cocco Posted January 2, 2018 Posted January 2, 2018 hi i have problem with orangepi plus2e i have not image on hdmi i atach some logs from Tera Term (serial terminal) witout sd HELLO! BOOT0 is starting! boot0 version : 4.2.0 boot0 commit : c8c201b51b7ea1baa94590a1887313124d9a5879 fel_flag = 0x00000000 rtc[0] value = 0x00000000 rtc[1] value = 0x00000000 rtc[2] value = 0x00000000 rtc[3] value = 0x00000000 rtc[4] value = 0x00000000 rtc[5] value = 0x00000000 rtc[6] value = 0x00000000 rtc[7] value = 0x00000000 DRAM DRIVE INFO: V1.4 the chip id is 0x00000081 the chip id is 0x00000081 the chip id is 0x00000081 the chip id is 0x00000081 the chip id is 0x00000081 NOT GATE MODE READ DQS LCDL = 001e1d1e DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM CLK = 672 MHz DRAM zq value: 003b3bfb DRAM dram para1: 11040800 DRAM dram para2: 00000000 DRAM workmode1: 000009f4 DRAM SIZE =2048 M odt delay dram size =2048 card boot number = 2 card no is 2 sdcard 2 line count 8 [mmc]: mmc driver ver 2015-04-13 16:07:39 [mmc]: ***Try SD card 2*** [mmc]: mmc 2 cmd 8 err 00000100 [mmc]: mmc 2 cmd 8 err 00000100 [mmc]: mmc 2 send if cond failed [mmc]: mmc 2 cmd 55 err 00000100 [mmc]: mmc 2 cmd 55 err 00000100 [mmc]: mmc 2 send app cmd failed [mmc]: ***Try MMC card 2*** [mmc]: mmc re-update_phase [mmc]: mmc re-update_phase [mmc]: 8bit ddr!!! [mmc]: mmc re-update_phase [mmc]: MMC ver 5.0 [mmc]: SD/MMC Card: 8bit, capacity: 14910MB [mmc]: vendor: Man 00150100 Snr 00ec7165 [mmc]: product: AWPD3 [mmc]: revision: 5.2 [mmc]: ***SD/MMC 2 init OK!!!*** sdcard 2 init ok The size of uboot is 000e4000. sum=fc107a6e src_sum=fc107a6e set_mmc_para,sdly 50M 0 set_mmc_para,sdly 25M 0 Succeed in loading uboot from sdmmc flash. Ready to disable icache. Jump to secend Boot. SUNXI_NORMAL_MODE [ 0.276]e mode U-Boot 2011.09-rc1-00024-gdbed064 (Nov 30 2015 - 20:18:20) Allwinner Technology [ 0.285]version: 1.1.0 [ 0.288]uboot commit : dbed064f3b1a936e4e374a6284944f4e4e30e9ae not using multi config normal mode [ 0.301]pmbus: ready not set main pmu id axp_probe error [board_vendor] vid_used not used [ 0.319]PMU: pll1 1008 Mhz,PLL6=600 Mhz AXI=336 Mhz,AHB=200 Mhz, APB1=100 Mhz sid read already fel key new mode run key detect no key found no key input dram_para_set start dram_para_set end normal mode [ 0.350]DRAM: 2 GiB relocation Offset is: 75af1000 [box standby] read rtc = 0x0 [box_start_os] mag be start_type no use user_gpio config user_gpio ok gic: normal or no secure os mode workmode = 0 MMC: 2 [ 0.428][mmc]: mmc driver ver 2015-06-1 20:01:00 [ 0.433][mmc]: get sdc_phy_wipe fail. [ 0.437][mmc]: get sdc0 sdc_erase fail. [ 0.441][mmc]: get sdc_2xmode ok, val = 1 [ 0.445][mmc]: get sdc_ddrmode ok, val = 1 [ 0.449][mmc]: get sdc_f_max fail,use default 50000000Hz [ 0.455][mmc]: get card_line ok, card_line = 8 [ 0.459][mmc]: get sdc_ex_dly_used fail,use default [ 0.464][mmc]: SUNXI SD/MMC: 2 [ 0.478][mmc]: *Try SD card 2* [ 0.481][mmc]: mmc 2 cmd 8 err 100 [ 0.487][mmc]: mmc send if cond failed [ 0.491][mmc]: mmc 2 cmd 55 err 100 [ 0.496][mmc]: send app cmd failed [ 0.499][mmc]: *Try MMC card 2* [ 0.541][mmc]: mmc re-update_phase [ 0.546][mmc]: mmc re-update_phase [ 0.551][mmc]: mmc re-update_phase [ 0.556][mmc]: ddr8 [ 0.558][mmc]: mmc re-update_phase [ 0.575][mmc]: CID 0x15010041 0x57504433 0x5200ec71 0x65a21377 [ 0.580][mmc]: MMC ver 5.0 [ 0.583][mmc]: mmc clk 50000000 [ 0.586][mmc]: SD/MMC Card: 8bit, capacity: 14910MB [ 0.592][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB [ 0.597][mmc]: ***SD/MMC 2 init OK!!!*** [ 0.602][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte [ 0.608][mmc]: secure_feature 0x55 [ 0.611][mmc]: secure_removal_type 0x9 [ 0.615]sunxi flash init ok script config pll_de to 864 Mhz Not Found clk pll_video1 in script script config pll_video to 297 Mhz script config pll_periph0 to 600 Mhz [boot]disp_init_tv [DISP_TV] disp_init_tv enter g_tv_used screen 0 do not support TV TYPE! [BOOOT_DISP_TV] disp tv device_registered unable to find regulator vcc-hdmi-18 from [pmu1_regu] or [pmu2_regu] enable power vcc-hdmi-18, ret=-1 DRV_DISP_Init end error: open tv_vdid.fex, maybe it is not exist error: open disp_rsl.fex, maybe it is not exist error: open disp_rsl.fex, maybe it is not exist boot_disp.auto_hpd=1 