Scrumpper Posted 8 hours ago Posted 8 hours ago It seemed like EVERYONE was talking about "looking into" getting Armbian going on this box. I did my best. Built from the Rock5b images. WiFi: Broadcom BCM43752 / AP6275P 802.11ax "WiFi 6" Panthor + Mesa GPU stack Open PanVK Vulkan + Panfrost GL GPU driver Gpu no longer pinned to 800MHz. Power toggles cycle it 600MHz, 800MHz, and 1000MHz. (the CPU also scales) Desktop compositing on the GPU A command is needed to set monitor resolution. Default is 1080p. Other Findings: CPU frequency was scanned under load: LITTLE cores (Cortex-A55): 1800 MHz BIG cores (Cortex-A76): 2208 MHz Those were the scaling_cur_freq readings. The vendor DTB caps the A76 at 2208 MHz: the physical max is 2.4 GHz but that OPP entry isn't in the table. Github repo: DOWNLOAD RELEASE FILES READ THE README.md! REFLASH STOCK IMAGE: UNPACKED FLASHING FILES FOR STOCK ANDROID README.md 0 Quote
