Armbian documentation on Overlays refers to /boot/armbianEnv.txt. But in the version of Armbian that I'm running (on a Cubietruck, ARMBIAN 5.36 user-built Debian GNU/Linux 8 (jessie) 4.13.16-sunxi) there is no such file.
There is however a copy in directory /usr/share/armbian. Is this the overlay file that is processed at start-up? If so, it would be good if the documentation was updated.
Quoting the documentation:
  • DT overlays are a Work-in-Progress (WIP) feature, present only in fresh images starting with 5.30, nightly and user made images
  • For older images (even upgraded to 5.30 or later) manual update of the u-boot and the boot script is required
I'm still puzzled by the boot sequence for my CubieTruck (Armbian 5.36, 4.13.16-sunxi).  As discussed above, it has no armbianEnv.txt so it's clearly not using the DT overlays. But nor does it have a valid copy of script.bin: the link points to a file in non-existent directory /boot/bin (see below).
Grateful for an explanation!
root@fs:/boot# ls -al
total 30512
drwxr-xr-x  4 root root    4096 Dec 24 16:10 .
drwxr-xr-x 24 root root    4096 Aug 15 09:34 ..
-rw-r--r--  1 root root    2796 Sep 15  2016 boot.cmd
-rw-r--r--  1 root root    2868 Sep 15  2016 boot.scr
-rw-r--r--  1 root root  156631 Nov 24 18:51 config-4.13.16-sunxi
lrwxrwxrwx  1 root root      17 Nov 29 18:41 dtb -> dtb-4.13.16-sunxi
drwxr-xr-x  3 root root   12288 Nov 29 18:34 dtb-4.13.16-sunxi
drwxr-xr-x  2 root root    4096 Jun 15  2017 dtb-4.9.12-sunxi
lrwxrwxrwx  1 root root      16 Jun 24  2017 dtb.old -> dtb-4.11.6-sunxi
-rw-r--r--  1 root root 4449039 Dec  8 16:33 initrd.img-4.13.16-sunxi
-rw-r--r--  1 root root 4163902 Feb 14  2017 initrd.img-4.8.4-sunxi
-rw-r--r--  1 root root 4075334 May 14  2017 initrd.img-4.9.12-sunxi
-rw-r--r--  1 root root 4086657 Feb 14  2017 initrd.img-4.9.7-sunxi
-rw-r--r--  1 root root       0 Nov 29 18:43 .next
lrwxrwxrwx  1 root root      18 Sep 15  2016 script.bin -> bin/cubietruck.bin
-rw-r--r--  1 root root 3015924 Nov 24 18:51 System.map-4.13.16-sunxi
lrwxrwxrwx  1 root root      21 Dec  8 16:33 uInitrd -> uInitrd-4.13.16-sunxi
-rw-r--r--  1 root root 4449103 Dec  8 16:33 uInitrd-4.13.16-sunxi
-rw-r--r--  1 root root       0 Jun 15  2017 .verbose
-rwxr-xr-x  1 root root 6790944 Nov 24 18:51 vmlinuz-4.13.16-sunxi
lrwxrwxrwx  1 root root      21 Nov 29 18:43 zImage -> vmlinuz-4.13.16-sunxi
root@fs:/boot#