auto hpd check has 0 times! attched ok, mgr0<-->device0, type=4, mode=4---- ready to set mode [ 1.505]finally, output_type=0x4, output_mode=0x4, screen_id=0x0, disp_para=0x404 In: serial Out: serial Err: serial --------fastboot partitions-------- -total partitions:14- -name- -start- -size- bootloader : 1000000 1000000 env : 2000000 1000000 boot : 3000000 1000000 system : 4000000 30000000 misc : 34000000 1000000 recovery : 35000000 2000000 sysrecovery : 37000000 30000000 private : 67000000 1000000 Reserve0 : 68000000 1000000 klog : 69000000 1000000 Reserve1 : 6a000000 2000000 Reserve2 : 6c000000 1000000 cache : 6d000000 28000000 UDISK : 95000000 0 ----------------------------------- base bootcmd=run setargs_nand boot_normal bootcmd set setargs_mmc key 0 cant find rcvy value cant find fstbt value misc partition found to be run cmd=run setargs_mmc boot_normal read item0 copy0 Item0 (Map) magic is bad the secure storage item0 copy0 is bad read item0 copy1 Item0 (Map) magic is bad the secure storage item0 copy0 == copy1, the data is good Item0 (Map) magic is bad can help me pls tnx
Igor Posted January 3, 2018 Posted January 3, 2018 6 hours ago, cocco said: U-Boot 2011.09-rc1-00024-gdbed064 (Nov 30 2015 - 20:18:20) Allwinner Technology This is not Armbian. We don't support 3rd party builds. Download image here: https://www.armbian.com/orange-pi-plus-2e/ and after you boot it, you can flash it to eMMC as well.
cocco Posted January 3, 2018 Author Posted January 3, 2018 Armbian_5.35_Orangepiplus2e_Ubuntu_xenial_default_3.4.113_desktop _________________________________________________________________ U-Boot SPL 2017.09-armbian (Nov 22 2017 - 16:50:56) DRAM: 2048 MiB Trying to boot from MMC1 U-Boot 2017.09-armbian (Nov 22 2017 - 16:50:56 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Plus 2E DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: phy interface7 eth0: ethernet@1c30000 230454 bytes read in 203 ms (1.1 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 USB4: USB EHCI 1.00 USB5: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 4 for devices... 2 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning bus 3 for devices... 2 USB Device(s) found scanning bus 5 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3708 bytes read in 209 ms (16.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 154 bytes read in 160 ms (0 Bytes/s) 5173329 bytes read in 528 ms (9.3 MiB/s) 4751880 bytes read in 526 ms (8.6 MiB/s) Found legacy kernel configuration 36808 bytes read in 560 ms (63.5 KiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5173265 Bytes = 4.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... [sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 2048MB ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1 ion_reserve_select: ion chipid [0x2c00081! ion_reserve_common: ion reserve: [0xb0000000, 0xc0000000]! <6Loading, please wait... starting version 229 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.27.1 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: recovering journal /dev/mmcblk0p1: clean, 113395/181792 files, 531197/727040 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Ubuntu 16.04.3 LTS! [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Created slice System Slice. [ OK ] Listening on fsck to fsckd communication Socket. [ OK ] Listening on Journal Audit Socket. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Created slice User and Session Slice. [ OK ] Reached target Swap. [ OK ] Listening on udev Kernel Socket. [ OK ] Started Trigger resolvconf update for networkd DNS. [ OK ] Reached target User and Group Name Lookups. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Reached target Paths. [ OK ] Listening on udev Control Socket. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Reached target Slices. [ OK ] Listening on Syslog Socket. [ OK ] Reached target Encrypted Volumes. [ OK ] Set up automount Arbitrary Executab...ats File System Automount Point. [ OK ] Listening on Journal Socket. Starting Load Kernel Modules... Mounting POSIX Message Queue File System... Starting Nameserver information manager... Starting Restore / save the current clock... Mounting Debug File System... Starting Create list of required st... nodes for the current kernel... Starting Remount Root and Kernel File Systems... Starting Set console keymap... [ OK ] Reached target Remote File Systems (Pre). [ OK ] Reached target Remote File Systems. [ OK ] Mounted Debug File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Started Load Kernel Modules. [ OK ] Started Restore / save the current clock. [ OK ] Started Create list of required sta...ce nodes for the current kernel. