first of all thanks a lot for every contributor, this is a great project, I'm an absolute fan!
I'm running Armbian on an orange pi 2, everything works fine for a while. I'm running a homegrown python script with flask, this one works too.
But after ~1-x hours, I can't connect anymore to my web service. This could be my problem, but in fact, neither SSH works.
So I found these things, my script tells me this:
Exception happened during processing of request from ('192.168.0.158', 59734)
Traceback (most recent call last):
  File "/usr/lib/python2.7/SocketServer.py", line 290, in _handle_request_noblock
    self.process_request(request, client_address)
  File "/usr/lib/python2.7/SocketServer.py", line 318, in process_request
    self.finish_request(request, client_address)
  File "/usr/lib/python2.7/SocketServer.py", line 331, in finish_request
    self.RequestHandlerClass(request, client_address, self)
  File "/usr/lib/python2.7/SocketServer.py", line 654, in __init__
    self.finish()
  File "/usr/lib/python2.7/SocketServer.py", line 713, in finish
    self.wfile.close()
  File "/usr/lib/python2.7/socket.py", line 283, in close
    self.flush()
  File "/usr/lib/python2.7/socket.py", line 307, in flush
    self._sock.sendall(view[write_offset:write_offset+buffer_size])
error: [Errno 32] Broken pipe
I did some wiresharking too for sure :) Looks like something is messed up, and TCP ends up with an RST.
https://drive.google.com/file/d/18GP8YvmaicyVGPHWYLzTulhkI0bPQTxy/view?usp=sharing
and my pcaps:
https://drive.google.com/file/d/1tJP1I71d7zCUFxzh3Ce75SpwrP3JBXsa/view?usp=sharing
https://drive.google.com/file/d/1ZIM74rI1T7qTOJ0q5Bmvk1sDUXdgaQeU/view?usp=sharing
Thanks for everyone !
argh, one important thing I missed, if I use the Network manager to disconnect and connect the connection, than the issue is gone.
so like:
nmcli c d "Wired Connection 1"
nmcli c u "Wired Connection 1"
And a couple of extra things, I haven't found anything interesting or related in the logs,
and I do have connection from the HW side, so I'm connected via a serial port, and I can ping google and so on.
so looks like I have an issue only with the inbound connections, based on my limited understanding,
my PC sends an RST in both cases, in the first case it looks like I get a re transmission of an already acked package...
but why?
I have the same issue here.
After some hours I can't access the OPi Zero via any connection (eth / wifi).
I tried via Serial and I can ping google.com without problems.
When i restart my network "sudo ip link set eth0 down && sudo ip link set eth0 up" all is running fine again.
You both forgot to provide the most important info: Which kernel/system version do you use? We have a utility which helps to debug. Do update and run
armbianmonitor -u
11 minutes ago, Stefan Anderson said:
When I run armbianmonitor -u it wont give me any URL.
Even after you run apt update && apt upgrade ? (you need a working network connection)
Hello all !
I have a similar issue here, with an OPiZ running Armbian_5.35_Orangepizero_Ubuntu_xenial_next_4.13.16. The OPiZ is sitting aside, connected via wifi to my domoticz box and is sending data to the box every 5 minutes. After a while, I cannot connect to the OPiZ from any other machine than the domoticz box. I noticed when this happens, the OPiZ does not respond to the ARP broadcast message, thus the calling machine never gets its MAC addr in the arp list. If I manually add the MAC address to the arp table of the third party machine, I can connect again to the OPiZ. I have not found any related message in the logs.
I don't know yet if it's related or not, but after connecting that way, I noticed the wifi card is in the mode DORMANT :
root@orangepizero:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
    link/ether 02:42:cd:b3:65:af brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
    link/ether 12:42:cd:b3:65:af brd ff:ff:ff:ff:ff:ff
Food for thought only so far, I'll continue to investigate the issue
This is because of the "bad drivers" for wifi chip.
But they dont write anywhere about problems with the Ethernet.
I switched back to the Armbian 5.35 (jessie) 3.4.113 and now I havent any problems.
Hi all,
I have the same issue on Ethernet connection.
After about 3 hours in idle, I can’t connect with OPI PC via SSH or HTTP
But I found that after ping OPI several times, it is possible to connect via SSH only from device from which I ping before.
