sgjava Posted December 21, 2017 Share Posted December 21, 2017 I'm working on a Duo project that needs SPI and this is how I configured and tested it without the mini shield. Requirements: NanoPi Duo with test Armbian image 1 female to female jumper wire Enable SPI on boot: sudo nano /boot/armbianEnv.txt Add spi-spidev to overlays= Add line param_spidev_spi_bus=1 sudo reboot If everything worked you should have /dev/spidev1.0. Check with ls /dev/spi*. Now we can test with a C program: cd wget http://www.raspibo.org/renzo/spidev_test.c gcc -o spidev_test spidev_test.c sudo ./spidev_test -D /dev/spidev1.0 spi device: /dev/spidev1.0 spi mode: 0 bits per word: 8 max speed: 500000 Hz (500 KHz) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 shutdown now -h then wire up MO and MI pins with jumper to create loop back and power up sudo ./spidev_test -D /dev/spidev1.0 spi device: /dev/spidev32766.0 spi mode: 0 bits per word: 8 max speed: 500000 Hz (500 KHz) FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DE AD BE EF BA AD F0 0D OK, let's try some Python now: sudo apt-get update sudo apt-get install python-dev sudo apt-get install python-pip sudo -H pip install --upgrade pip setuptools sudo -H pip install --upgrade spidev nano spitest.py import spidev input = [1 ,2 ,3, 4, 5] print "input: %s" % input spi = spidev.SpiDev() spi.open(1,0) output = spi.xfer2(input) print "output: %s" % output Save code and run program: sudo python spitest.py input: [1, 2, 3, 4, 5] output: [1, 2, 3, 4, 5] Link to comment Share on other sites More sharing options...
