Johan Nilsson Posted Wednesday at 10:24 AM Posted Wednesday at 10:24 AM I have Debian and installed Mate. I happen to install sv_SE.UTF-8 and en_US.UTF-8 but I cannot change languish on desktop from sv_SE.UTF-8 to en_US.UTF-8. First I just remove "sv_SE.UTF-8, but then the Terminal complain it did not find sv_SE, so install again. I generate the 2 locales, And thied to when I marked the local I want en_US, but it say sv_SE are active in Mate. I tried to run: sudo localectl set-locale en_US.UTF-8 Failed to issue method call: Access denied I don't find any "Languish controll" at all in Mate desktop It is right languish in terminal. Cheers Joni 0 Quote
Werner Posted Wednesday at 10:30 AM Posted Wednesday at 10:30 AM dpkg-reconfigure locales and change default locale Tried? 0 Quote
Johan Nilsson Posted Wednesday at 01:19 PM Author Posted Wednesday at 01:19 PM Yes. I just came to armbian-config and there I select en_US as default, but it does not change Mate to en_US. It change are only on cli. 0 Quote
Johan Nilsson Posted 2 hours ago Author Posted 2 hours ago Seems like Mate change to sv_SE.UTF-8, but there are no app to change launguish in Mate. Think I have to remove mate? 0 Quote
bedna Posted 1 hour ago Posted 1 hour ago (edited) For mate IIRC they use gnome's gnome-language-selector (start it in a terminal if you are missing the icon in settings), but it was a while since I used that desktop-env so I could be wrong. My old notes says the setting should be in: System > Control Center > Language Support For your information (as a fellow Swedish person): there is a locale called en_DK.UTF-8 that you might want to use instead. That way you get the correct settings for Scandinavian (like date/clock format for example) but the language is English. Or you can probably do it in terminal altogether: sudo dpkg-reconfigure locales # select en_DK.UTF-8 here, or whatever locale you want to use, I will use the dk version in this example localectl set-locale LANG=en_DK.UTF-8 sed -i "s/sv_SE/en_DK/" ~/.dmrc Edited 52 minutes ago by bedna 0 Quote