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Set console keymap. [ OK ] Started Nameserver information manager. Starting udev Coldplug all Devices... Starting Load/Save Random Seed... Starting Create Static Device Nodes in /dev... Mounting FUSE Control File System... Starting Apply Kernel Variables... [ OK ] Mounted FUSE Control File System. [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Started Apply Kernel Variables. [ OK ] Started udev Coldplug all Devices. [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... Starting udev Kernel Device Manager... [ OK ] Mounted /tmp. [ OK ] Reached target Local File Systems. Starting Set console font and keymap... Starting Armbian enhanced Log2Ram... [ OK ] Started Entropy daemon using the HAVEGE algorithm. [ OK ] Started udev Kernel Device Manager. [ OK ] Reached target Sound Card. [ OK ] Found device /dev/ttyS0. [ OK ] Started Armbian enhanced Log2Ram. [ OK ] Found device /sys/subsystem/net/devices/eth0. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. Starting Journal Service... Starting Load/Save RF Kill Switch Status... [ OK ] Started Journal Service. [ OK ] Started Load/Save RF Kill Switch Status. Starting Flush Journal to Persistent Storage... [ OK ] Started Flush Journal to Persistent Storage. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... [ OK ] Reached target System Time Synchronized. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Reached target System Initialization. Starting Armbian filesystem resize service... [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. [ OK ] Started Daily Cleanup of Temporary Directories. [FAILED] Failed to start Set console font and keymap. See 'systemctl status console-setup.service' for details. [ OK ] Started Armbian filesystem resize service. [ OK ] Reached target Basic System. Starting System Logging Service... Starting Accounts Service... Starting Save/Restore Sound Card State... Starting Initializes zram swaping... Starting Avahi mDNS/DNS-SD Stack... Starting LSB: Load kernel modules needed to enable cpufreq scaling... Starting LSB: No Display Manager... Starting Login Service... Starting LSB: Armbian gathering hardware information... [ OK ] Reached target Network (Pre). Starting Raise network interfaces... [ OK ] Started ifup for eth0. [ OK ] Started Armbian first run tasks. [ OK ] Created slice system-getty.slice. Starting LSB: Start/stop sysstat's sadc... [ OK ] Started Regular background program processing daemon. [ OK ] Started D-Bus System Message Bus. [ OK ] Started Avahi mDNS/DNS-SD Stack. Starting Network Manager... Starting Permit User Sessions... [ OK ] Started System Logging Service. [ OK ] Started Initializes zram swaping. [ OK ] Started Permit User Sessions. [ OK ] Started Save/Restore Sound Card State. [ OK ] Started LSB: No Display Manager. [ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling. [ OK ] Started LSB: Start/stop sysstat's sadc. [ OK ] Started Network Manager. [ OK ] Started Login Service. Starting Network Manager Script Dispatcher Service... Starting Network Manager Wait Online... Starting Authenticate and Authorize Users to Run Privileged Tasks... Starting LSB: set CPUFreq kernel parameters... Starting Set console scheme... [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started Set console scheme. [ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks. [ OK ] Started Raise network interfaces. [ OK ] Started Accounts Service. [ OK ] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [ OK ] Reached target Network. Starting OpenBSD Secure Shell server... Starting OpenVPN service... [ OK ] Started Unattended Upgrades Shutdown. Starting Hostname Service... [ OK ] Started OpenVPN service. [ OK ] Started OpenBSD Secure Shell server. [ OK ] Started Hostname