john.glasson Posted December 25, 2017 Share Posted December 25, 2017 Armbian documentation on Overlays refers to /boot/armbianEnv.txt. But in the version of Armbian that I'm running (on a Cubietruck, ARMBIAN 5.36 user-built Debian GNU/Linux 8 (jessie) 4.13.16-sunxi) there is no such file. There is however a copy in directory /usr/share/armbian. Is this the overlay file that is processed at start-up? If so, it would be good if the documentation was updated. Link to comment Share on other sites More sharing options...
tkaiser Posted December 25, 2017 Share Posted December 25, 2017 Quoting the documentation: DT overlays are a Work-in-Progress (WIP) feature, present only in fresh images starting with 5.30, nightly and user made images For older images (even upgraded to 5.30 or later) manual update of the u-boot and the boot script is required Link to comment Share on other sites More sharing options...
john.glasson Posted December 25, 2017 Author Share Posted December 25, 2017 Thanks. tkaiser Link to comment Share on other sites More sharing options...
john.glasson Posted December 30, 2017 Author Share Posted December 30, 2017 I'm still puzzled by the boot sequence for my CubieTruck (Armbian 5.36, 4.13.16-sunxi). As discussed above, it has no armbianEnv.txt so it's clearly not using the DT overlays. But nor does it have a valid copy of script.bin: the link points to a file in non-existent directory /boot/bin (see below). Grateful for an explanation! root@fs:/boot# ls -al total 30512 drwxr-xr-x 4 root root 4096 Dec 24 16:10 . drwxr-xr-x 24 root root 4096 Aug 15 09:34 .. -rw-r--r-- 1 root root 6944 Sep 15 2016 boot.bmp -rw-r--r-- 1 root root 2796 Sep 15 2016 boot.cmd -rw-r--r-- 1 root root 2868 Sep 15 2016 boot.scr -rw-r--r-- 1 root root 156631 Nov 24 18:51 config-4.13.16-sunxi lrwxrwxrwx 1 root root 17 Nov 29 18:41 dtb -> dtb-4.13.16-sunxi drwxr-xr-x 3 root root 12288 Nov 29 18:34 dtb-4.13.16-sunxi drwxr-xr-x 2 root root 4096 Jun 15 2017 dtb-4.9.12-sunxi lrwxrwxrwx 1 root root 16 Jun 24 2017 dtb.old -> dtb-4.11.6-sunxi -rw-r--r-- 1 root root 4449039 Dec 8 16:33 initrd.img-4.13.16-sunxi -rw-r--r-- 1 root root 4163902 Feb 14 2017 initrd.img-4.8.4-sunxi -rw-r--r-- 1 root root 4075334 May 14 2017 initrd.img-4.9.12-sunxi -rw-r--r-- 1 root root 4086657 Feb 14 2017 initrd.img-4.9.7-sunxi -rw-r--r-- 1 root root 0 Nov 29 18:43 .next lrwxrwxrwx 1 root root 18 Sep 15 2016 script.bin -> bin/cubietruck.bin -rw-r--r-- 1 root root 3015924 Nov 24 18:51 System.map-4.13.16-sunxi lrwxrwxrwx 1 root root 21 Dec 8 16:33 uInitrd -> uInitrd-4.13.16-sunxi -rw-r--r-- 1 root root 4449103 Dec 8 16:33 uInitrd-4.13.16-sunxi -rw-r--r-- 1 root root 0 Jun 15 2017 .verbose -rwxr-xr-x 1 root root 6790944 Nov 24 18:51 vmlinuz-4.13.16-sunxi lrwxrwxrwx 1 root root 21 Nov 29 18:43 zImage -> vmlinuz-4.13.16-sunxi root@fs:/boot# Link to comment Share on other sites More sharing options...
martinayotte Posted December 30, 2017 Share Posted December 30, 2017 It looks like you are using an old u-boot from Sept 2016. Is this a system that you've upgraded only the kernel without upgrading the u-boot ? Link to comment Share on other sites More sharing options...
john.glasson Posted December 30, 2017 Author Share Posted December 30, 2017 If I run apt-get install linux-u-boot-cubietruck-next, response is that I already have latest version installed. Link to comment Share on other sites More sharing options...
martinayotte Posted December 30, 2017 Share Posted December 30, 2017 Ok ! I was asking because I don't own any cubietruck, and on almost all boards I own, the u-boot version is now 2017.11. Link to comment Share on other sites More sharing options...
john.glasson Posted December 31, 2017 Author Share Posted December 31, 2017 On 06/09/2017 at 9:26 PM, tkaiser said: --- My version 22-Nov-2017 so that looks ok. Link to comment Share on other sites More sharing options...
