted May 7 Author Posted May 7 I don’t have an SD card for testing, only a USB stick. The idea is to turn this TV box into a KDS for a restaurant, it will only run this program. However, it needs to be done in Linux. I downloaded a new image, it booted through Android, it detected the USB stick but reported that it couldn’t find the installation package. 0 Quote
SteeMan Posted May 7 Posted May 7 Get an SD card. That is what 95% of people use on these boxes. Also if you want help, you need to be a lot more detailed than 'but reported it couldn't find the installation package'. Logs/Screenshots are needed to even begin to help. 0 Quote
confuseruser Posted May 7 Author Posted May 7 Well, with the new image there was some progress, but I will give up for now. I will look for an SD card and try again using it. I’m confident that I will finally succeed in this operation. 0 Quote
confuseruser Posted 7 hours ago Author Posted 7 hours ago well now i using a sd card and get this situation.... 0 Quote
SteeMan Posted 1 hour ago Posted 1 hour ago You shouldn't be getting into android recovery. How did you burn the image to the SD card? On what platform? The fact that I'm seeing things like "System Volume Information" and "box-config" which aren't directories that should exist on an Armbian image, it looks like something strange has happened to your SD card image. 0 Quote