Service. [ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf. [ OK ] Started LSB: Armbian gathering hardware information. Starting WPA supplicant... [ OK ] Started WPA supplicant. Starting Load/Save RF Kill Switch Status... [ OK ] Started Load/Save RF Kill Switch Status. [ OK ] Started Network Manager Wait Online. [ OK ] Reached target Network is Online. Starting /etc/rc.local Compatibility... Starting LSB: disk temperature monitoring daemon... [ OK ] Started Daily apt download activities. [ OK ] Started Daily apt upgrade and clean activities. [ OK ] Reached target Timers. Starting LSB: Advanced IEEE 802.11 management daemon... Starting LSB: Start NTP daemon... [ OK ] Started /etc/rc.local Compatibility. [ OK ] Started LSB: Advanced IEEE 802.11 management daemon. [ OK ] Started Serial Getty on ttyS0. [ OK ] Started Getty on tty1. [ OK ] Reached target Login Prompts. [ OK ] Started LSB: disk temperature monitoring daemon. [ OK ] Started LSB: Start NTP daemon. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. Ubuntu 16.04.3 LTS orangepiplus2e ttyS0 orangepiplus2e login: root Password: You are required to change your password immediately (root enforced) Changing password for root. (current) UNIX password: Enter new UNIX password: Retype new UNIX password: ___ ____ _ ____ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) _ |___ \| ____| | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |_| |_ __) | _| | |_| | | | (_| | | | | (_| | __/ | __/| |_ _| / __/| |___ \___/|_| \__,_|_| |_|\__, |\___| |_| |_| |_| |_____|_____| |___/ Welcome to ARMBIAN 5.35 user-built Ubuntu 16.04.3 LTS 3.4.113-sun8i System load: 1.74 0.45 0.15 Up time: 0 min Memory usage: 2 % of 2014MB IP: CPU temp: 46°C Usage of /: 75% of 2.8G Warning: a reboot is needed to finish resizing the filesystem Please reboot the system as soon as possible New to Armbian? Check the documentation first: https://docs.armbian.com Thank you for choosing Armbian! Support: www.armbian.com Creating a new user account. Press <Ctrl-C> to abort Desktop environment will not be enabled if you abort the new user creation Please provide a username (eg. your forename): cocco Trying to add user cocco Adding user `cocco' ... Adding new group `cocco' (1000) ... Adding new user `cocco' (1000) with group `cocco' ... Creating home directory `/home/cocco' ... Copying files from `/etc/skel' ... Enter new UNIX password: Retype new UNIX password: passwd: password updated successfully Changing the user information for cocco Enter the new value, or press ENTER for the default Full Name []: Room Number []: Work Phone []: Home Phone []: Other []: Is the information correct? [Y/n] y Dear cocco, your account cocco has been created and is sudo enabled. Please use this account for your daily work from now on. Your display settings are currently 720p (1280x720). To change this use the h3disp utility. Do you want to change display settings now? [nY] n Warning: a reboot is needed to finish resizing the filesystem Please reboot the system now root@orangepiplus2e:~# root@orangepiplus2e:~# startx xauth: file /root/.Xauthority does not exist X.Org X Server 1.18.4 Release Date: 2016-07-19 X Protocol Version 11, Revision 0 Build Operating System: Linux 4.4.0-97-generic armv7l Ubuntu Current Operating System: Linux orangepiplus2e 3.4.113-sun8i #4 SMP PREEMPT Wed Nov 22 13:45:28 CET 2017 armv7l Kernel command line: root=UUID=c9935ecd-9814-4cd9-bfd4-5bf53ea6a1d6 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=7010ec8c-01 ubootsource=mmc usb-storage.quirks= cma=96M cgroup_enable=memory swapaccount=1 Build Date: 13 October 2017 01:59:44PM xorg-server 2:1.18.4-0ubuntu0.7 (For technical support please see http://www.ubuntu.com/support) Current version of pixman: 0.33.6 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 25 05:45:22 2017 (==) Using config directory: "/etc/X11/xorg.conf.d" (==) Using system config directory "/usr/share/X11/xorg.conf.d" modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/3.4.113-sun8i modprobe: FATAL: Module sunxi_cedar_mod not found in directory /lib/modules/3.4.113-sun8i xf86: found device 0 xf86: found device 0
Igor Posted January 3, 2018 Posted January 3, 2018 14 minutes ago, cocco said: Please reboot the system now Do it.
